    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 511.0k Views 172 Watching
      hsh = {
                  ;branch   => {
                      ;nodesize    => 3,
                      ;pattern     => 0.8,
                      ;probability => 0.97,
                      ;radius      => 0.8,
                      ;floatlength => 150,
                      ;detail      => 4,
                      ;spread      => 0
                  ;leaf     => {
                      ;pattern     => 1,
                      ;probability => 0.7,
                      ;size        => 5
                  ;gravity  => {
                      ;weight => 1,
                      ;vector => [0, 0, -1]
                  ;wind     => {
                      ;weight => 0.1
                  ;random   => {
                      ;weight => 0.3
                  ;adhesion =>{
                      ;max_adhesion_distance => 50,
                      ;weight                => 0.2
                  ;legacy   => {
                      ;weight => 0.8
      The default settings as extracted from the code.
      Now you do some work resetting your values manually... 😐
        No worries. πŸ˜‰
        • RomBR
          RomB
          sorry for my english at first. not my native - in russian i mean that this option will be very usefull. and of course thanks for that plugin. sorry if i offend somehow someone of developers. sorry please
          ps. in russian it's a little bit more words need to be said of simple -you need to make-
          • RomBR
            RomB
            still not on the wall ((( picture above. where's my mistake?
              I don't even have this tool installed !
              The default adhesion seems to be 50 in the code I posted...
              Why is yours 0.2 [20?] ??
              Presumably the higher the adhesion value the more it sticks to the wall ???
              • RomBR
                RomB
                that's it ) maybe i know english - but no so good till that time. and 0.5 become working not from next ivy, from third. But problem is solved - thx. better to rename adhesion to -sticking- πŸ˜„ fo rus users
                • RomBR
                  RomB
                  it won't work properly again, with -adhesion- 0.5 it's still grow in every direction. what's wrong with me? please help me to understand.
                  ps. it's skp file in archive, my model in wich ivy goes crazy. maybe problem it it?
                  Land_Mass_2_test_2.rar
                  • Z
                    zick
                    wow πŸ‘
                    • iichiversiiI
                      iichiversii
                      Wow Ivy Generator is great, but im having a problem importing the file back into SU, i can export my model from SU into Ivy Gen but when i import it to SU it freezes SU and never recovers, im using free version of SU and using obj importer, any suggestions would be great
                      Bring on the Rain...
                      • F
                        farmerjoe50
                        I dropped file into plugins folder but it is not showing up in sketchup...I noticed the file is .rar, not a rb file. What is the secret?
                          Doh!
                          A .rar file is a compressed file - like a .zip file - just made by another application.
                          So, like with a zip file you must extract its contents - i.e. the .rb file and intact subfolder[s] of miscellaneous files that then go into the Plugins folder.
                          There's a sticky-post in the Plugins Forum about installing tools from zip files - read that - substituting 'rar' when it says 'zip'...
                          πŸ˜‰
                          • F
                            farmerjoe50
                            momentary lapse of reason....got it.
                            • V
                              Vicspa
                              I tried all 3 versions, none worked properly, but after reading all 25 pages of forum, and about an hour and a half of loading and re-loading plugins, it's FINALLY working well for me, hope it stays that way. Rendering in Thea,
                              but the alpha channels do not import, but no big deal, I do it manually, and renders just fine.
                              Thank you Pierreden.
                              • bigstickB
                                bigstick
                                I didn't have your patience to get it to work. I did install it and the dialog worked fine. It just didn't seem to 'grow' the ivy, and it's not like I didn't check the installation and read up about it. The reality is that I didn't need the functionality enough to put the time and effort in.
                                The frustrating thing is that it looks like a really excellent plugin, but it needs sorting out before it's ready for most users.
                                If a lot of people have to make a considerable effort to get it working after 25 pages of posts, it shows that more work is necessary.
                                Sorry - I don't mean any criticism or disrespect to the author in the slightest, it seems to be a wonderful plugin and the effort you have made is very much appreciated!
                                • V
                                  Vicspa
                                  I hear you Bigstick, it seems to be working on/off and can get frustrating, but it promises to be a great plugin, and I hope all the bugs will be worked out.
                                  • bigstickB
                                    bigstick
                                    Agree 100%, I really hope these niggles can be fixed, because for lots of users it will be a 'must have'! The only reason I haven't persisted more is time unfortunately. All my spare time is taken up with SUPodium, and I would love to get the two to work together nicely.
                                    Actually this could be the basis of a tree/plant generator, to make any kind of plant. Huge undertaking though I suspect...
                                    • irwanwrI
                                      irwanwr
                                      πŸ‘ i totally agree on that opinion, bigstick.
                                      at least from the description and exhibits showing what it might capable of.
                                        I'm using sketchup 8
                                        The leaf size outcome look nice at sketchup
                                        but everytime i render, it become standard value size (5)
                                        anyone can help me with this issue ?
                                        Many thanks
                                        • C
                                          cmuhleman
                                          Great looking plugin. This would be immensely practical for a few projects i've got sitting around.
                                          I gave the 0.6.3 and also the last stable version a try on my mac and can't seem to get it to work. I'm running Sketchup 8.0.11751 on a Mac.
                                          I'm having a similar issue to bigstick. It's creating the paths and generating spots for leaves, but wont actually create the volumes.
                                          Keep up the good work! This one's a winner.
                                          • irwanwrI
                                            irwanwr
                                            I just realised that this plugin put components into a model right away after sketchup started.
                                            Does it meant to work that way?
                                            Found Ivy's components in the comp browser when I check it. After seeing how a door model file size became around more than 1 MB.
                                            Still learning to use this plugin.
                                            Thank you Pierre
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 36
                                            • 37
                                            • 19 / 37
