    [Plugin] CleanUp
    974 Posts 217 Posters 833.6k Views 217 Watching
    • Z Offline
      Zacchia
      Same thing in office. See screenshot.
        My bad. I made a minor change that required an update in TT_Lib2.
        Version 3.1.6
        Updated TT_Lib requirement to 2.5.5
          blajnov
          Version 3.1.6
          Updated to version 2.5.5 TT_Lib and plug tt_cleanup.rb (Version 3.1.6), but I fall empty menu
            Any error messages this time?
            Btw, you're using Windows7 or Vista, right? If you go to the plugins folder in Windows Explorer, is there a Compatibility Files button visible?
              Just noticed something odd in your screenshot:
              "CleanUpi" - the title is suppose to be "CleanUp³" ... I wonder if your copy has been corrupted...
                blajnov
                Windows7 x64, previous versions worked flawlessly Cleanup
                  Any error messages in the Ruby Console?
                  Do you see a Compatibility Files button in Windows Explorer when you go to the Plugins folder?
                  • Z Offline
                    Zacchia
                    Hi Tom
                    No error message but just an empty window
                      hm... I cannot reproduce this at all.
                      btw - when you lot check the Ruby Console, you open the Ruby Console before you try to use CleanUp ?
                      Also, do you have administrator access?
                      • N Offline
                        nomeradona
                        thnaks thomas for the update.
                        • Z Offline
                          Zacchia
                          Yes. I do this way. No messages in ruby console. Same thing in Windows 7 and XP.
                          • Z Offline
                            Zacchia
                            Tom
                            Can you send me the 3.1.4 Version again? I tried to replace the 3.1.6 with the 3.1.4 but the window is now also with 3.1.4 empty so I am not sure if I really have the 3.1.4 file...
                              Can you try:
                              1. Type in the Ruby Console: TT::Lib::VERSION
                              2. Type in the Ruby Console: TT::System.temp_path
                              3. Type in the Ruby Console: TT::Plugins::CleanUp::VERSION
                              4. Right Click on the empty webdialog when you try "Clean..." and click Properties. Take a screenshot.
                                @zacchia said:
                                Tom
                                Would you help trying to find the cause of the problem first? I'd like to get to the bottom of this.
                                • jamalitoJ Offline
                                  jamalito
                                  thank so Thomas to your great work I have Q setup cleanup to my Su it tells mt it is need to TT_lib 2.5.4 but when I setup it Edge TOOL2 not work I don't know what is a problem ? thank Sir Thomas
                                  my SU is SU8
                                  Albert Einstein:
                                  ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
                                    my SU is SU8
                                    You're saying Edge Tools doesn't work for you when you update TT_Lib? What doesn't "work"? Error messages?
                                    Have you ensured you also have the latest Edge Tools?
                                      blajnov
                                      @thomthom said:
                                      my SU is SU8
                                      Checked on a home computer, everything works fine, most likely due to adminpravami (at work today, he was absent), ie there is no access to the folder webdialog...
                                      Thomas, thanks for the update plug-in.
                                      • Z Offline
                                        Zacchia
                                        @thomthom said:
                                        Can you try:
                                        Well... this was in fact 2.5.4.... i am very sorry 😒 I was sure I changed to the new version but I did not! I am sorry and thank you so much for your support! Everything works fine now!
                                        • Z Offline
                                          Zacchia
                                          Hi Tom
                                          It's not over 😕 In office (XP) there I have still the problem, see screenshot. In Window 7 it is ok.
                                            Cursed! 😞
                                            Ok, can you Right Click and empty window and click "View Source" ?
                                            • 48
                                            • 49
                                            • 4 / 49
