    [Plugin] CleanUp
    974 Posts 217 Posters 1.2m Views 217 Watching
      Clean up of Clean up! ๐Ÿ˜‰
        @driven said:
        @thomthom said:
        Version 3.1.5
        Minor update to fix an internal GC issue.
        should this remove the html temp files?
        No. Afraid not. Anything related to that will occur in TT_Lib. I'll have a proper patch in a day or two.
        • pep75P
          pep75
          ๐Ÿ‘ ๐ŸŽ‰
            mberger
            Thank you.
            I have a feature request:
            Could you have the option to not purge components that are unused but have "XXXX_proxy" instances.
            I use the proxy feature in maxwell exporter a lot. It allows me to swap in the more complex geometry on export.
            Functionality would be a checkbox i think and an extra check when deleting an un used instance if the corresponding instance with _proxy appended to the name is used and iff that is true not delete it.
            • dereiD
              derei
              It seems like your last version doesn't clean as good as the previous did. I wanted to clean some lines from a geometry I modified, but they remained. I had to delete them manually.
              DESIGNER AND ARTIST DEREI.UK
                What version compared to which? 3.1.5 has no change in how it cleans compared to 3.1.4...
                Got sample model? And screenshot of settings?
                  3rdEye
                  Hmmm, strange....
                  when I install 3.1.5 and try with either TT_Lib 2.5.4 or 2.5.5 I get a blank Window on hitting the Cleanup Menue Item. So I switched back to 3.1.4 and Lib 2.5.4, which is the combination that works.
                  I use SU 8 Pro, WinXP 32bit,
                  but anyway - thx again for keeping it up!
                  all the best, 3rdEye
                  • dereiD
                    derei
                    Uhh, I just downloaded today last version and replaced the one I had (can't say what version I had) and I noticed that it didn't worked as I expected. Now I'm home. I'll check tomorrow and eventually I'll send you a model.
                      Also be sure that all setting where identical between your test. Could be some some checkbox being unticked.
                      • Z
                        Zacchia
                        Tomtom
                        Thanks for 3.1.5. When I "clean" nothing happens, no window pup up, when I "clean with last settings" it works like 3.1.4. Windows 7 64 bit. The window should pup up, correct? I try tomorrow at the office...
                          @zacchia said:
                          Tomtom
                          Can you open the Ruby Console before you try "Clean..." and post back any errors?
                          • Z
                            Zacchia
                            Same thing in office. See screenshot.
                              My bad. I made a minor change that required an update in TT_Lib2.
                              Version 3.1.6
                              Updated TT_Lib requirement to 2.5.5
                              • B
                                blajnov
                                Version 3.1.6
                                Updated to version 2.5.5 TT_Lib and plug tt_cleanup.rb (Version 3.1.6), but I fall empty menu
                                  โ“ โ“ โ“
                                  Any error messages this time?
                                  Btw, you're using Windows7 or Vista, right? If you go to the plugins folder in Windows Explorer, is there a Compatibility Files button visible?
                                    Just noticed something odd in your screenshot:
                                    "CleanUpi" - the title is suppose to be "CleanUpยณ" ... I wonder if your copy has been corrupted...
                                    • B
                                      blajnov
                                      @thomthom said:
                                      :?: โ“ โ“
                                      Windows7 x64, previous versions worked flawlessly Cleanup
                                        @blajnov said:
                                        @thomthom said:
                                        :?: โ“ โ“
                                        Any error messages in the Ruby Console?
                                        Do you see a Compatibility Files button in Windows Explorer when you go to the Plugins folder?
                                        • Z
                                          Zacchia
                                          Hi Tom
                                          No error message but just an empty window
                                            hm... I cannot reproduce this at all.
                                            btw - when you lot check the Ruby Console, you open the Ruby Console before you try to use CleanUp ?
                                            Also, do you have administrator access?
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 48
                                            • 49
                                            • 21 / 49
