    [Plugin] CleanUp
    974 Posts 217 Posters 1.3m Views 217 Watching
      mberger
      Thank you.
      I have a feature request:
      Could you have the option to not purge components that are unused but have "XXXX_proxy" instances.
      I use the proxy feature in maxwell exporter a lot. It allows me to swap in the more complex geometry on export.
      Functionality would be a checkbox i think and an extra check when deleting an un used instance if the corresponding instance with _proxy appended to the name is used and iff that is true not delete it.
      • dereiD
        derei
        It seems like your last version doesn't clean as good as the previous did. I wanted to clean some lines from a geometry I modified, but they remained. I had to delete them manually.
        DESIGNER AND ARTIST DEREI.UK
          What version compared to which? 3.1.5 has no change in how it cleans compared to 3.1.4...
          Got sample model? And screenshot of settings?
            3rdEye
            Hmmm, strange....
            when I install 3.1.5 and try with either TT_Lib 2.5.4 or 2.5.5 I get a blank Window on hitting the Cleanup Menue Item. So I switched back to 3.1.4 and Lib 2.5.4, which is the combination that works.
            I use SU 8 Pro, WinXP 32bit,
            but anyway - thx again for keeping it up!
            all the best, 3rdEye
            • dereiD
              derei
              Uhh, I just downloaded today last version and replaced the one I had (can't say what version I had) and I noticed that it didn't worked as I expected. Now I'm home. I'll check tomorrow and eventually I'll send you a model.
                Also be sure that all setting where identical between your test. Could be some some checkbox being unticked.
                • Z
                  Zacchia
                  Tomtom
                  Thanks for 3.1.5. When I "clean" nothing happens, no window pup up, when I "clean with last settings" it works like 3.1.4. Windows 7 64 bit. The window should pup up, correct? I try tomorrow at the office...
                    @zacchia said:
                    Tomtom
                    Can you open the Ruby Console before you try "Clean..." and post back any errors?
                    • Z
                      Zacchia
                      Same thing in office. See screenshot.
                        My bad. I made a minor change that required an update in TT_Lib2.
                        Version 3.1.6
                        Updated TT_Lib requirement to 2.5.5
                        • B
                          blajnov
                          Version 3.1.6
                          Updated to version 2.5.5 TT_Lib and plug tt_cleanup.rb (Version 3.1.6), but I fall empty menu
                            Any error messages this time?
                            Btw, you're using Windows7 or Vista, right? If you go to the plugins folder in Windows Explorer, is there a Compatibility Files button visible?
                              Just noticed something odd in your screenshot:
                              "CleanUpi" - the title is suppose to be "CleanUp³" ... I wonder if your copy has been corrupted...
                              • B
                                blajnov
                                Windows7 x64, previous versions worked flawlessly Cleanup
                                  Any error messages in the Ruby Console?
                                  Do you see a Compatibility Files button in Windows Explorer when you go to the Plugins folder?
                                  • Z
                                    Zacchia
                                    Hi Tom
                                    No error message but just an empty window
                                      hm... I cannot reproduce this at all.
                                      btw - when you lot check the Ruby Console, you open the Ruby Console before you try to use CleanUp ?
                                      Also, do you have administrator access?
                                      • N
                                        nomeradona
                                        thnaks thomas for the update.
                                        • Z
                                          Zacchia
                                          Yes. I do this way. No messages in ruby console. Same thing in Windows 7 and XP.
                                          • Z
                                            Zacchia
                                            Tom
                                            Can you send me the 3.1.4 Version again? I tried to replace the 3.1.6 with the 3.1.4 but the window is now also with 3.1.4 empty so I am not sure if I really have the 3.1.4 file...
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 48
                                            • 49
                                            • 21 / 49
