    [Plugin] Shell
    93 Posts 33 Posters 72.2k Views 34 Watching
    • jeff hammondJ Offline
      wow ๐Ÿ˜ฒ
      i missed this one..
      gonna test it a little later tonight.
      thanks thom
        @jorge2011 said:
        Hi thom, This plugin generates a small error, you can fix that
        Ah, yea. There are bugs in this plugin. Hence the Alpha status of the version number. Though I've not had any time to work on it recently.
          robert111
          mr thomthom
          when i make group for this form , i and i use shell plugin , i have this stroange message
            That error message is not something I've put into Shell. I have no idea where it's coming from. Exactly what is the steps you do to produce that? (Can you also share the model along with the steps?)
              j_forrester
              Is it possible to shell but keep the return from the original geometry. I have tried with JPP too but seems to fall down when you try it with and opening with single extruded returns.
              Many thanks
                The generated geometry is created in a separate group - if that is what you mean..?
                  robert111
                  i post my file and vedio for this bug
                  bug00.rar
                  shell bug.rar
                    4.6MB for that.skp ๐Ÿ˜ฒ
                    one word:
                    PURGE ๐Ÿ˜„
                    model info -> statistics -> purge unused.
                    gets it down to around 150kb
                      Your SKP will shrink to almost nothing IF you use Model Info > Purge Unused...
                      Then there's no need to zip/rar it and others will be more willing to look at it!
                      You don't appear to understand the idea of what makes a 'solid'.
                      An 8 sided box is a 'solid' - all edges have 2 faces - no more, no less.
                      Your group group has only 4 faces and several edges with only one face... so it's not a 'solid'.
                      Select two groups in turn and see what the Entity Info dialog says... make one as a 6 sided box [it says it's 'Solid'] and yours will not say it's 'solid' !
                      Therefore you can't do 'solid' operations on your group - it's not a 'solid'!
                        ... I'm confused ... you're getting the error when trying to use Solids Tools?
                        Shell doesn't require solids...
                        Can you explain step by step what you are doing? (What you click on etc.) Also, what are you trying to accomplish.
                          robert111
                          i make box and i deleted 02 faces and i have group it
                          and after i click in this box and i click after shell plugin
                          i have make video for my file can you see it
                          the file video is shell bug.rar
                            Robert
                            As I tried to explain...
                            Shell and similar only only work if the group is a 'solid'.
                            An 6 sided box with no 'holes' is a 'solid'.
                            If you delete edges and/or faces then it is no longer a 'solid'.
                            The simple definition of a 'solid' group [or component] is that every edge in it has 2 faces attached to itself - but no more and no less...
                              No...
                              I will have a look at the sample video and see if I can understand what this whole is about.
                                Ah!
                                Now I understand what this all is about!
                                You're trying to use SketchUp Solid Tools's "Outer Shell" command - instead of "Shell" which is this plugin. I can see how you got confused.
                                  Aha! ๐Ÿ˜ฎ
                                  His video shows him trying to use [Outer] Shell on a non-solid object !
                                  ๐Ÿ˜’
                                    robert111
                                    mr TIG, thanks you for your reponse but i dont know how to make any form to solid form with sketchup, can you make video tutorial for this plugin plzzz
                                      See the responses on the previous page since your last visit: http://forums.sketchucation.com/viewtopic.php?f=323&t=39308&start=15#p365385
                                        No.
                                        If you do not grasp the concept of what a solid is how would showing you help?
                                        Most simple forms made by Sketchup like boxes and cylinders are 'solids'.
                                        When you add them together they can make internal partitions etc which need removing before it's considered to be a solid.
                                        Try my SolidSolver tool which attempts to turn non-solid groups into solids...
                                        However, your example of a 4 sided box could never be made a solid unless you add more faces/edge etc...
                                          But he doesn't need a solid at all. He simply confused the "Outer Shell" menu item for my "Shell" menu item.
                                            robert111
                                            thanks
                                            i confused the out shell with shell
                                            your plugin work perfect now
                                            thanks thomthom and thanks TIG too
                                            • 2 / 5
