    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 511.0k Views 172 Watching
    • OxerO
      Oxer
      Hi Rombout,
      I use Sketchup 8 on Mac and Sketchupivy 0.6beta works fine for me, you can see this video on You Tube http://www.youtube.com/embed/RGV8jU9HK_Y
      If you want i send you the plugin again.
      Usually SketchyPhisics3 plugin gives errors and conflicts with other plugins like shape_bender.rb, round_corner.rb, Extrude Tools and others
      perhaps with Sketchupivy too, have you installed SketchyPhisics3?
      • charly2008C
        charly2008
        I've recently experimented a bit to produce a Wisteria. Unfortunately I was not so successful. Then I have reinstalled the "0.63 beta". The result is now that no Ivy texture appears and Wisteria leaves also still appears. What is wrong?
        Charly
        • romboutR
          rombout
          I do have a couple of those installed as well. But I think it due to the sketchy physics, I installed this lately and before that it was always working. But I got it to work again after changes to lines of code (see tomasz's tips) there's one doneside on that. I hardly renders leaves know!? So I think I need to take a closer look now.
          What's also weird is that io never got your version to work in iether su7 or 8, I would only work in su6.
            driven
            Charley,
            are the Materials showing up in the browser when you launch Ivy?
            and does the script have Tigs mod??
            • charly2008C
              charly2008
              Hi John,
              no, only the material for the tribe. Yes I have installed the "TIG mod".
                driven
                did you try it without the mod... john
                • charly2008C
                  charly2008
                  John,
                  yes i did. I have looked again at the contents of the texture folder (see pictures below). Can it be that something is missing here?
                  SKP-Files
                  Texture Files
                    driven
                    I think it's to do with the image file name, I remember re-naming a complete set to replace the originals when I was playing with it.
                    early in the thread someone supplied a modified Textures folder [with different leafs], maybe look at that...
                    • charly2008C
                      charly2008
                      John,
                      I've tried the modified folder but no change. Even if the textures folder was deleted, wisteria, and ivy leaves appear the same. I do not understand, this is crazy!
                      Charly
                      Textures Folder deleted
                      • charly2008C
                        charly2008
                        Dear members,
                        I need an idea from you. How can I eliminate this material Wisteria? I've searched the entire hard disk, but these "Wisteria.png" is nowhere to be found. But these png must be stored somewhere. I feel like a beginner.
                        Charly
                        • charly2008C
                          charly2008
                          Problem solved. The png was saved in my template.
                          • charly2008C
                            charly2008
                            I give it up now. Now the plugin is working again. But now some leaves are again transparent and others not. I probably do not understand the workings of this plugin. I'll wait for an update. 😢
                            Charly
                            • romboutR
                              rombout
                              Charly
                              THat's due to the prob that 2 images arent transparent png's open these to in a image editor and make them transparent and than re-import them into SU
                              • charly2008C
                                charly2008
                                Hi Rombout,
                                Thanks for your answer. I have converted the jpg to png. I do not know if I've done anything wrong. I have attached the pngs below. If you watch it once I would be grateful.
                                Charly
                                  You seem to be going round in circles.
                                  This zip containing the three adjusted SKPs [and PNGs] that have hidden edges and already use proper transparent PNG files...
                                  Replace those in the Textures folder...
                                  Retry...IvyTexturesSKPs.zip
                                  • charly2008C
                                    charly2008
                                    TIG,
                                    I do not know how I can thank you. Sometimes you appear to me like the Robin Hood of the forum.
                                    Charly
                                    • RomBR
                                      RomB
                                      you need to make reset button. i have made a lot of changes in numbers...and now my ivy don't grow on a wall, it grows in every direction...please can someone share default settings?
                                        @romb said:
                                        you need to
                                        Did you mean, "it would be nice with" or "Could you please"? 😉
                                        Just saying, the wording can make a difference. Making freeware stuff and you end up with lots of demands from your users, it can get a bit tiresome. (Spoken by someone who makes lots of freeware.)
                                          hsh = {
                                                      ;branch   => {
                                                          ;nodesize    => 3,
                                                          ;pattern     => 0.8,
                                                          ;probability => 0.97,
                                                          ;radius      => 0.8,
                                                          ;floatlength => 150,
                                                          ;detail      => 4,
                                                          ;spread      => 0
                                                      ;leaf     => {
                                                          ;pattern     => 1,
                                                          ;probability => 0.7,
                                                          ;size        => 5
                                                      ;gravity  => {
                                                          ;weight => 1,
                                                          ;vector => [0, 0, -1]
                                                      ;wind     => {
                                                          ;weight => 0.1
                                                      ;random   => {
                                                          ;weight => 0.3
                                                      ;adhesion =>{
                                                          ;max_adhesion_distance => 50,
                                                          ;weight                => 0.2
                                                      ;legacy   => {
                                                          ;weight => 0.8
                                          The default settings as extracted from the code.
                                          Now you do some work resetting your values manually... 😐
                                            No worries. 😉
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 36
                                            • 37
                                            • 18 / 37
