    [Plugin]Hole on Solid tool v1.6.3 upadate Jan 09, 2012
    134 Posts 43 Posters 105.2k Views 43 Watching
    • simon le bonS
      simon le bon
      Hi tak2hata β˜€
      This is a very smart tool where Su is lacking. Thanks a lot. πŸ‘ πŸ‘ 😎
      (not very far from TIG's "Hole Punching Tool" complementary and maybe more easy to use "on the fly".
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thHoleonSolidtool_tak2hata_01.jpg
      Do you think It will be possible to overpass some limitations ?
      -> use it on a shape which is not necessarily : - a closed shape, - a group or a component.
      -> select a bunch of faces to be hole punched rather than to be one by one ?
      My respect and my friendship for what you gracefully share into this place,
      http://i274.photobucket.com/albums/jj245/Spendauballet/iSimon/applause.gif
      ++simon
      • T
        tak2hata
        I update this to v1.6.in Dec 14, 2011.
        New function and small improves.
        Enjoy. πŸ˜‰
        by TAK2HATA
          RichardCherry
          Absolutely superb!
          The update is excellent, thank you πŸ˜„
          • bmikeB
            bmike
            will try it out after the update!
            • simon le bonS
              simon le bon
              Dear tak2hata,
              veryyy nice upgrade indeed!! πŸ‘ πŸ‘ πŸ˜„
              (model Fancy arched window by loverevolutionary on 3D Warehouse)
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thHoleonSolidtool_tak2hata_002.jpg
              Would you please tak2hata not give up in such a good path: It remains a major limitation.
              It would be very interesting to drill holes by lot in case of large number of windows for exemple...
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thHoleonSolidtool_tak2hata_003.jpg
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thHoleonSolidtool_tak2hata_004.jpg
              A little reminder on how make a Component with a cutting option:
              (I have myself to revisit the process each time πŸ˜• )
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_HoleonSolidtool_tak2hata_005.jpg
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_HoleonSolidtool_tak2hata_006.jpg
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_HoleonSolidtool_tak2hata_007.jpg
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_HoleonSolidtool_tak2hata_008.jpg
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_HoleonSolidtool_tak2hata_009.jpg
              Cheers,
              simon
              • T
                tak2hata
                Hi,Simon.
                Thanks your opinion.
                I will add function multi hole.
                You give me nice idea and description picture.
                And the funcy window is very nice.
                Thanks.
                by TAK2HATA
                  sicd_steve
                  It won't work on Snow Leopard 10.6.8 I can't get it to work on a Mac?
                  I have done everything ?
                    jorge2011
                    tak2hata hello. Thank you very much for this excellent plugin.
                    Just a suggestion,
                    Is possible to add an option (for example by pressing the alt key) for projecting the selected faces over the group or component?
                      It does something on my Mac with 10.6.8. It's not what I expected. Hmmm
                      • T
                        tak2hata
                        Hi,sicd_steve ,Dave.
                        I will test the problem on mac later in few days.
                        Please wait.
                        by TAK2HATA
                          driven
                          Hi it's working, with and without other plugins enabled on 10.5.8.
                          I do get
                          WARNING: make_unique is a deprecated methodof Sketchup:Group nil WARNING: make_unique is a deprecated methodof Sketchup:Group
                          but it functions.
                          so any one on Lion who is up for a simple test can.
                          in 'Ruby Console' enter
                          Sketchup.plugins_disabled = **true**
                          then quit and restart, you will now not have a plugins menu,
                          so open Ruby Console again and type or copy/paste
                          load '/Library/Application Support/Google SketchUp 8/SketchUp/plugins/create_hole_on_solid.rb'
                          modify if your path is different
                          Retest the plugin... then into RC again
                          Sketchup.plugins_disabled = **false**
                          to turn back on all your plugins next startup.
                          • T
                            tak2hata
                            I test this plugin on mac os 10.6.8 and sketchup v8 free.
                            It work well.
                            So I need to know what is caused for this problem.
                            Please show the ruby console message as Driven says.
                            I will guess from that message.
                            Thanks.
                            by TAK2HATA
                              Here you go.
                              nil
                              Error: #<TypeError: Cannot convert argument to Sketchup::Entities>
                              /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:306:in intersect_with' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:306:in subtract_form'
                              /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:139:in subtract_form_MS' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:131:in subtract_start'
                              /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:440:in increment_state' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:470:in onLButtonDown'
                              • T
                                tak2hata
                                Hi,Dave:
                                I update this plugin.
                                This will work.
                                Sorry this problem was happened in windows os ,too. but It was corrected.
                                Please try it.
                                Thanks.
                                by TAK2HATA
                                  Excellent! It work well now. Thank you.
                                  May I make a request? I know you changed the script so that when a circle is punch through, the edges on the sides of the hole are soften. That's the way I think it should work but... For polygons, could you make it so that the edges are not softened?
                                    samatall
                                    Hi tak2hata,
                                    I tried it in SU 8. I did a simple wall and a circle face in front of it. Then I applied this plugin. It only duplicated the circle (but grouped). I tried using window components on it. It also made a intersection profiled face on the wall. I have no idea how to figure out this. Can anyone help?
                                      Post the example SKP file so it can be examined.
                                        samatall
                                        Dave, Attached is the model to explain it. Thanksexample001.skp
                                          I opened the wall group and deleted the copy of the circle. Then I closed the group. I selected the tool, the wall and then the circle. Hole punched just fine. Do you have the most recent version of the plugin?
                                          example001.skp
                                          • E
                                            Enachi
                                            For some reason this plugin is not working with my SU v8. I've installed latest version of bst and hos 1.6.1. Even so, when I activate the plugin, then the tool and then I go for the wall, this is simple selected in blue color (not orange as I've seen on tutorial) and doesn't let me to select the circle, that would make the hole.
                                            Any suggestion?
                                            Thank you.
                                            • 3 / 7
