    [Plugin]Hole on Solid tool v1.6.3 upadate Jan 09, 2012
    134 Posts 43 Posters 98.4k Views 43 Watching
      j_forrester
      First of all great plugin!
      I was wondering if would be possible to first select your solid as currently, but then select a group of many faces and it create a whole for all in one go or is it limited to only a single face at a time?
      Keep up the good work!
      • MALAISEM Offline
        MALAISE
        Hi tak2hata,
        This "tool" is awsome ! You hardly imagine time saved by using it in complex
        shapes. Thanks for sharing 😄
        MALAISE
          tak2hata
          I correct bug.
          Fix to correct the hole shifting.
          Perhaps OK. 😉
          Thanks.
          by TAK2HATA
            jorge2011
            Hi, tak2hata:
            Thank you very much for this wonderful plugins.
            I send a file to test the plugin. I think the plugin does not work well with these geometries.
            thank you very much
            Sin título.skp
            • mitcorbM Offline
              mitcorb
              Hi, tak2hata:
              I am glad to report that the tool works in both v7 and v8. I made the observation (probably obvious, but not demonstrated) that the hole punching path is always normal to the face doing the punch. So, if your cutting face is slightly off angle, then the hole may not occur exactly where you expect it.
              EDIT: All that is required is that the object to receive the hole be a grouped closed volume.
              The tool will ignore all other intervening geometry that might be in the cutting path.
              EDIT: Oh, and thank you once again, tak2hata san!
                tak2hata
                @jorge2011 said:
                Hi, tak2hata:
                thank you very much
                Hi,jorge2011.
                I saw your model.
                It does not be occluded with very small faces being disconnected.
                It must correct to be judged as solid in sketchup v8.
                solid model I want is all each edges has connecntion to 2 faces or 4 faces.In this case,the faces are occluded.
                Thanks.
                by TAK2HATA
                • sumasterS Offline
                  sumaster
                  Hello tak2hata,
                  It's very useful tool .......
                  GooD ....... Thank you ........
                  Very nice .......
                  Thank you,
                  SUmaster
                  • simon le bonS Offline
                    simon le bon
                    Hi tak2hata ☀
                    This is a very smart tool where Su is lacking. Thanks a lot. 👍 👍 😎
                    (not very far from TIG's "Hole Punching Tool" complementary and maybe more easy to use "on the fly".
                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thHoleonSolidtool_tak2hata_01.jpg
                    Do you think It will be possible to overpass some limitations ?
                    -> use it on a shape which is not necessarily : - a closed shape, - a group or a component.
                    -> select a bunch of faces to be hole punched rather than to be one by one ?
                    My respect and my friendship for what you gracefully share into this place,
                    http://i274.photobucket.com/albums/jj245/Spendauballet/iSimon/applause.gif
                    ++simon
                      tak2hata
                      I update this to v1.6.in Dec 14, 2011.
                      New function and small improves.
                      Enjoy. 😉
                      by TAK2HATA
                        RichardCherry
                        Absolutely superb!
                        The update is excellent, thank you 😄
                        • bmikeB Offline
                          bmike
                          will try it out after the update!
                            simon le bon
                            Dear tak2hata,
                            veryyy nice upgrade indeed!! 👍 👍 😄
                            (model Fancy arched window by loverevolutionary on 3D Warehouse)
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thHoleonSolidtool_tak2hata_002.jpg
                            Would you please tak2hata not give up in such a good path: It remains a major limitation.
                            It would be very interesting to drill holes by lot in case of large number of windows for exemple...
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thHoleonSolidtool_tak2hata_003.jpg
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thHoleonSolidtool_tak2hata_004.jpg
                            A little reminder on how make a Component with a cutting option:
                            (I have myself to revisit the process each time 😕 )
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_HoleonSolidtool_tak2hata_005.jpg
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_HoleonSolidtool_tak2hata_006.jpg
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_HoleonSolidtool_tak2hata_007.jpg
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_HoleonSolidtool_tak2hata_008.jpg
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_HoleonSolidtool_tak2hata_009.jpg
                            Cheers,
                            simon
                              tak2hata
                              Hi,Simon.
                              Thanks your opinion.
                              I will add function multi hole.
                              You give me nice idea and description picture.
                              And the funcy window is very nice.
                              Thanks.
                              by TAK2HATA
                                sicd_steve
                                It won't work on Snow Leopard 10.6.8 I can't get it to work on a Mac?
                                I have done everything ?
                                  jorge2011
                                  tak2hata hello. Thank you very much for this excellent plugin.
                                  Just a suggestion,
                                  Is possible to add an option (for example by pressing the alt key) for projecting the selected faces over the group or component?
                                    It does something on my Mac with 10.6.8. It's not what I expected. Hmmm
                                      tak2hata
                                      Hi,sicd_steve ,Dave.
                                      I will test the problem on mac later in few days.
                                      Please wait.
                                      by TAK2HATA
                                        driven
                                        Hi it's working, with and without other plugins enabled on 10.5.8.
                                        I do get
                                        WARNING: make_unique is a deprecated methodof Sketchup:Group nil WARNING: make_unique is a deprecated methodof Sketchup:Group
                                        but it functions.
                                        so any one on Lion who is up for a simple test can.
                                        in 'Ruby Console' enter
                                        Sketchup.plugins_disabled = **true**
                                        then quit and restart, you will now not have a plugins menu,
                                        so open Ruby Console again and type or copy/paste
                                        load '/Library/Application Support/Google SketchUp 8/SketchUp/plugins/create_hole_on_solid.rb'
                                        modify if your path is different
                                        Retest the plugin... then into RC again
                                        Sketchup.plugins_disabled = **false**
                                        to turn back on all your plugins next startup.
                                          tak2hata
                                          I test this plugin on mac os 10.6.8 and sketchup v8 free.
                                          It work well.
                                          So I need to know what is caused for this problem.
                                          Please show the ruby console message as Driven says.
                                          I will guess from that message.
                                          Thanks.
                                          by TAK2HATA
                                            Here you go.
                                            nil
                                            Error: #<TypeError: Cannot convert argument to Sketchup::Entities>
                                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:306:in intersect_with' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:306:in subtract_form'
                                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:139:in subtract_form_MS' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:131:in subtract_start'
                                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:440:in increment_state' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:470:in onLButtonDown'
                                            • 3 / 7
