    SketchUp 2 Layout - very poor resolution
    28 Posts 9 Posters 10.1k Views 9 Watching
    • T
      tim
      That's certainly not the sort of output I get; it looks like you're a Windows guy so maybe it's some detail of the video driver version/preferences/settings/bug ? It seems there are plenty of things that can go wrong in that area.
      • GaieusG
        What rendering method are you using? Raster will not take you too far. With image textures, I would suggest hybrid.
        • utilerU
          utiler
          Thanks guys, I have rendered 'shaded view with textures' then Hybrid mode. I'm now trying straight shaded view and Vector mode.... Will see how it goes...
          Just Curious...
          • utilerU
            utiler
            SO here's Vector mode... the actual section cut seems to be removed whic is not good. everything else is goo though....
            Not sure what to do about the section cut. Its set at 3 in styles....
            Just Curious...
            • GaieusG
              Use hybrid mode. Although unfortunately the section cut won't "vectorize" so in hybrid mode you may end up with sharp lines everywhere except your cut line. Or use TIG's section cut face plugin. What it does is:
              1. Adds a group at the slice (like the native SU tool)
              2. Moves it a bit back (so the section plane won't just hide it)
              3. Fills the faces.
                Now by adding a group of edges all around there (and moving them to the visible area), you will end up with real geometry that can be vectorized and even you can infer to it with the LO dimension tool so you can dimension from your cuts.
              • EdsonE
                Edson
                I have never had any resolution problems on mac.
                http://www.mahfuz.arq.br
                • B
                  bjanzen
                  Can you share the LayOut document? Also, take that scene and export to PDF in SketchUp, which will do the same thing (vector render) as LayOut. You can also try re-rendering in raster, then vector and see if anything is fixed.
                  b
                  • utilerU
                    utiler
                    Thanks guys,
                    @Barry - This LO file and SKP file are very large so its a little hard to post. [21mb] but I'll use the model of my office to show you. 👍
                    @ Csaba - I do use Section Cut Face all the time but still the issue remains. See the PDF attached:
                    4 examples with Shaded View / Hidden Line view and showing / not showing the section cut face....
                    stylestest.pdf
                    Just Curious...
                      What is the size of the document in Layout, and what size do you print it in?
                      If you have a A4 page and print it A3 or A2 or larger you will find it being low quality even if you have High quality when exporting.
                      For a model where I needed really fine details printed in A3 I made the Layout page A1 - effectively giving me double the quality.
                      • utilerU
                        utiler
                        No thom, its not a print resolution problem. If I export models to A3 i print A3; same, same for A4...
                        Just Curious...
                        • jeff hammondJ
                          dunno, i think your problem is from something other than how layout is exporting.. whatever you're doing/using to view/print the pdf seems to be rasterizing it at a certain resolution then enlarging it?
                          here's a screenshot how your pdf looks on my system after zooming in a bazillion %
                          zoomed in on one seat (Click on picture for actual size of my screenshot)
                          (unless of course, the pdf you posted was meant as an example of something other than the initial problem you spoke of 😕 ❓ )
                          • utilerU
                            utiler
                            This thread has moved a little off what I originally posted about although it has dug a fair bit into the issue.
                            Here is a screenshot zoomed in of the PDF with raster images. It appears that for any linework you want to appear within any drawing standard you will need to either use Vector or Hybrid. The problem however is when your file size is large LO just seems to hang forever!!!!
                            To give you an idea of the actual zoom scale of this image; it is an A3 site plan at 1:2000. Dimensions are 2.5mm high so as you can see as lines become more acute to the horizontal / vertical they splinter.... not good.
                            Jeff, your zoomed in image is a good example of if you reduce your Styles line weight in LO [Vector mode] you can achieve crisp lines. The obvious problem though is Section cuts turn white which makes the whole process useless.... [for plan / section drawings...]
                            Just Curious...
                            • jeff hammondJ
                              are you sure you don't have the section cut color set to white for the SU style? [EDiT - but i guess if you had it set that way, the cut lines would be white in sketchup as well..]
                              i don't have a problem using section cuts in layout.. see attached example:
                              A3 paper exported at medium quality PDF… Hybrid rendering mode
                              (but then again, i missed your point the first time around so maybe i'm missing something again 😄 )
                              that's another thing i'm not getting.. i'm pretty sure my cuts are vectors in hybrid/vector
                              • utilerU
                                utiler
                                No Jeff, Section cuts are set to black. 👍
                                So you're on Mac right? Not sure why I'm getting result this out of PC... Csaba, You're on PC; do you get the same result as I do? Maybe this is a disparity between PC & Mac.
                                Thanks for taking the time to compare, Jeff and everyone... 👍
                                Just Curious...
                                • GaieusG
                                  Can you share that file, Andrew (or at least PM)
                                  • utilerU
                                    utiler
                                    Hi Csaba, PM me your email address and I'll forward via 'yousendit'... a little larger than allowed here....
                                    you too Jeff if you like.
                                    Cheers, guys.
                                    Just Curious...
                                    • GaieusG
                                      Okay, so I can confirm that both in hybrid and vector mode, the section cut edges turn from black to white. Nothing seems to help: I tried changing the background colour just a little bit less white, the section cut colour just a bit less black - nothing.
                                      Sorry Andrew.
                                      • utilerU
                                        utiler
                                        No worries, Csaba. thanks for trying it out and confirming what I thought.
                                        Just Curious...
                                        • jeff hammondJ
                                          hey Andrew..
                                          utiler_export.pdf
                                          little jpg shot…corresponding PDF download above.. A3 - medium output - hybrid
                                          so i think it's something to do with your section plane being inside a group in the sketchup model..
                                          here's what i did to get the section planes working in layout:
                                          (in sketchup)
                                          **--**make section planes visible (view -> section planes)
                                          now, notice when you click on the plane in question, it turns solid blue since it's inside a group.. it seems like this is contributing to the error in layout..
                                          -- enter the group containing the plane then select the plane
                                          -- Cut (ctrlX on windows?) or (edit -> cut)
                                          -- exit the group
                                          -- Edit -> paste in place
                                          continue as normal..
                                          putting the section plane outside the group fixed the problem in layout.
                                          • GaieusG
                                            Nice Jeff. However sometimes one would like to keep the section inside a group (say when you want to have serval active cuts)
