    [Plugin] CleanUp
    974 Posts 217 Posters 1.0m Views 217 Watching
      Just noticed something odd in your screenshot:
      "CleanUpi" - the title is suppose to be "CleanUp³" ... I wonder if your copy has been corrupted...
        blajnov
        @thomthom said:
        Any error messages this time?
        Btw, you're using Windows7 or Vista, right? If you go to the plugins folder in Windows Explorer, is there a Compatibility Files button visible?
        Windows7 x64, previous versions worked flawlessly Cleanup
          Any error messages in the Ruby Console?
          Do you see a Compatibility Files button in Windows Explorer when you go to the Plugins folder?
          • Z Offline
            Zacchia
            Hi Tom
            No error message but just an empty window
              hm... I cannot reproduce this at all.
              btw - when you lot check the Ruby Console, you open the Ruby Console before you try to use CleanUp ?
              Also, do you have administrator access?
              • N Offline
                nomeradona
                thnaks thomas for the update.
                • Z Offline
                  Zacchia
                  Yes. I do this way. No messages in ruby console. Same thing in Windows 7 and XP.
                  • Z Offline
                    Zacchia
                    Tom
                    Can you send me the 3.1.4 Version again? I tried to replace the 3.1.6 with the 3.1.4 but the window is now also with 3.1.4 empty so I am not sure if I really have the 3.1.4 file...
                      Can you try:
                      1. Type in the Ruby Console: TT::Lib::VERSION
                      2. Type in the Ruby Console: TT::System.temp_path
                      3. Type in the Ruby Console: TT::Plugins::CleanUp::VERSION
                      4. Right Click on the empty webdialog when you try "Clean..." and click Properties. Take a screenshot.
                        @zacchia said:
                        Tom
                        Would you help trying to find the cause of the problem first? I'd like to get to the bottom of this.
                        • jamalitoJ Offline
                          jamalito
                          thank so Thomas to your great work I have Q setup cleanup to my Su it tells mt it is need to TT_lib 2.5.4 but when I setup it Edge TOOL2 not work I don't know what is a problem ? thank Sir Thomas
                          my SU is SU8
                          Albert Einstein:
                          ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
                            my SU is SU8
                            You're saying Edge Tools doesn't work for you when you update TT_Lib? What doesn't "work"? Error messages?
                            Have you ensured you also have the latest Edge Tools?
                              blajnov
                              @thomthom said:
                              my SU is SU8
                              Checked on a home computer, everything works fine, most likely due to adminpravami (at work today, he was absent), ie there is no access to the folder webdialog...
                              Thomas, thanks for the update plug-in.
                              • Z Offline
                                Zacchia
                                @thomthom said:
                                Can you try:
                                Well... this was in fact 2.5.4.... i am very sorry 😒 I was sure I changed to the new version but I did not! I am sorry and thank you so much for your support! Everything works fine now!
                                • Z Offline
                                  Zacchia
                                  Hi Tom
                                  It's not over 😕 In office (XP) there I have still the problem, see screenshot. In Window 7 it is ok.
                                    Cursed! 😞
                                    Ok, can you Right Click and empty window and click "View Source" ?
                                    • Z Offline
                                      Zacchia
                                      @thomthom said:
                                      Cursed! 😞
                                      In german lanuage "Quelltext anzeigen", hope you mean this...
                                        I really do not understand why.
                                        What is your Internet Explorer version btw?
                                        • charly2008C Offline
                                          charly2008
                                          Hi Thomas.
                                          I have updated to version 3.1.6 but now no more menu box appears. I can run it but only with "Clean with last settings". What could be wrong? In the ruby console appears (see picture below)
                                          Charly
                                          Command: Clean
                                          Command: Clean with last settings
                                            That error indicate that you haven't updated TT_Lib2 to 2.5.5. It should have given you an error about that at startup, so I don't understand why you didn't. 😕
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 48
                                            • 49
                                            • 21 / 49
