    [Plugin] CleanUp
    974 Posts 217 Posters 1.1m Views 217 Watching
      My bad. I made a minor change that required an update in TT_Lib2.
      Version 3.1.6
      Updated TT_Lib requirement to 2.5.5
        blajnov
        Version 3.1.6
        Updated to version 2.5.5 TT_Lib and plug tt_cleanup.rb (Version 3.1.6), but I fall empty menu
          Any error messages this time?
          Btw, you're using Windows7 or Vista, right? If you go to the plugins folder in Windows Explorer, is there a Compatibility Files button visible?
            Just noticed something odd in your screenshot:
            "CleanUpi" - the title is suppose to be "CleanUp³" ... I wonder if your copy has been corrupted...
              blajnov
              Windows7 x64, previous versions worked flawlessly Cleanup
                Any error messages in the Ruby Console?
                Do you see a Compatibility Files button in Windows Explorer when you go to the Plugins folder?
                • Z Offline
                  Zacchia
                  Hi Tom
                  No error message but just an empty window
                    hm... I cannot reproduce this at all.
                    btw - when you lot check the Ruby Console, you open the Ruby Console before you try to use CleanUp ?
                    Also, do you have administrator access?
                    • N Offline
                      nomeradona
                      thnaks thomas for the update.
                      • Z Offline
                        Zacchia
                        Yes. I do this way. No messages in ruby console. Same thing in Windows 7 and XP.
                        • Z Offline
                          Zacchia
                          Tom
                          Can you send me the 3.1.4 Version again? I tried to replace the 3.1.6 with the 3.1.4 but the window is now also with 3.1.4 empty so I am not sure if I really have the 3.1.4 file...
                            Can you try:
                            1. Type in the Ruby Console: TT::Lib::VERSION
                            2. Type in the Ruby Console: TT::System.temp_path
                            3. Type in the Ruby Console: TT::Plugins::CleanUp::VERSION
                            4. Right Click on the empty webdialog when you try "Clean..." and click Properties. Take a screenshot.
                              @zacchia said:
                              Tom
                              Would you help trying to find the cause of the problem first? I'd like to get to the bottom of this.
                              • jamalitoJ Offline
                                jamalito
                                thank so Thomas to your great work I have Q setup cleanup to my Su it tells mt it is need to TT_lib 2.5.4 but when I setup it Edge TOOL2 not work I don't know what is a problem ? thank Sir Thomas
                                my SU is SU8
                                Albert Einstein:
                                ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
                                  my SU is SU8
                                  You're saying Edge Tools doesn't work for you when you update TT_Lib? What doesn't "work"? Error messages?
                                  Have you ensured you also have the latest Edge Tools?
                                    blajnov
                                    @thomthom said:
                                    my SU is SU8
                                    Checked on a home computer, everything works fine, most likely due to adminpravami (at work today, he was absent), ie there is no access to the folder webdialog...
                                    Thomas, thanks for the update plug-in.
                                    • Z Offline
                                      Zacchia
                                      @thomthom said:
                                      Can you try:
                                      Well... this was in fact 2.5.4.... i am very sorry 😒 I was sure I changed to the new version but I did not! I am sorry and thank you so much for your support! Everything works fine now!
                                      • Z Offline
                                        Zacchia
                                        Hi Tom
                                        It's not over 😕 In office (XP) there I have still the problem, see screenshot. In Window 7 it is ok.
                                          Cursed! 😞
                                          Ok, can you Right Click and empty window and click "View Source" ?
                                          • Z Offline
                                            Zacchia
                                            @thomthom said:
                                            Cursed! 😞
                                            In german lanuage "Quelltext anzeigen", hope you mean this...
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 48
                                            • 49
                                            • 21 / 49
