    1.5k Posts 478 Posters 4.3m Views 478 Watching
      rollerhaus
      Fredo, you're a God-send! Thank you so much. One question for you...is there a way to map textures to the curves or have it to use already placed maps? It doesn't seem to like image maps πŸ˜•
      • fredo6F
        Do you have an example to illustrate it?
          rollerhaus
          Voila! Obviously not a real-world example but it's easier to understand the issue vs. if had i shown wood. Not sure if there's a way around this though given SU's limited texture/uvw functionality...
            stoneshawnp
            @stoneshawnp said:
            Thanks TIG. I am learning a bit more about the Architecture here.
            I renamed my Plugin's directory & created a new empty one.
            Then I started re-installing the Plugin's 1-by-1, and so far RoundCorners as such, is working again.
            When (if) i figure out the offending Plugin, I will post it here.
            Thanks for helping a Newbie! πŸ˜‰
            Small Update...
            I went through 1-by-1 and re-installed every plugin I have until I found the conflict with RoundCorners.. It seem to be the Ledas Driving Dimensions (http://forums.sketchucation.com/viewtopic.php?f=80&t=13808&hilit=ledas+driving+dimension or otherwise http://drivingdimensions.com/. When I disable this plugin, my "BugSplats" with RoundCorners disappear.
            ... Great Forum! also very interested to see the feedback to the Texture question just posted πŸ˜‰
              I have already told the Driving Dimensions author [Dmitry Ushakov] about the conflicts the tool has with other plugins about a month ago - the faults are on his side because he messes with base class/methods... It seemed OK in v8, but v7 was causing problems with a few tools [similar to SketchyPhysics] - but your problem occurs in v8 ? ...
              πŸ˜’
                stoneshawnp
                πŸ˜’
                Yes. Problem occurs in SU Pro 8 (installed on both Windows XP & Windows 7 machines).
                Thx
                Shawn
                  JAI GOEL
                  i am using google sketchup 8 i am not able to use this plugin in 8 version. how can i install that??
                  thx
                    Have you installed it as the instructions, with the supporting files etc, as explained on the download page ?
                    If so why can't you 'use it'?
                    Do you get Preferences>extension_to_activate/menu_items/view>toolbar>toolbar?
                    Do you get error messages when using it?
                    Do you get error messages in the Ruby Console when using it?
                    Please give more details, to help us help you...
                    • P
                      Pitoon
                      how can i get the icons back up...i closed them by accident? .......been trying for half an hour where to find them?
                      thanks!
                      • GaieusG
                        If that's the plugin toolbar you closed, you can reactivate it from the View > Toolbars menu.
                        • G
                          greatoe
                          I have problem running RoundCorner on my mac with OSX 10.7.2.
                          Everything was fine on OSX 10.6.x, but after I "upgrade" to 10.7, RoundCorner hangs on processing. I have to force quit Sketchup.
                          The following images are screen shots when RoundCorner hangs.
                          RoundCorner v2.2, LibFredo6 v3.6, Sketchup Pro 8, Mac OSX Lion 10.7.2
                          RoundCorner v2.3, LibFredo6 v3.7 or v4.2 (both act same), Sketchup Pro 8, Mac OSX Lion 10.7.2
                          • fredo6F
                            greatoe
                            I'll have to count on Mac users to tell if they have this problem too (I don't have OSX Lion).
                            Just in case, can you open the Ruby Console before launching RoundCorner, in case you see some messages before Sketchup hangs.
                            • G
                              greatoe
                              greatoe
                              Hi Fredo,
                              Thanks for the reply.
                              Nothing show up in the Ruby Console.
                              greatoe
                                aea
                                hay
                                • massimoM
                                  massimo Moderator
                                  This is a possible workflow with SU's native tools supposing you already have a cone as a start.
                                    aea
                                    thanks , Another problem I found here
                                    • GaieusG
                                      From the picture it seems that those diagonals could be safely deleted. Try to run the plugin after that.
                                      • fredo6F
                                        @aea said:
                                        hay
                                        For rounding the tip of a cone, I suggest you use Massimo's method.
                                        With RoundCorner, you can do the rounding, but:
                                        1. you need to make the edges plain (i.e. non soft, non smooth)
                                        2. the edges will be themselves rounded, which won't leave the surface of the cone smooth.
                                        RoundCorner_Cone.gif]
                                        • GaieusG
                                          Also, for the cone, you can truncate the tip and apply round corner only on the top circle. It's a bit of a fiddling around what settings to use but the result will be fine.
                                          before
                                          after (hidden edges displayed)
                                          • W
                                            WRipley
                                            thanks for this great Plugin.
                                            But i have a problem.
                                            I have a structure buil also with holes.
                                            When i round the corners of the whole structure it closes
                                            my holes on the side where i pushed the form thru the material.
                                            I hope you know what i mean.
                                            When i make a hole i start makin a circle on the Material.
                                            Then i push the Circle thru the material that i get a hole.
                                            Wehen i then try to round the corners the hole is on one side closed.
                                            On the other side not.
                                            Maybe it depends on me.
                                            Or do you know that problem.
                                            Thanks in advance
                                            Best
                                            Walter
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 74
                                            • 75
                                            • 23 / 75
