    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 313.7k Views 172 Watching
    • romboutR Offline
      rombout
      I do have a couple of those installed as well. But I think it due to the sketchy physics, I installed this lately and before that it was always working. But I got it to work again after changes to lines of code (see tomasz's tips) there's one doneside on that. I hardly renders leaves know!? So I think I need to take a closer look now.
      What's also weird is that io never got your version to work in iether su7 or 8, I would only work in su6.
        driven
        Charley,
        are the Materials showing up in the browser when you launch Ivy?
        and does the script have Tigs mod??
        • charly2008C Offline
          charly2008
          Hi John,
          no, only the material for the tribe. Yes I have installed the "TIG mod".
            driven
            did you try it without the mod... john
              charly2008
              John,
              yes i did. I have looked again at the contents of the texture folder (see pictures below). Can it be that something is missing here?
              SKP-Files
              Texture Files
                driven
                I think it's to do with the image file name, I remember re-naming a complete set to replace the originals when I was playing with it.
                early in the thread someone supplied a modified Textures folder [with different leafs], maybe look at that...
                  charly2008
                  John,
                  I've tried the modified folder but no change. Even if the textures folder was deleted, wisteria, and ivy leaves appear the same. I do not understand, this is crazy!
                  Charly
                  Textures Folder deleted
                    charly2008
                    Dear members,
                    I need an idea from you. How can I eliminate this material Wisteria? I've searched the entire hard disk, but these "Wisteria.png" is nowhere to be found. But these png must be stored somewhere. I feel like a beginner.
                    Charly
                      charly2008
                      Problem solved. The png was saved in my template.
                        charly2008
                        I give it up now. Now the plugin is working again. But now some leaves are again transparent and others not. I probably do not understand the workings of this plugin. I'll wait for an update. 😢
                        Charly
                        • romboutR Offline
                          rombout
                          Charly
                          THat's due to the prob that 2 images arent transparent png's open these to in a image editor and make them transparent and than re-import them into SU
                            charly2008
                            Hi Rombout,
                            Thanks for your answer. I have converted the jpg to png. I do not know if I've done anything wrong. I have attached the pngs below. If you watch it once I would be grateful.
                            Charly
                              You seem to be going round in circles.
                              This zip containing the three adjusted SKPs [and PNGs] that have hidden edges and already use proper transparent PNG files...
                              Replace those in the Textures folder...
                              Retry...IvyTexturesSKPs.zip
                                charly2008
                                TIG,
                                I do not know how I can thank you. Sometimes you appear to me like the Robin Hood of the forum.
                                Charly
                                • RomBR Offline
                                  RomB
                                  you need to make reset button. i have made a lot of changes in numbers...and now my ivy don't grow on a wall, it grows in every direction...please can someone share default settings?
                                    @romb said:
                                    you need to
                                    Did you mean, "it would be nice with" or "Could you please"? 😉
                                    Just saying, the wording can make a difference. Making freeware stuff and you end up with lots of demands from your users, it can get a bit tiresome. (Spoken by someone who makes lots of freeware.)
                                      hsh = {
                                                  ;branch   => {
                                                      ;nodesize    => 3,
                                                      ;pattern     => 0.8,
                                                      ;probability => 0.97,
                                                      ;radius      => 0.8,
                                                      ;floatlength => 150,
                                                      ;detail      => 4,
                                                      ;spread      => 0
                                                  ;leaf     => {
                                                      ;pattern     => 1,
                                                      ;probability => 0.7,
                                                      ;size        => 5
                                                  ;gravity  => {
                                                      ;weight => 1,
                                                      ;vector => [0, 0, -1]
                                                  ;wind     => {
                                                      ;weight => 0.1
                                                  ;random   => {
                                                      ;weight => 0.3
                                                  ;adhesion =>{
                                                      ;max_adhesion_distance => 50,
                                                      ;weight                => 0.2
                                                  ;legacy   => {
                                                      ;weight => 0.8
                                      The default settings as extracted from the code.
                                      Now you do some work resetting your values manually... 😐
                                        No worries. 😉
                                        • RomBR Offline
                                          RomB
                                          sorry for my english at first. not my native - in russian i mean that this option will be very usefull. and of course thanks for that plugin. sorry if i offend somehow someone of developers. sorry please
                                          ps. in russian it's a little bit more words need to be said of simple -you need to make-
                                          • RomBR Offline
                                            RomB
                                            still not on the wall ((( picture above. where's my mistake?
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 34 / 37
