    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 312.8k Views 172 Watching
    • romboutR Offline
      rombout
      Hi tomasz,
      on the mac the popup window of ivy generator shows and than immediately hides again on the mac, su6 and 7
      Here's the code from SU7
      Error; #<NoMethodError; undefined method `to_array' for Pdn;;LiveIvy;;Parameters;Module>
      /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb;58;in `register_callbacks'
      /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb;58;in `call'
      • romboutR Offline
        rombout
        @oxer said:
        @rombout said:
        how come for a lot of peeps the 0.6.3 versiion does work?
        on the mac i doesnt do anything, no feedback no nothing?! 😲
        Hi Rombout,
        Try this version, works for me on Mac OSX 10.6.7 and SU 8.
        Keys on Mac:
        Click where you want the Ivy to start grow.
        Cmd+Click : Make the ivy grow towards the mouse position.
        Alt+Click : Grow Ivy leafs.
        SHIFT+Click : Finish Ivy.
        Keyboard 'i' : Start over.
        [attachment=0:1xv8nygn]<!-- ia0 -->SketchupIvy.0.6.beta.zip<!-- ia0 -->[/attachment:1xv8nygn]
        He this version wont work no more for me any more. I did how ever did some updates on some plugins so think i need to do a reload step by step and see which one it is
        • OxerO Offline
          Oxer
          Hi Rombout,
          I use Sketchup 8 on Mac and Sketchupivy 0.6beta works fine for me, you can see this video on You Tube http://www.youtube.com/embed/RGV8jU9HK_Y
          If you want i send you the plugin again.
          Usually SketchyPhisics3 plugin gives errors and conflicts with other plugins like shape_bender.rb, round_corner.rb, Extrude Tools and others
          perhaps with Sketchupivy too, have you installed SketchyPhisics3?
          • charly2008C Offline
            charly2008
            I've recently experimented a bit to produce a Wisteria. Unfortunately I was not so successful. Then I have reinstalled the "0.63 beta". The result is now that no Ivy texture appears and Wisteria leaves also still appears. What is wrong?
            Charly
            • romboutR Offline
              rombout
              I do have a couple of those installed as well. But I think it due to the sketchy physics, I installed this lately and before that it was always working. But I got it to work again after changes to lines of code (see tomasz's tips) there's one doneside on that. I hardly renders leaves know!? So I think I need to take a closer look now.
              What's also weird is that io never got your version to work in iether su7 or 8, I would only work in su6.
                driven
                Charley,
                are the Materials showing up in the browser when you launch Ivy?
                and does the script have Tigs mod??
                  charly2008
                  Hi John,
                  no, only the material for the tribe. Yes I have installed the "TIG mod".
                    driven
                    did you try it without the mod... john
                      charly2008
                      John,
                      yes i did. I have looked again at the contents of the texture folder (see pictures below). Can it be that something is missing here?
                      SKP-Files
                      Texture Files
                        driven
                        I think it's to do with the image file name, I remember re-naming a complete set to replace the originals when I was playing with it.
                        early in the thread someone supplied a modified Textures folder [with different leafs], maybe look at that...
                          charly2008
                          John,
                          I've tried the modified folder but no change. Even if the textures folder was deleted, wisteria, and ivy leaves appear the same. I do not understand, this is crazy!
                          Charly
                          Textures Folder deleted
                            charly2008
                            Dear members,
                            I need an idea from you. How can I eliminate this material Wisteria? I've searched the entire hard disk, but these "Wisteria.png" is nowhere to be found. But these png must be stored somewhere. I feel like a beginner.
                            Charly
                              charly2008
                              Problem solved. The png was saved in my template.
                                charly2008
                                I give it up now. Now the plugin is working again. But now some leaves are again transparent and others not. I probably do not understand the workings of this plugin. I'll wait for an update. 😢
                                Charly
                                • romboutR Offline
                                  rombout
                                  Charly
                                  THat's due to the prob that 2 images arent transparent png's open these to in a image editor and make them transparent and than re-import them into SU
                                    charly2008
                                    Hi Rombout,
                                    Thanks for your answer. I have converted the jpg to png. I do not know if I've done anything wrong. I have attached the pngs below. If you watch it once I would be grateful.
                                    Charly
                                      You seem to be going round in circles.
                                      This zip containing the three adjusted SKPs [and PNGs] that have hidden edges and already use proper transparent PNG files...
                                      Replace those in the Textures folder...
                                      Retry...IvyTexturesSKPs.zip
                                        charly2008
                                        TIG,
                                        I do not know how I can thank you. Sometimes you appear to me like the Robin Hood of the forum.
                                        Charly
                                        • RomBR Offline
                                          RomB
                                          you need to make reset button. i have made a lot of changes in numbers...and now my ivy don't grow on a wall, it grows in every direction...please can someone share default settings?
                                            @romb said:
                                            you need to
                                            Did you mean, "it would be nice with" or "Could you please"? 😉
                                            Just saying, the wording can make a difference. Making freeware stuff and you end up with lots of demands from your users, it can get a bit tiresome. (Spoken by someone who makes lots of freeware.)
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 36
                                            • 37
                                            • 12 / 37
