    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 294.4k Views 172 Watching
    • charly2008C Offline
      charly2008
      John,
      I've tried the modified folder but no change. Even if the textures folder was deleted, wisteria, and ivy leaves appear the same. I do not understand, this is crazy!
      Charly
      Textures Folder deleted
        charly2008
        Dear members,
        I need an idea from you. How can I eliminate this material Wisteria? I've searched the entire hard disk, but these "Wisteria.png" is nowhere to be found. But these png must be stored somewhere. I feel like a beginner.
        Charly
          charly2008
          Problem solved. The png was saved in my template.
            charly2008
            I give it up now. Now the plugin is working again. But now some leaves are again transparent and others not. I probably do not understand the workings of this plugin. I'll wait for an update. 😢
            Charly
            • romboutR Offline
              rombout
              Charly
              THat's due to the prob that 2 images arent transparent png's open these to in a image editor and make them transparent and than re-import them into SU
                charly2008
                Hi Rombout,
                Thanks for your answer. I have converted the jpg to png. I do not know if I've done anything wrong. I have attached the pngs below. If you watch it once I would be grateful.
                Charly
                  You seem to be going round in circles.
                  This zip containing the three adjusted SKPs [and PNGs] that have hidden edges and already use proper transparent PNG files...
                  Replace those in the Textures folder...
                  Retry...IvyTexturesSKPs.zip
                    charly2008
                    TIG,
                    I do not know how I can thank you. Sometimes you appear to me like the Robin Hood of the forum.
                    Charly
                    • RomBR Offline
                      RomB
                      you need to make reset button. i have made a lot of changes in numbers...and now my ivy don't grow on a wall, it grows in every direction...please can someone share default settings?
                        @romb said:
                        you need to
                        Did you mean, "it would be nice with" or "Could you please"? 😉
                        Just saying, the wording can make a difference. Making freeware stuff and you end up with lots of demands from your users, it can get a bit tiresome. (Spoken by someone who makes lots of freeware.)
                          hsh = {
                                      ;branch   => {
                                          ;nodesize    => 3,
                                          ;pattern     => 0.8,
                                          ;probability => 0.97,
                                          ;radius      => 0.8,
                                          ;floatlength => 150,
                                          ;detail      => 4,
                                          ;spread      => 0
                                      ;leaf     => {
                                          ;pattern     => 1,
                                          ;probability => 0.7,
                                          ;size        => 5
                                      ;gravity  => {
                                          ;weight => 1,
                                          ;vector => [0, 0, -1]
                                      ;wind     => {
                                          ;weight => 0.1
                                      ;random   => {
                                          ;weight => 0.3
                                      ;adhesion =>{
                                          ;max_adhesion_distance => 50,
                                          ;weight                => 0.2
                                      ;legacy   => {
                                          ;weight => 0.8
                          The default settings as extracted from the code.
                          Now you do some work resetting your values manually... 😐
                            No worries. 😉
                            • RomBR Offline
                              RomB
                              sorry for my english at first. not my native - in russian i mean that this option will be very usefull. and of course thanks for that plugin. sorry if i offend somehow someone of developers. sorry please
                              ps. in russian it's a little bit more words need to be said of simple -you need to make-
                              • RomBR Offline
                                RomB
                                still not on the wall ((( picture above. where's my mistake?
                                  I don't even have this tool installed !
                                  The default adhesion seems to be 50 in the code I posted...
                                  Why is yours 0.2 [20?] ??
                                  Presumably the higher the adhesion value the more it sticks to the wall ???
                                  • RomBR Offline
                                    RomB
                                    that's it ) maybe i know english - but no so good till that time. and 0.5 become working not from next ivy, from third. But problem is solved - thx. better to rename adhesion to -sticking- 😄 fo rus users
                                    • RomBR Offline
                                      RomB
                                      it won't work properly again, with -adhesion- 0.5 it's still grow in every direction. what's wrong with me? please help me to understand.
                                      ps. it's skp file in archive, my model in wich ivy goes crazy. maybe problem it it?
                                      Land_Mass_2_test_2.rar
                                      • Z Offline
                                        zick
                                        wow 👍
                                        • iichiversiiI Offline
                                          iichiversii
                                          Wow Ivy Generator is great, but im having a problem importing the file back into SU, i can export my model from SU into Ivy Gen but when i import it to SU it freezes SU and never recovers, im using free version of SU and using obj importer, any suggestions would be great
                                          Bring on the Rain...
                                          • F Offline
                                            farmerjoe50
                                            I dropped file into plugins folder but it is not showing up in sketchup...I noticed the file is .rar, not a rb file. What is the secret?
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 36
                                            • 37
                                            • 20 / 37
