    [Plugin] CleanUp
    974 Posts 217 Posters 1.3m Views 217 Watching
      @thomthom said:
      What version compared to which? 3.1.5 has no change in how it cleans compared to 3.1.4...
      Got sample model? And screenshot of settings?
      Uhh, I just downloaded today last version and replaced the one I had (can't say what version I had) and I noticed that it didn't worked as I expected. Now I'm home. I'll check tomorrow and eventually I'll send you a model.
      Also be sure that all setting where identical between your test. Could be some some checkbox being unticked.
      • Z
        Zacchia
        Tomtom
        Thanks for 3.1.5. When I "clean" nothing happens, no window pup up, when I "clean with last settings" it works like 3.1.4. Windows 7 64 bit. The window should pup up, correct? I try tomorrow at the office...
          @zacchia said:
          Tomtom
          Can you open the Ruby Console before you try "Clean..." and post back any errors?
          • Z
            Zacchia
            Same thing in office. See screenshot.
              My bad. I made a minor change that required an update in TT_Lib2.
              Version 3.1.6
              Updated TT_Lib requirement to 2.5.5
              • B
                blajnov
                Version 3.1.6
                Updated to version 2.5.5 TT_Lib and plug tt_cleanup.rb (Version 3.1.6), but I fall empty menu
                  Any error messages this time?
                  Btw, you're using Windows7 or Vista, right? If you go to the plugins folder in Windows Explorer, is there a Compatibility Files button visible?
                    Just noticed something odd in your screenshot:
                    "CleanUpi" - the title is suppose to be "CleanUp³" ... I wonder if your copy has been corrupted...
                    • B
                      blajnov
                      Windows7 x64, previous versions worked flawlessly Cleanup
                        Any error messages in the Ruby Console?
                        Do you see a Compatibility Files button in Windows Explorer when you go to the Plugins folder?
                        • Z
                          Zacchia
                          Hi Tom
                          No error message but just an empty window
                            hm... I cannot reproduce this at all.
                            btw - when you lot check the Ruby Console, you open the Ruby Console before you try to use CleanUp ?
                            Also, do you have administrator access?
                            • N
                              nomeradona
                              thnaks thomas for the update.
                              • Z
                                Zacchia
                                Yes. I do this way. No messages in ruby console. Same thing in Windows 7 and XP.
                                • Z
                                  Zacchia
                                  Tom
                                  Can you send me the 3.1.4 Version again? I tried to replace the 3.1.6 with the 3.1.4 but the window is now also with 3.1.4 empty so I am not sure if I really have the 3.1.4 file...
                                    Can you try:
                                    1. Type in the Ruby Console: TT::Lib::VERSION
                                    2. Type in the Ruby Console: TT::System.temp_path
                                    3. Type in the Ruby Console: TT::Plugins::CleanUp::VERSION
                                    4. Right Click on the empty webdialog when you try "Clean..." and click Properties. Take a screenshot.
                                      @zacchia said:
                                      Tom
                                      Would you help trying to find the cause of the problem first? I'd like to get to the bottom of this.
                                      • jamalitoJ
                                        jamalito
                                        thank so Thomas to your great work I have Q setup cleanup to my Su it tells mt it is need to TT_lib 2.5.4 but when I setup it Edge TOOL2 not work I don't know what is a problem ? thank Sir Thomas
                                        my SU is SU8
                                        Albert Einstein:
                                        ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
                                          my SU is SU8
                                          You're saying Edge Tools doesn't work for you when you update TT_Lib? What doesn't "work"? Error messages?
                                          Have you ensured you also have the latest Edge Tools?
                                          • B
                                            blajnov
                                            @thomthom said:
                                            my SU is SU8
                                            Checked on a home computer, everything works fine, most likely due to adminpravami (at work today, he was absent), ie there is no access to the folder webdialog...
                                            Thomas, thanks for the update plug-in.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 48
                                            • 49
                                            • 21 / 49
