    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
    • GaieusG
      When you draw a rectangle on the red/green plane, its back face (blue colour) is showing up by default. Right click and reverse faces to change that and now the front face (white) will show upwards.
      I am not sure this is the problem but I can imagine.
      • B
        boestin
        Thanks Gaieus!! That was the problem
        You made my day!!
          sectionaa
          @fletch said:
          JC,
          Does THIS help at all?
          http://twilightrender.com/phpBB3/download/file.php?id=3803
          Very useful indeed.
          There must be a variable not shown in settings dialog which controls rotation on a specified axis.
          (The default effect is visible in the road signs image).
          It would be a great benefit to have that variable available, and a "jitter" control.
          But the author has done a fantastic job.
            sectionaa
            @gaieus said:
            Yeah. Though already a minority of the countries, still "the sun never sets over the countries that drive on the left".
            And of course the land of the rising sun drives on the left.
            • brodieB
              brodie
              I downloaded the plugin and extracted it to my plugins folder (SU 😎 and now get a runtime error anytime I open SU. Anyone else have this issue or have a solution?
              -Brodie
              • T
                Taavi K
                I ran into small problem. What can I do to lose that ... problem?
                  sesil5
                  goodmorning!! i need your help!
                  How can i download this plugin?
                  • GaieusG
                    Hi Sesil,
                    It is posted as an attachment at the bottom of the first post.
                      sesil5
                      @gaieus said:
                      Hi Sesil,
                      Hi Gaieus, i found the zip file but it doesn't contains any runfile for installation. Sorry for my English,i'm from Greece.
                      Nevertheless, thank you very much.
                      • GaieusG
                        SketchUp plugins are 8mostly) simple text files with an rb (for "ruby") extension. All you need to do is to extract all the content and then copy everything into the plugins folder of SketchUp which is by default (on a 32 bit windows) here:
                        C:\Program Files\Google\Google SketchUp 8\Plugins\
                        Also, here is a sticky post about the installation of zipped plugins:
                        http://forums.sketchucation.com/viewtopic.php?f=323&t=35746
                          sesil5
                          It's work!!! Thank you very very much. I use some other plugins like omnigrid plugin and it was necessary to make an installation. I think that i'm comfused about the programms and the plugins!!!!
                            dirtypr
                            This is great!
                            • B
                              brokenstaral
                              awsome!!
                              so simple and easy to operate!!
                              This is by far one of the best and most useful plugins I have ever seen !!!!!
                              • U
                                uzairazam
                                i am unable to create furs....when i click make fur....nothing happens....what is wrong with it plz help?
                                  mazureac
                                  Thanks for a super plugin!
                                  • T
                                    torring
                                    Great plugin!
                                      stef52
                                      Hello!
                                      i have a little problem with a piece of a terrain shaped with the sand box; what can i do to have a regular surface of grass instead of this triangulated one?
                                      http://img11.hostingpics.net/thumbs/mini_12231297gg.png
                                      • T
                                        tak2hata
                                        Hi,stef52.
                                        @stef52 said:
                                        Hello!
                                        I think inputing larger number to "MaxNumber(/Face)" in dialog will improve the problem.
                                        How is it?
                                        Please reply if it does not improve the problem.
                                        Thanks.
                                        by TAK2HATA
                                        • eidam655E
                                          eidam655
                                          hello,
                                          thanks for the plugin, grass making is now really easy (and by using component grass, it's also super fast as well!) 😄
                                          however, i have a question (a feature request): would it be possible to implement distributing by a B&W texture, or with an exponential fall-off (especially useful with the Valid Distance option)
                                          thanks for answers and i wish you good luck 😄
                                          I'm using SketchUp 2017, V-Ray 3.4
                                            db9black
                                            hi tak2hata
                                            i just discoverd this plugin. this plugin is awesome!!! it's a great relief for all SU users. thank you very much! domo arigato gozaimashita!!!!
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 32
                                            • 33
                                            • 21 / 33
