    SketchUp 8 M2 is out!
    157 Posts 49 Posters 53.4k Views 49 Watching
    • opalO
      opal
      Another user with the greyed out menu items here.
      I drew a basic rectangle an as usual it surfaced backface up so I right clicked and the option to reverse faces is greyed out.
      Using the drop down edit menu, selecting the same face, reverse faces is no longer greyed out.
      .. interesting to note, I did nothing to change any settings anywhere - thought gee.. I should go get some screen shots since there were other greyed down items on the edit list and it seemed to have fixed itself.. until I drew another basic rectangle and tried again to right click.
      Using the drop down edit menu instead of right click seems to fix it.. odd
      I know.. I should be in the newbie forum
        You have too many Plugins loading that are making 'Commands' - an issue reported in several other threads... and awaiting Google's fix ๐Ÿ˜ฎ
        • opalO
          opal
          ty, I read this thread and saw it was somehow plugin related. I thought it was interesting that using the drop down menu to access those commands made them work and might be a useful bit of information.
          • KrisidiousK
            Krisidious
            as I said before guys... this is a perfect opportunity to start fresh with a new plugin folder. that means installing each plugin fresh 1 at a time and checking to make sure it's up to date. and while your at it look for redundant plugins and outdated ones. chances are this will fix most of your greyed out issues.
            I don't think we've come up with a number of plugins where it reaches greyed out by bloat. it will happen at some point but I'm not sure at what number of plugins.
            By: Kristoff Rand
            • jbacusJ
              jbacus
              @jgb said:
              Can I simply install M2 or do I need to install M1 first โ“
              No- SU8M2 does not require that you install M1 first.
              "...exaggerate the essential and leave the obvious unclear." --Vincent Van Gogh
              John Bacus
              jbacus@sketchup.com
              • jbacusJ
                jbacus
                I think it might help us to troubleshoot if those of you experiencing the grayed-out context menus could give us a sense of (how many total and which ones specifically) the plugins you have installed.
                John Bacus
                jbacus@sketchup.com
                • T
                  tspco
                  Not impressed, went back to older version. My terrains don't move as nicely, really hammers my computer. SP animations are about half or less speed, than they used to be. So until I find out what I need to do I will not use it.
                  SU make 2017, /Twilight Render Hobby
                  Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                  • opalO
                    opal
                    Where should we send that list?
                    • Bob JamesB
                      Bob James
                      Here you go, John.
                      146 Plugins
                        mukul.ar
                        @tig said:
                        jbacus...
                        Indeed... ๐Ÿ˜ฒ
                        I do have a vague 'plan' [when time allows!] to 'Extensionalize' my main scripts and then offer .zip/.rbz versions for alternative installation... if you have v8+++...
                        Thereby, up-to-date Users can install the updated tools via Preferences - but it needs considerable [unpaid] effort on my part...
                        AND there are many 'legacy' Users who will still need the .zip version...
                        ๐Ÿ˜ฒ
                        Is this google's way to take away rubies too from the free sketchup version? I believe this new way to install rubies is available only in M2 (pro version)?
                        My Works
                        • jeff hammondJ
                          where are you getting that impression from?
                          • jeff hammondJ
                            @bob james said:
                            Here you go, John.
                            146 Plugins
                            i don't think anybody can really read that ๐Ÿ˜„
                            (that said, i think you might want to reconsider how you're dropboxing those.. why not sync the actual plugin folder instead of each individual file?)
                            • jbacusJ
                              jbacus
                              Extension installation and the accompanying changes to the Ruby API are equally available to both Free and Pro users of SketchUp 8 M2.
                              John Bacus
                              jbacus@sketchup.com
                              • jbacusJ
                                jbacus
                                Thanks- this will really help us figure out what is going on. You might just post it here, if you don't mind doing that. Alternately, you can PM Tricia for alternatives.
                                John Bacus
                                jbacus@sketchup.com
                                  mukul.ar
                                  @Jeff: I was just clarifying whether the new way to install plugins was the way forward for sketchup in general or just for sketchup pro...
                                  @jbacus: Thankyou for clarifying ๐Ÿ‘ This may be out of topic, but is the google team working on a sketchup that is able to handle more geometry (heavier models)? Because that would be the only push I'd need to go pro... Its not every day I get to interact with the developing team so... Thankyou for this great piece of software... ๐Ÿ˜„
                                  My Works
                                    For the mix here are my own plugin/extension/toolbar stats...
                                    Plugins:
                                    Loading:
                                    RB 297
                                    RBS 9
                                    Disabled:
                                    RB! 327
                                    RBS! 11
                                    This can never be entirely correct as several scripts will/won't load other files from within subfolders, but it's a reasonable indication of numbers...
                                    Scripts within 'Tools' are also not included above [there are 13 of these loading].
                                    Extensions:
                                    Active 18
                                    Inactive 16
                                    Toolbars:
                                    Active 46
                                    Inactive 13
                                    I load/activate them as needed.
                                    Obviously I have almost every script known to man, and some unknown, as I have several 'under development' at any one time...
                                    But I get no gray-out menus with this current 'set'.
                                    Many plugins do produce a lot of 'commands' to overwhelm Sketchup's capacity, but I find this is just below that fatal limit...
                                    However, if I activate too many more complex extras then random gray-outs do occur...
                                    • opalO
                                      opal
                                      my list is huge.. really.
                                      goes looking for a Tricia on the board somewhere to send a PM
                                      • GaieusG
                                        Here...
                                        • opalO
                                          opal
                                          Found her already, thanks ๐Ÿ˜„
                                            Have you checked if Hardware Acceleration has become disabled for some reason?
                                            • 4 / 8
