    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
      Taavi K
      I ran into small problem. What can I do to lose that ... problem?
        sesil5
        goodmorning!! i need your help!
        How can i download this plugin?
          Hi Sesil,
          It is posted as an attachment at the bottom of the first post.
            sesil5
            @gaieus said:
            Hi Sesil,
            Hi Gaieus, i found the zip file but it doesn't contains any runfile for installation. Sorry for my English,i'm from Greece.
            Nevertheless, thank you very much.
              SketchUp plugins are 8mostly) simple text files with an rb (for "ruby") extension. All you need to do is to extract all the content and then copy everything into the plugins folder of SketchUp which is by default (on a 32 bit windows) here:
              C:\Program Files\Google\Google SketchUp 8\Plugins\
              Also, here is a sticky post about the installation of zipped plugins:
              http://forums.sketchucation.com/viewtopic.php?f=323&t=35746
                sesil5
                It's work!!! Thank you very very much. I use some other plugins like omnigrid plugin and it was necessary to make an installation. I think that i'm comfused about the programms and the plugins!!!!
                  dirtypr
                  This is great!
                    brokenstaral
                    awsome!!
                    so simple and easy to operate!!
                    This is by far one of the best and most useful plugins I have ever seen !!!!!
                    • U Offline
                      uzairazam
                      i am unable to create furs....when i click make fur....nothing happens....what is wrong with it plz help?
                        mazureac
                        Thanks for a super plugin!
                          torring
                          Great plugin!
                            stef52
                            Hello!
                            i have a little problem with a piece of a terrain shaped with the sand box; what can i do to have a regular surface of grass instead of this triangulated one?
                            http://img11.hostingpics.net/thumbs/mini_12231297gg.png
                              tak2hata
                              Hi,stef52.
                              @stef52 said:
                              Hello!
                              I think inputing larger number to "MaxNumber(/Face)" in dialog will improve the problem.
                              How is it?
                              Please reply if it does not improve the problem.
                              Thanks.
                              by TAK2HATA
                              • eidam655E Offline
                                eidam655
                                hello,
                                thanks for the plugin, grass making is now really easy (and by using component grass, it's also super fast as well!) 😄
                                however, i have a question (a feature request): would it be possible to implement distributing by a B&W texture, or with an exponential fall-off (especially useful with the Valid Distance option)
                                thanks for answers and i wish you good luck 😄
                                I'm using SketchUp 2017, V-Ray 3.4
                                  db9black
                                  hi tak2hata
                                  i just discoverd this plugin. this plugin is awesome!!! it's a great relief for all SU users. thank you very much! domo arigato gozaimashita!!!!
                                  • mitcorbM Offline
                                    mitcorb
                                    @steph52:
                                    Viewing your example suggested that you may need to set up a more regular mesh on that slope instead of stretched triangles. More like a fishnet grid. I may have misinterpreted the image, however.
                                      tak2hata
                                      Hi,eidam655 and db9black and mitcorb.
                                      Thanks for your replys. 😄
                                      eidam655...
                                      Your request is difficult for me.
                                      I did not try processing from a picture yet.
                                      I will search the method for that solution.
                                      Please wait (without Expectation...Sorry.)
                                      by TAK2HATA
                                        azp136
                                        fur、txt、Oh, thank you
                                        • peter_shawP Offline
                                          peter_shaw
                                          just found this plugin, it's awesome!
                                            tak2hata
                                            @peter_shaw said:
                                            [attachment=0:p83hevax]<!-- ia0 -->grastropfen.jpg<!-- ia0 -->[/attachment:p83hevax]
                                            Hi ,peter_shaw.
                                            very nice! 😍
                                            by TAK2HATA
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 32
                                            • 33
                                            • 22 / 33
