    [Plugin]Hole on Solid tool v1.6.3 upadate Jan 09, 2012
    134 Posts 43 Posters 98.9k Views 43 Watching
      tak2hata
      I update this to v1.6.in Dec 14, 2011.
      New function and small improves.
      Enjoy. πŸ˜‰
      by TAK2HATA
        RichardCherry
        Absolutely superb!
        The update is excellent, thank you πŸ˜„
        • bmikeB Offline
          bmike
          will try it out after the update!
          • simon le bonS Offline
            simon le bon
            Dear tak2hata,
            veryyy nice upgrade indeed!! πŸ‘ πŸ‘ πŸ˜„
            (model Fancy arched window by loverevolutionary on 3D Warehouse)
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thHoleonSolidtool_tak2hata_002.jpg
            Would you please tak2hata not give up in such a good path: It remains a major limitation.
            It would be very interesting to drill holes by lot in case of large number of windows for exemple...
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thHoleonSolidtool_tak2hata_003.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thHoleonSolidtool_tak2hata_004.jpg
            A little reminder on how make a Component with a cutting option:
            (I have myself to revisit the process each time πŸ˜• )
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_HoleonSolidtool_tak2hata_005.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_HoleonSolidtool_tak2hata_006.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_HoleonSolidtool_tak2hata_007.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_HoleonSolidtool_tak2hata_008.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_HoleonSolidtool_tak2hata_009.jpg
            Cheers,
            simon
              tak2hata
              Hi,Simon.
              Thanks your opinion.
              I will add function multi hole.
              You give me nice idea and description picture.
              And the funcy window is very nice.
              Thanks.
              by TAK2HATA
                sicd_steve
                It won't work on Snow Leopard 10.6.8 I can't get it to work on a Mac?
                I have done everything ?
                  jorge2011
                  tak2hata hello. Thank you very much for this excellent plugin.
                  Just a suggestion,
                  Is possible to add an option (for example by pressing the alt key) for projecting the selected faces over the group or component?
                    It does something on my Mac with 10.6.8. It's not what I expected. Hmmm
                      tak2hata
                      Hi,sicd_steve ,Dave.
                      I will test the problem on mac later in few days.
                      Please wait.
                      by TAK2HATA
                        driven
                        Hi it's working, with and without other plugins enabled on 10.5.8.
                        I do get
                        WARNING: make_unique is a deprecated methodof Sketchup:Group nil WARNING: make_unique is a deprecated methodof Sketchup:Group
                        but it functions.
                        so any one on Lion who is up for a simple test can.
                        in 'Ruby Console' enter
                        Sketchup.plugins_disabled = **true**
                        then quit and restart, you will now not have a plugins menu,
                        so open Ruby Console again and type or copy/paste
                        load '/Library/Application Support/Google SketchUp 8/SketchUp/plugins/create_hole_on_solid.rb'
                        modify if your path is different
                        Retest the plugin... then into RC again
                        Sketchup.plugins_disabled = **false**
                        to turn back on all your plugins next startup.
                          tak2hata
                          I test this plugin on mac os 10.6.8 and sketchup v8 free.
                          It work well.
                          So I need to know what is caused for this problem.
                          Please show the ruby console message as Driven says.
                          I will guess from that message.
                          Thanks.
                          by TAK2HATA
                            Here you go.
                            nil
                            Error: #<TypeError: Cannot convert argument to Sketchup::Entities>
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:306:in intersect_with' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:306:in subtract_form'
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:139:in subtract_form_MS' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:131:in subtract_start'
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:440:in increment_state' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:470:in onLButtonDown'
                              tak2hata
                              Hi,Dave:
                              I update this plugin.
                              This will work.
                              Sorry this problem was happened in windows os ,too. but It was corrected.
                              Please try it.
                              Thanks.
                              by TAK2HATA
                                Excellent! It work well now. Thank you.
                                May I make a request? I know you changed the script so that when a circle is punch through, the edges on the sides of the hole are soften. That's the way I think it should work but... For polygons, could you make it so that the edges are not softened?
                                  samatall
                                  Hi tak2hata,
                                  I tried it in SU 8. I did a simple wall and a circle face in front of it. Then I applied this plugin. It only duplicated the circle (but grouped). I tried using window components on it. It also made a intersection profiled face on the wall. I have no idea how to figure out this. Can anyone help?
                                    Post the example SKP file so it can be examined.
                                      samatall
                                      Dave, Attached is the model to explain it. Thanksexample001.skp
                                        I opened the wall group and deleted the copy of the circle. Then I closed the group. I selected the tool, the wall and then the circle. Hole punched just fine. Do you have the most recent version of the plugin?
                                        example001.skp
                                        • E Offline
                                          Enachi
                                          For some reason this plugin is not working with my SU v8. I've installed latest version of bst and hos 1.6.1. Even so, when I activate the plugin, then the tool and then I go for the wall, this is simple selected in blue color (not orange as I've seen on tutorial) and doesn't let me to select the circle, that would make the hole.
                                          Any suggestion?
                                          Thank you.
                                            tak2hata
                                            Any suggestion?
                                            Thank you.
                                            Hi,enachi.
                                            The face and solid must be in same Group or Component or Model.
                                            It is rule of this plugin.
                                            If this is not solution for your trouble,Please show ruby console from 'menu' -> 'Window' -> 'Ruby console'
                                            And work some with this plugin,the error message will show when error is happened.
                                            or Download the example.skp that Dave R uploaded in this topics.and test it.
                                            Please reply the result.
                                            Thanks.
                                            by TAK2HATA
                                            • 3 / 7
