    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 450.2k Views 172 Watching
      driven
      Charley,
      are the Materials showing up in the browser when you launch Ivy?
      and does the script have Tigs mod??
      • charly2008C Offline
        charly2008
        Hi John,
        no, only the material for the tribe. Yes I have installed the "TIG mod".
          driven
          did you try it without the mod... john
            charly2008
            John,
            yes i did. I have looked again at the contents of the texture folder (see pictures below). Can it be that something is missing here?
            SKP-Files
            Texture Files
              driven
              I think it's to do with the image file name, I remember re-naming a complete set to replace the originals when I was playing with it.
              early in the thread someone supplied a modified Textures folder [with different leafs], maybe look at that...
                charly2008
                John,
                I've tried the modified folder but no change. Even if the textures folder was deleted, wisteria, and ivy leaves appear the same. I do not understand, this is crazy!
                Charly
                Textures Folder deleted
                  charly2008
                  Dear members,
                  I need an idea from you. How can I eliminate this material Wisteria? I've searched the entire hard disk, but these "Wisteria.png" is nowhere to be found. But these png must be stored somewhere. I feel like a beginner.
                  Charly
                    charly2008
                    Problem solved. The png was saved in my template.
                      charly2008
                      I give it up now. Now the plugin is working again. But now some leaves are again transparent and others not. I probably do not understand the workings of this plugin. I'll wait for an update. 😢
                      Charly
                      • romboutR Offline
                        rombout
                        Charly
                        THat's due to the prob that 2 images arent transparent png's open these to in a image editor and make them transparent and than re-import them into SU
                          charly2008
                          Hi Rombout,
                          Thanks for your answer. I have converted the jpg to png. I do not know if I've done anything wrong. I have attached the pngs below. If you watch it once I would be grateful.
                          Charly
                            You seem to be going round in circles.
                            This zip containing the three adjusted SKPs [and PNGs] that have hidden edges and already use proper transparent PNG files...
                            Replace those in the Textures folder...
                            Retry...IvyTexturesSKPs.zip
                              charly2008
                              TIG,
                              I do not know how I can thank you. Sometimes you appear to me like the Robin Hood of the forum.
                              Charly
                              • RomBR Offline
                                RomB
                                you need to make reset button. i have made a lot of changes in numbers...and now my ivy don't grow on a wall, it grows in every direction...please can someone share default settings?
                                  @romb said:
                                  you need to
                                  Did you mean, "it would be nice with" or "Could you please"? 😉
                                  Just saying, the wording can make a difference. Making freeware stuff and you end up with lots of demands from your users, it can get a bit tiresome. (Spoken by someone who makes lots of freeware.)
                                    hsh = {
                                                ;branch   => {
                                                    ;nodesize    => 3,
                                                    ;pattern     => 0.8,
                                                    ;probability => 0.97,
                                                    ;radius      => 0.8,
                                                    ;floatlength => 150,
                                                    ;detail      => 4,
                                                    ;spread      => 0
                                                ;leaf     => {
                                                    ;pattern     => 1,
                                                    ;probability => 0.7,
                                                    ;size        => 5
                                                ;gravity  => {
                                                    ;weight => 1,
                                                    ;vector => [0, 0, -1]
                                                ;wind     => {
                                                    ;weight => 0.1
                                                ;random   => {
                                                    ;weight => 0.3
                                                ;adhesion =>{
                                                    ;max_adhesion_distance => 50,
                                                    ;weight                => 0.2
                                                ;legacy   => {
                                                    ;weight => 0.8
                                    The default settings as extracted from the code.
                                    Now you do some work resetting your values manually... 😐
                                      No worries. 😉
                                      • RomBR Offline
                                        RomB
                                        sorry for my english at first. not my native - in russian i mean that this option will be very usefull. and of course thanks for that plugin. sorry if i offend somehow someone of developers. sorry please
                                        ps. in russian it's a little bit more words need to be said of simple -you need to make-
                                        • RomBR Offline
                                          RomB
                                          still not on the wall ((( picture above. where's my mistake?
                                            I don't even have this tool installed !
                                            The default adhesion seems to be 50 in the code I posted...
                                            Why is yours 0.2 [20?] ??
                                            Presumably the higher the adhesion value the more it sticks to the wall ???
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 36
                                            • 37
                                            • 18 / 37
