    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
      Jeff... doh! moment for me... 😳
      Use EEbyLattice and chose 'Rail' only option to get a central spine curve [auto-welded and grouped] without the needed to mess on erasing ribs made from EEbyRails πŸ˜’Capture.PNG
      • jeff hammondJ
        Use EEbyLattice and chose 'Rail' only option to get a central spine curve [auto-welded and grouped] without the needed to mess on erasing ribs made from EEbyRails πŸ˜’[attachment=0:1z22r8l6]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:1z22r8l6]
        lol!
        i had forgotten about that option as well
        • fredo6F
          (i can't get it to work if both curves are flat and on the same plane)
          Jeff,
          Do you have a particular model where it does not work. In general, that should give the results.
          By the way, you can choose the number of internediate curve via the #seg parameter (but not the spacing).
          • jeff hammondJ
            hi Fredo,
            it's a lot faster for me to just explain it in a video.. i hope it makes sense
            [flash=700,428:2w2q5yyr]http://www.youtube.com/v/bl7TMkBWpZc?version=3&amp;hl=en_US&amp;rel=0[/flash:2w2q5yyr]
            • fredo6F
              Jeff,
              Well spotted!
              1. Options for generating geometry is one feature of Curviloft which is not terminated. I may however add the option to keep either / or the mesh lines in a next release quickly
              2. in Skinning, I purposedly removed the meshing of surfaces that are planar, precisely to avoid too many polys and faces. Unfortunately, I did not provision an option to inhibit this feature.
              Thanks again. I'll try to incorporate all this in a next release
              Just one remark: with your skinning approach, you don't need to divide the segment. Curviloft can do it for you via the Sampling parameter.
              • jeff hammondJ
                ha.. yeah, i knew that (as it's a great feature of curviloft in general). what i meant to do was use the manual divide as a way to show me trying to force curviloft to make the lines to no avail.
                for whatever reason, i ended up doing it in a few different parts..
                i should maybe try following a script next time i make a video πŸ˜„
                  redsteel
                  Hi Fredo
                  I just want to say thank you very much!
                  • V
                    vidy
                    Dear Fredo,
                    First of all i want to thank you for this magnificent plugin.. πŸ‘
                    but i have question, is there a way to slow down the movement of the grip, when we select a grip or a point to edit it?? i usually have this problem when i want to move it on certain axes (after im press ctrl button)
                    Regards,
                    still so much to learn..
                    • C
                      clifdon
                      Great thank you for this plugin πŸ˜„.
                      • H
                        helmholtz
                        Thank you greatly good sir πŸ˜„
                          marcel.forum
                          Dear Fredo
                          Big thanks for this plugin.
                          Marcel
                          • X
                            xrok1
                            spotted this in another thread. Worth noting:
                            http://forums.sketchucation.com/download/file.php?id=67872&t=1
                              rv1974
                              Hi Fredo,
                              I recently updated your spline tools set and unfortunately it stopped functioning.
                              I get the toolbar, I can activate the commands, but they simply don't draw.
                              I'm pretty sure the file's structure is OK, the FredoLib is updated.
                              What could be the reason?
                              Thank you in advance.
                              BTW where could I download the older version?
                                Have you tried reinstalling it? Completely removing the existing plugin first and then reinstall to be 100% sure everything is installed correctly.
                                  rv1974
                                  Did it a couple times it didn't help.
                                    What is your system info? Windows and SketchUp version?
                                    Does none of the drawing functions work?
                                    I cannot reproduce it here on my end. Everything appear to work. SU8M1 Pro, Win7.
                                      rv1974
                                      it's win7x64 + su8 (see the printscreen).
                                      none of drawing tools work.
                                        rv1974
                                        I just downgraded to v1.2. It solved πŸ˜• the problem
                                          You shouldn't have to do that, though.
                                            Lets see what Fredo says - there's been no other reports of this issue since it was released in January. Seems that there's some local issue. Have you tried temporarily to run SU with just BezierSpline? In case there is a conflict with some other plugin?
                                            • 11
                                            • 12
                                            • 13
                                            • 22
                                            • 23
                                            • 11 / 23
