    [Plugin] CleanUp
    974 Posts 217 Posters 1.3m Views 217 Watching
      @zacchia said:
      Tomtom
      Thanks for 3.1.5. When I "clean" nothing happens, no window pup up, when I "clean with last settings" it works like 3.1.4. Windows 7 64 bit. The window should pup up, correct? I try tomorrow at the office...
      Can you open the Ruby Console before you try "Clean..." and post back any errors?
      • Z
        Zacchia
        Same thing in office. See screenshot.
          My bad. I made a minor change that required an update in TT_Lib2.
          Version 3.1.6
          Updated TT_Lib requirement to 2.5.5
          • B
            blajnov
            Version 3.1.6
            Updated to version 2.5.5 TT_Lib and plug tt_cleanup.rb (Version 3.1.6), but I fall empty menu
              Any error messages this time?
              Btw, you're using Windows7 or Vista, right? If you go to the plugins folder in Windows Explorer, is there a Compatibility Files button visible?
                Just noticed something odd in your screenshot:
                "CleanUpi" - the title is suppose to be "CleanUp³" ... I wonder if your copy has been corrupted...
                • B
                  blajnov
                  Windows7 x64, previous versions worked flawlessly Cleanup
                    Any error messages in the Ruby Console?
                    Do you see a Compatibility Files button in Windows Explorer when you go to the Plugins folder?
                    • Z
                      Zacchia
                      Hi Tom
                      No error message but just an empty window
                        hm... I cannot reproduce this at all.
                        btw - when you lot check the Ruby Console, you open the Ruby Console before you try to use CleanUp ?
                        Also, do you have administrator access?
                        • N
                          nomeradona
                          thnaks thomas for the update.
                          • Z
                            Zacchia
                            Yes. I do this way. No messages in ruby console. Same thing in Windows 7 and XP.
                            • Z
                              Zacchia
                              Tom
                              Can you send me the 3.1.4 Version again? I tried to replace the 3.1.6 with the 3.1.4 but the window is now also with 3.1.4 empty so I am not sure if I really have the 3.1.4 file...
                                Can you try:
                                1. Type in the Ruby Console: TT::Lib::VERSION
                                2. Type in the Ruby Console: TT::System.temp_path
                                3. Type in the Ruby Console: TT::Plugins::CleanUp::VERSION
                                4. Right Click on the empty webdialog when you try "Clean..." and click Properties. Take a screenshot.
                                  @zacchia said:
                                  Tom
                                  Would you help trying to find the cause of the problem first? I'd like to get to the bottom of this.
                                  • jamalitoJ
                                    jamalito
                                    thank so Thomas to your great work I have Q setup cleanup to my Su it tells mt it is need to TT_lib 2.5.4 but when I setup it Edge TOOL2 not work I don't know what is a problem ? thank Sir Thomas
                                    my SU is SU8
                                    Albert Einstein:
                                    ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
                                      my SU is SU8
                                      You're saying Edge Tools doesn't work for you when you update TT_Lib? What doesn't "work"? Error messages?
                                      Have you ensured you also have the latest Edge Tools?
                                      • B
                                        blajnov
                                        @thomthom said:
                                        my SU is SU8
                                        Checked on a home computer, everything works fine, most likely due to adminpravami (at work today, he was absent), ie there is no access to the folder webdialog...
                                        Thomas, thanks for the update plug-in.
                                        • Z
                                          Zacchia
                                          @thomthom said:
                                          Can you try:
                                          Well... this was in fact 2.5.4.... i am very sorry 😒 I was sure I changed to the new version but I did not! I am sorry and thank you so much for your support! Everything works fine now!
                                          • Z
                                            Zacchia
                                            Hi Tom
                                            It's not over 😕 In office (XP) there I have still the problem, see screenshot. In Window 7 it is ok.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 48
                                            • 49
                                            • 21 / 49
