    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.2m Views 254 Watching
      boestin
      Thanks Gaieus!! That was the problem
      You made my day!!
        sectionaa
        @fletch said:
        JC,
        Does THIS help at all?
        http://twilightrender.com/phpBB3/download/file.php?id=3803
        Very useful indeed.
        There must be a variable not shown in settings dialog which controls rotation on a specified axis.
        (The default effect is visible in the road signs image).
        It would be a great benefit to have that variable available, and a "jitter" control.
        But the author has done a fantastic job.
          sectionaa
          @gaieus said:
          Yeah. Though already a minority of the countries, still "the sun never sets over the countries that drive on the left".
          And of course the land of the rising sun drives on the left.
          • brodieB Offline
            brodie
            I downloaded the plugin and extracted it to my plugins folder (SU 😎 and now get a runtime error anytime I open SU. Anyone else have this issue or have a solution?
            -Brodie
              Taavi K
              I ran into small problem. What can I do to lose that ... problem?
                sesil5
                goodmorning!! i need your help!
                How can i download this plugin?
                  Hi Sesil,
                  It is posted as an attachment at the bottom of the first post.
                    sesil5
                    @gaieus said:
                    Hi Sesil,
                    Hi Gaieus, i found the zip file but it doesn't contains any runfile for installation. Sorry for my English,i'm from Greece.
                    Nevertheless, thank you very much.
                      SketchUp plugins are 8mostly) simple text files with an rb (for "ruby") extension. All you need to do is to extract all the content and then copy everything into the plugins folder of SketchUp which is by default (on a 32 bit windows) here:
                      C:\Program Files\Google\Google SketchUp 8\Plugins\
                      Also, here is a sticky post about the installation of zipped plugins:
                      http://forums.sketchucation.com/viewtopic.php?f=323&t=35746
                        sesil5
                        It's work!!! Thank you very very much. I use some other plugins like omnigrid plugin and it was necessary to make an installation. I think that i'm comfused about the programms and the plugins!!!!
                          dirtypr
                          This is great!
                            brokenstaral
                            awsome!!
                            so simple and easy to operate!!
                            This is by far one of the best and most useful plugins I have ever seen !!!!!
                            • U Offline
                              uzairazam
                              i am unable to create furs....when i click make fur....nothing happens....what is wrong with it plz help?
                                mazureac
                                Thanks for a super plugin!
                                  torring
                                  Great plugin!
                                    stef52
                                    Hello!
                                    i have a little problem with a piece of a terrain shaped with the sand box; what can i do to have a regular surface of grass instead of this triangulated one?
                                    http://img11.hostingpics.net/thumbs/mini_12231297gg.png
                                      tak2hata
                                      Hi,stef52.
                                      @stef52 said:
                                      Hello!
                                      I think inputing larger number to "MaxNumber(/Face)" in dialog will improve the problem.
                                      How is it?
                                      Please reply if it does not improve the problem.
                                      Thanks.
                                      by TAK2HATA
                                      • eidam655E Offline
                                        eidam655
                                        hello,
                                        thanks for the plugin, grass making is now really easy (and by using component grass, it's also super fast as well!) 😄
                                        however, i have a question (a feature request): would it be possible to implement distributing by a B&W texture, or with an exponential fall-off (especially useful with the Valid Distance option)
                                        thanks for answers and i wish you good luck 😄
                                        I'm using SketchUp 2017, V-Ray 3.4
                                          db9black
                                          hi tak2hata
                                          i just discoverd this plugin. this plugin is awesome!!! it's a great relief for all SU users. thank you very much! domo arigato gozaimashita!!!!
                                          • mitcorbM Offline
                                            mitcorb
                                            @steph52:
                                            Viewing your example suggested that you may need to set up a more regular mesh on that slope instead of stretched triangles. More like a fishnet grid. I may have misinterpreted the image, however.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 32
                                            • 33
                                            • 21 / 33
