    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
      torring
      Great plugin!
        stef52
        Hello!
        i have a little problem with a piece of a terrain shaped with the sand box; what can i do to have a regular surface of grass instead of this triangulated one?
        http://img11.hostingpics.net/thumbs/mini_12231297gg.png
          tak2hata
          Hi,stef52.
          @stef52 said:
          Hello!
          I think inputing larger number to "MaxNumber(/Face)" in dialog will improve the problem.
          How is it?
          Please reply if it does not improve the problem.
          Thanks.
          by TAK2HATA
          • eidam655E Offline
            eidam655
            hello,
            thanks for the plugin, grass making is now really easy (and by using component grass, it's also super fast as well!) 😄
            however, i have a question (a feature request): would it be possible to implement distributing by a B&W texture, or with an exponential fall-off (especially useful with the Valid Distance option)
            thanks for answers and i wish you good luck 😄
            I'm using SketchUp 2017, V-Ray 3.4
              db9black
              hi tak2hata
              i just discoverd this plugin. this plugin is awesome!!! it's a great relief for all SU users. thank you very much! domo arigato gozaimashita!!!!
              • mitcorbM Offline
                mitcorb
                @steph52:
                Viewing your example suggested that you may need to set up a more regular mesh on that slope instead of stretched triangles. More like a fishnet grid. I may have misinterpreted the image, however.
                  tak2hata
                  Hi,eidam655 and db9black and mitcorb.
                  Thanks for your replys. 😄
                  eidam655...
                  Your request is difficult for me.
                  I did not try processing from a picture yet.
                  I will search the method for that solution.
                  Please wait (without Expectation...Sorry.)
                  by TAK2HATA
                    azp136
                    fur、txt、Oh, thank you
                    • peter_shawP Offline
                      peter_shaw
                      just found this plugin, it's awesome!
                        tak2hata
                        @peter_shaw said:
                        [attachment=0:p83hevax]<!-- ia0 -->grastropfen.jpg<!-- ia0 -->[/attachment:p83hevax]
                        Hi ,peter_shaw.
                        very nice! 😍
                        by TAK2HATA
                        • eidam655E Offline
                          eidam655
                          hi,
                          here's what i thought of:
                          current algorithm distributes fur to the whole face/polygon according to a function with multiple parameters, density being one of them. i would suggest something like:
                          request min and max density from user
                          request/load the density map from user (file)
                          stretch image on the face (300x300 px image onto a 1m x 1m face for example)
                          go through every pixel in image //yeah, this sucks while 1. there's no getPixelColor method in sketchup's sdk as far as i can see, and 2. this is a loop in a loop and takes ages to complete 😄
                          color value divided by white (100%) is the percentage
                          therefore current density for this area is minDensity+percentage*(maxDensity-minDensity)
                          ...and so on.
                          yes, there are probably more effective ways to do this.
                          no, i'm not a computer scientist.
                          no, i don't know ruby or sketchup's sdk.
                          no, i'm not sure how this should have helped you.
                            ssw
                            CREATING GRASS with HIDDEN EDGES in model with visible edges?
                            Any way to use the create grass function to do this? Can do this in the create crowd function, but it doesn't have the controls of the blade shape.
                            A wonderful plug-in that really helps create lush landscaping.
                              jdcamc
                              Help! I'm doing something wrong. Here is my setup:
                              settings
                              and my render:
                              render
                              As you can see, the grass is just little green dots and the rendering shows nothing at all. What am I doing wrong? ❓
                                Those green dots are the preview only. Did you also press the Make fur button?
                                  jdcamc
                                  Well, I thought I did. Let me try it again just to make sure.
                                  Thanks.
                                    jdcamc
                                    yippee!! grass and everything - now I guess I'l have to start mowing....
                                    • N Offline
                                      negiaf
                                      thanks alot
                                      its amazing
                                        asmendong
                                        IVE DOWNLOADED THE MAKE FUR, BUT NO .EXE FILE, ONLY FUR_EN, NOT AND INSTALLER, ONLY IMAGES. ANY HELP PLSSS??
                                          Arman
                                          Follow the installation instructions on the download page.
                                          There is no 'exe' file or an 'installer' etc. 😕
                                          Various files/subfolder in the downloaded 'archive' file will need extracting into the Sketchup Plugins folder... Before you restart Sketchup to get the expected menus/toolbars/etc...
                                          It sounds like you are a complete installation newbie ??? 😒
                                          There are many posts explaining how to do this in some detail... do a search on the SCF forums...
                                          Please [re]read these and the tools download page guidance notes - if you still can't install it come back to us...
                                          PS: Please don't post using ALL CAPS - it looks like you are shouting at us, it is also harder to read... AND it is generally regarded as bad manners on almost all forums... 😞
                                            pogogt
                                            THHAAAAAAAAAAAANNNNKKKKK YOU!!!! this will be very helpfull with my models : )
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 32
                                            • 33
                                            • 22 / 33
