    [Plugin] Shell
    93 Posts 33 Posters 74.1k Views 34 Watching
    • EarthMoverE
      EarthMover
      Looks interesting. Thanks Thom! πŸ‘
      Content Creator at Skapeup
      • utilerU
        utiler
        You're da bomb, Thom!!!!
        Have been feeling for your countrymen of late, mate.... πŸ‘
        Just Curious...
          driven
          hi Thomas,
          would it be ok to change the menu name to 'tt_shell' as it needs to be unique to use a mac system shortcut key and Jim's simple shell uses 'shell' in the SU menu already...
          it also turned off all my other toolbars [except 'booleen helper' and SU ones] when I first loaded/ran it.
          never had that happen before...
          I'll do some testing tonight.
            You can edit line 40 to change the menu name.
            There is nothing in the plugin's code that modifies other toolbars. It doesn't even add one itself.
            Did it cause any errors when you loaded the first time?
              driven
              yes,
              it failed on one particular group and generated error messages, so I'd make something less something less complex, but I noticed all my toolbars had gone.
              I turned the same ones back on restarted SU, used tt_shell again and they were fine...
              I get non planar faces errors on things that JPP works on.
              I'll have a proper look later
                Can you give me a sample model?
                  driven
                  hi thomas,
                  here's something similar that fails tt_skin, but works for JPP.
                  the lavender one is jpp'd.
                  Also, the disappearing toolbars are from TIG's new DAE exporter, which uses
                  Sketchup.send_action('terminate:')
                  which 'disappears' the toolbars and was the last thing that I had used before I installed this.
                  tt_skin_test.skp
                    Cheers for the model!
                    • StinkieS
                      Stinkie
                      OK, I'll ban you later πŸ‘
                      πŸ˜†
                      Thanks, Thomas!
                      • N
                        nomeradona
                        this is the one im waiting for. I requested for this before but many keep on pointing joint push pull. thanks thomas..
                          jorge2011
                          Hi thom, This plugin generates a small error, you can fix that
                          Error: #<ArgumentError: Points are not planar>
                          C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:370:in add_face' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:370:in shell'
                          C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:362:in each' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:362:in shell'
                          C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:321:in offset_mesh' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:319:in each'
                          C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:319:in offset_mesh' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:173:in onReturn'
                          C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:420
                          • jeff hammondJ
                            wow 😲
                            i missed this one..
                            gonna test it a little later tonight.
                            thanks thom
                              Ah, yea. There are bugs in this plugin. Hence the Alpha status of the version number. Though I've not had any time to work on it recently.
                                robert111
                                mr thomthom
                                when i make group for this form , i and i use shell plugin , i have this stroange message
                                  That error message is not something I've put into Shell. I have no idea where it's coming from. Exactly what is the steps you do to produce that? (Can you also share the model along with the steps?)
                                    j_forrester
                                    Is it possible to shell but keep the return from the original geometry. I have tried with JPP too but seems to fall down when you try it with and opening with single extruded returns.
                                    Many thanks
                                      The generated geometry is created in a separate group - if that is what you mean..?
                                        robert111
                                        i post my file and vedio for this bug
                                        bug00.rar
                                        shell bug.rar
                                        • jeff hammondJ
                                          4.6MB for that.skp 😲
                                          one word:
                                          PURGE πŸ˜„
                                          model info -> statistics -> purge unused.
                                          gets it down to around 150kb
                                            Your SKP will shrink to almost nothing IF you use Model Info > Purge Unused...
                                            Then there's no need to zip/rar it and others will be more willing to look at it!
                                            You don't appear to understand the idea of what makes a 'solid'.
                                            An 8 sided box is a 'solid' - all edges have 2 faces - no more, no less.
                                            Your group group has only 4 faces and several edges with only one face... so it's not a 'solid'.
                                            Select two groups in turn and see what the Entity Info dialog says... make one as a 6 sided box [it says it's 'Solid'] and yours will not say it's 'solid' !
                                            Therefore you can't do 'solid' operations on your group - it's not a 'solid'!
                                            • 1 / 5
