    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 511.0k Views 172 Watching
    • romboutR
      rombout
      Hi tomasz,
      on the mac the popup window of ivy generator shows and than immediately hides again on the mac, su6 and 7
      Here's the code from SU7
      Error; #<NoMethodError; undefined method `to_array' for Pdn;;LiveIvy;;Parameters;Module>
      /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb;58;in `register_callbacks'
      /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb;58;in `call'
      • romboutR
        rombout
        @oxer said:
        @rombout said:
        how come for a lot of peeps the 0.6.3 versiion does work?
        on the mac i doesnt do anything, no feedback no nothing?! 😲
        Hi Rombout,
        Try this version, works for me on Mac OSX 10.6.7 and SU 8.
        Keys on Mac:
        Click where you want the Ivy to start grow.
        Cmd+Click : Make the ivy grow towards the mouse position.
        Alt+Click : Grow Ivy leafs.
        SHIFT+Click : Finish Ivy.
        Keyboard 'i' : Start over.
        [attachment=0:1xv8nygn]<!-- ia0 -->SketchupIvy.0.6.beta.zip<!-- ia0 -->[/attachment:1xv8nygn]
        He this version wont work no more for me any more. I did how ever did some updates on some plugins so think i need to do a reload step by step and see which one it is
        • OxerO
          Oxer
          Hi Rombout,
          I use Sketchup 8 on Mac and Sketchupivy 0.6beta works fine for me, you can see this video on You Tube http://www.youtube.com/embed/RGV8jU9HK_Y
          If you want i send you the plugin again.
          Usually SketchyPhisics3 plugin gives errors and conflicts with other plugins like shape_bender.rb, round_corner.rb, Extrude Tools and others
          perhaps with Sketchupivy too, have you installed SketchyPhisics3?
          • charly2008C
            charly2008
            I've recently experimented a bit to produce a Wisteria. Unfortunately I was not so successful. Then I have reinstalled the "0.63 beta". The result is now that no Ivy texture appears and Wisteria leaves also still appears. What is wrong?
            Charly
            • romboutR
              rombout
              I do have a couple of those installed as well. But I think it due to the sketchy physics, I installed this lately and before that it was always working. But I got it to work again after changes to lines of code (see tomasz's tips) there's one doneside on that. I hardly renders leaves know!? So I think I need to take a closer look now.
              What's also weird is that io never got your version to work in iether su7 or 8, I would only work in su6.
                driven
                Charley,
                are the Materials showing up in the browser when you launch Ivy?
                and does the script have Tigs mod??
                • charly2008C
                  charly2008
                  Hi John,
                  no, only the material for the tribe. Yes I have installed the "TIG mod".
                    driven
                    did you try it without the mod... john
                    • charly2008C
                      charly2008
                      John,
                      yes i did. I have looked again at the contents of the texture folder (see pictures below). Can it be that something is missing here?
                      SKP-Files
                      Texture Files
                        driven
                        I think it's to do with the image file name, I remember re-naming a complete set to replace the originals when I was playing with it.
                        early in the thread someone supplied a modified Textures folder [with different leafs], maybe look at that...
                        • charly2008C
                          charly2008
                          John,
                          I've tried the modified folder but no change. Even if the textures folder was deleted, wisteria, and ivy leaves appear the same. I do not understand, this is crazy!
                          Charly
                          Textures Folder deleted
                          • charly2008C
                            charly2008
                            Dear members,
                            I need an idea from you. How can I eliminate this material Wisteria? I've searched the entire hard disk, but these "Wisteria.png" is nowhere to be found. But these png must be stored somewhere. I feel like a beginner.
                            Charly
                            • charly2008C
                              charly2008
                              Problem solved. The png was saved in my template.
                              • charly2008C
                                charly2008
                                I give it up now. Now the plugin is working again. But now some leaves are again transparent and others not. I probably do not understand the workings of this plugin. I'll wait for an update. 😢
                                Charly
                                • romboutR
                                  rombout
                                  Charly
                                  THat's due to the prob that 2 images arent transparent png's open these to in a image editor and make them transparent and than re-import them into SU
                                  • charly2008C
                                    charly2008
                                    Hi Rombout,
                                    Thanks for your answer. I have converted the jpg to png. I do not know if I've done anything wrong. I have attached the pngs below. If you watch it once I would be grateful.
                                    Charly
                                      You seem to be going round in circles.
                                      This zip containing the three adjusted SKPs [and PNGs] that have hidden edges and already use proper transparent PNG files...
                                      Replace those in the Textures folder...
                                      Retry...IvyTexturesSKPs.zip
                                      • charly2008C
                                        charly2008
                                        TIG,
                                        I do not know how I can thank you. Sometimes you appear to me like the Robin Hood of the forum.
                                        Charly
                                        • RomBR
                                          RomB
                                          you need to make reset button. i have made a lot of changes in numbers...and now my ivy don't grow on a wall, it grows in every direction...please can someone share default settings?
                                            @romb said:
                                            you need to
                                            Did you mean, "it would be nice with" or "Could you please"? 😉
                                            Just saying, the wording can make a difference. Making freeware stuff and you end up with lots of demands from your users, it can get a bit tiresome. (Spoken by someone who makes lots of freeware.)
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 36
                                            • 37
                                            • 18 / 37
