    [Plugin] Shell
    93 Posts 33 Posters 72.2k Views 34 Watching
      driven
      hi Thomas,
      would it be ok to change the menu name to 'tt_shell' as it needs to be unique to use a mac system shortcut key and Jim's simple shell uses 'shell' in the SU menu already...
      it also turned off all my other toolbars [except 'booleen helper' and SU ones] when I first loaded/ran it.
      never had that happen before...
      I'll do some testing tonight.
        You can edit line 40 to change the menu name.
        There is nothing in the plugin's code that modifies other toolbars. It doesn't even add one itself.
        Did it cause any errors when you loaded the first time?
          driven
          yes,
          it failed on one particular group and generated error messages, so I'd make something less something less complex, but I noticed all my toolbars had gone.
          I turned the same ones back on restarted SU, used tt_shell again and they were fine...
          I get non planar faces errors on things that JPP works on.
          I'll have a proper look later
            Can you give me a sample model?
              driven
              hi thomas,
              here's something similar that fails tt_skin, but works for JPP.
              the lavender one is jpp'd.
              Also, the disappearing toolbars are from TIG's new DAE exporter, which uses
              Sketchup.send_action('terminate:')
              which 'disappears' the toolbars and was the last thing that I had used before I installed this.
              tt_skin_test.skp
                Cheers for the model!
                • StinkieS Offline
                  Stinkie
                  OK, I'll ban you later πŸ‘
                  πŸ˜†
                  Thanks, Thomas!
                  • N Offline
                    nomeradona
                    this is the one im waiting for. I requested for this before but many keep on pointing joint push pull. thanks thomas..
                      jorge2011
                      Hi thom, This plugin generates a small error, you can fix that
                      Error: #<ArgumentError: Points are not planar>
                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:370:in add_face' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:370:in shell'
                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:362:in each' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:362:in shell'
                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:321:in offset_mesh' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:319:in each'
                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:319:in offset_mesh' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:173:in onReturn'
                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:420
                      • jeff hammondJ Offline
                        wow 😲
                        i missed this one..
                        gonna test it a little later tonight.
                        thanks thom
                          Ah, yea. There are bugs in this plugin. Hence the Alpha status of the version number. Though I've not had any time to work on it recently.
                            robert111
                            mr thomthom
                            when i make group for this form , i and i use shell plugin , i have this stroange message
                              That error message is not something I've put into Shell. I have no idea where it's coming from. Exactly what is the steps you do to produce that? (Can you also share the model along with the steps?)
                                j_forrester
                                Is it possible to shell but keep the return from the original geometry. I have tried with JPP too but seems to fall down when you try it with and opening with single extruded returns.
                                Many thanks
                                  The generated geometry is created in a separate group - if that is what you mean..?
                                    robert111
                                    i post my file and vedio for this bug
                                    bug00.rar
                                    shell bug.rar
                                      4.6MB for that.skp 😲
                                      one word:
                                      PURGE πŸ˜„
                                      model info -> statistics -> purge unused.
                                      gets it down to around 150kb
                                        Your SKP will shrink to almost nothing IF you use Model Info > Purge Unused...
                                        Then there's no need to zip/rar it and others will be more willing to look at it!
                                        You don't appear to understand the idea of what makes a 'solid'.
                                        An 8 sided box is a 'solid' - all edges have 2 faces - no more, no less.
                                        Your group group has only 4 faces and several edges with only one face... so it's not a 'solid'.
                                        Select two groups in turn and see what the Entity Info dialog says... make one as a 6 sided box [it says it's 'Solid'] and yours will not say it's 'solid' !
                                        Therefore you can't do 'solid' operations on your group - it's not a 'solid'!
                                          ... I'm confused ... you're getting the error when trying to use Solids Tools?
                                          Shell doesn't require solids...
                                          Can you explain step by step what you are doing? (What you click on etc.) Also, what are you trying to accomplish.
                                            robert111
                                            i make box and i deleted 02 faces and i have group it
                                            and after i click in this box and i click after shell plugin
                                            i have make video for my file can you see it
                                            the file video is shell bug.rar
                                            • 1 / 5
