    [Plugin] Click2flip v1.0 20110928
    23 Posts 11 Posters 20.7k Views 11 Watching
    • TIGT Online
      Written as a quick response to someone's query - to show how to detect clicks only on a 'back of a face'...
      TIG (c) 2011
      Usage: Plugins menu > 'Click Back of Face to Flip...'
      Click on a face.
      If you click on its back the face flips [reverses].
      If you click on its front it's unchanged.
      If you don't click on a face nothing happens.
      If the face is 'nested' inside a group or component it will still flip!
      Press <Esc> or activate another tool to stop this tool...
      If you want it to 'beep' when a face is flipped then set @@BEEP=true at
      the start of the code...
      Donations:
      PayPal.com info @ revitrev.orgPayPalButtonVersion:
      1.0 20110928 First issue.Put the .rb file into the Plugins folder and restart Sketchup, follow the usage guidance...
      Here's the alternative ' TIG.flipBacks()' that processes selected faces en mass... http://forums.sketchucation.com/viewtopic.php?p=357193#p357193
      • CarrozzaC Offline
        Carrozza
        Seems like a great time-saver in some situations, and generally such a clever feature that should be built-int.
        Bravo TIG! ^__^
          This one is my favorite! 😎 πŸ˜‰
          • CadFatherC Offline
            CadFather
            Pilou, you are the best! πŸ˜†
              byrnebm
              You are a genius.
              Just to explain why I wanted to know how to do this. I wanted to use your "RelazioneFacce" script for some work I do. I want to select all the inside surfaces of a room (modelled as a box with no top). The "RelazioneFacce" script gives the orientation I am looking for but only when I have all the back sides of walls facing into the box. I can do this manually by clicking on the faces and reversing them so the back side of faces point in. But I thought there might be something I could put into the script so that when I select all the faces and run the "RelazioneFacce" script the code would firstly check if the back sides were facing inwards and reverse any faces that arent.
              This click2flip script will greatly speed up my process so thank you. Just wondering if it could be incorporated programatically as I have described?
              • TIGT Online
                To run it on 'all selected faces' is easier - just recast the code so that it isn't a 'tool' that needs to process clicked faces, but rather a method that processes a selection thus...
                module TIG
                def self.flipBacks()
                  model=Sketchup.active_model
                  eye=model.active_view.camera.eye
                  faces=[]
                  Sketchup.active_model.selection.each{|e|faces << e if e.class==Sketchup;;Face}
                  return nil unless faces[0]
                  model.start_operation("Flip Selected Back Faces...")
                  faces.each{|face|
                    normal=face.normal
                    vector=face.bounds.center.vector_to(eye)
                    angle=normal.angle_between(vector)
                    face.reverse! if angle > 90.degrees
                  model.commit_operation
                UI.menu('Plugins').add_item('Flip Selected Back Faces...'){self.flipBacks()} unless file_loaded?(__FILE__)
                file_loaded(__FILE__)
                Copy/paste the code into a new file in Plugins called 'TIG-flipBacks.rb', restart Sketchup and the item is in the Plugins menu for you...
                EDIT: here's a .rb ready made TIG-flipBacks.rb
                  byrnebm
                  Thanks again. When I select the 4 inside surfaces of a box, the script correctly flips all but one of the walls. Do you know what might be causing this? Is it anything to do with my viewpoint when I run the script?
                  • TIGT Online
                    Yes, if a face is towards the camera it won't reverse because as far as the rules go it IS already facing the right way!
                    If all you want to do is reverse all selected faces then simply make a Shortcut to 'Reverse'.
                    Select any face so the option is available in the context-menu list, then use Window > Preferences > Shortcuts, filter for 'Reverse', set a shortcut to it - I also have a similar key+alt mapped to 'Orient'... Then you can quickly reverse a selection of faces.
                    These tools are specifically for reversing all picked or selected faces that are 'backwards' when considering their orientation 'towards' the current eye position... πŸ€“Capture.PNG
                      byrnebm
                      Ok thanks. Just a quick question is relation to the script "relazionefacce" which I use with click2flip. For the parameters it returns i.e FACCIA, ORIENAMENTO,AREA and MATERIALE. Where does the Faccia parameter come from and is this something that can be set for each face?
                      • TIGT Online
                        FACCIA [FACE] is name=face.to_s.split(":")[-1].split(">")[0]
                        i.e. when the array of faces is made they are by their 'id' e.g.
                        [#<Sketchup::Face:0x1182fad0>, #<Sketchup::Face:0x1182f9e0>, ...]
                        The splitting takes the 'id' code so the above list becomes
                        [0x1182fad0 0x1182f9e0 ...
                        You could of course just omit that column in the file as it does little of use...
                          byrnebm
                          I was just wondering if there was some way of naming the faces. I was hoping to be able to assign the room name to the horizontal face ie the floor of the room. So when i copy the parameters returned by relazionefacce to a spreadsheet I would know what room the results refer to.
                          • TIGT Online
                            You could of course add an attribute to each face and later match the tabulated values to those, but it means manually adding them all - that's why I used the 'id' - but that only exists per session so isn't that useful later either...
                            When I code with attributes I usually add a time-stamp id as it's unique enough - if you have two attributes with the value 'office' only one might get found.
                            Tools like 'flattery' add a unique attribute code to every selected face and then use this in matching parts together later. You could do something similar - add an attribute to every selected face and use the attribute in your tabulated forms. You'd then need a second simple tool to 'find face by id' - it opens a dialog, you'd paste the attribute value from the tabulated data, and it finds the face by its attribute and then highlights that face for you...
                            Change 'FACCIA' to say 'ID'.
                            Modify the code thus...
                            faces.each{|face|
                              tid=(Time.now.to_f*1000).to_i
                              face.set_attribute('BB','id',tid)if not face.get_attribute('BB','id',nil)
                              ### if it already has an id it's kept...
                              tid=face.get_attribute('BB','id',0)
                              name=tid.to_s
                            Now write a new tool to find a face by id...
                            module TIG
                             def self.findfacebyid()
                              ss=model.selection
                              ss.clear
                              results=inputbox(['ID; '],[0],'FindFaceByID')
                              return nil unless results
                              id=results[0].to_i
                              model.active_entities.each{|e|ss.add(e)if e.get_attribute('BB','id',nil)==id}
                            Usage: type TIG.findfacebyid
                            or make a second menu item using it - follow the other menu item as a guide...
                            Copy+paste an id from the table into the dialog
                            The faces' IDs will persist across sessions provided the model is saved...
                            I used 'BB' as the attribute-library based on your initials, but you can use anything you want...
                            πŸ€“
                              Gillman
                              Just wanted to thank you for this great plug-in. It has already saved me a ton of time.
                                mirale999
                                A wonderful plugin! thank you TIG!I think TIG-flipBacks.rb is much more easier than other face reversers until now~
                                paranoia is a higher form of awareness...
                                • 3 Offline
                                  3dsmax9
                                  it's great to have a lot of choice thanks TIG, personally i prefer this one FrontFace1-2 : http://forums.sketchucation.com/viewtopic.php?t=13380
                                    mirale999
                                    haha! I'm using frontface and Click2flip, they have different feature~ I appreciate the amazing performance of the former, while the latter is faster when I have so many small faces to reverse at once!
                                    • artmusicstudioA Offline
                                      artmusicstudio
                                      hi tig,
                                      i am not a programmer, but as flipped faces always happen in skp and in complicated structures it is sometimes difficult to select them one after another, i had a following idea for this script
                                      1. could it flip ALL SELECTED faces at once (of course with your "automatic" identificaton?
                                      2. could it become an option :
                                      make all front / make all back / make all faces the side, which is "higher" represented (sorry for this english....means with 100 faces, when 3 are back and the rest is front, it would make all front and vice versa)
                                      by that i could double-click & select all connected faces and define all at once
                                      thanx stan
                                      • TIGT Online
                                        Isn't a pair of shortcut-keys, to 'Reverse' and 'Orient' to match the just reversed face, going to do most of this ?
                                          artmusicstudio
                                          yes, you're right. maybe for selection (if there is any) or all elements.
                                          so this 'make positive/negative' feature would be great and a real time-saver.
                                          regards stan
                                            clubber2k
                                            Wow, magical! πŸ‘ πŸ‘ πŸ‘
                                            looked for something like this way back and didn't find.
                                            only issue is that the automatic decision making stress me out. on complex models it might flip the right one facing to me, but also another that should be facing in another direction and I didn't even notice...
                                            can you add an option using the same concept to just label all the wrong facing faces - allowing more precise decision making?
                                            thanks 😎
