    [Plugin] CleanUp
    974 Posts 217 Posters 834.3k Views 217 Watching
    • dereiD Offline
      derei
      It seems like your last version doesn't clean as good as the previous did. I wanted to clean some lines from a geometry I modified, but they remained. I had to delete them manually.
        What version compared to which? 3.1.5 has no change in how it cleans compared to 3.1.4...
        Got sample model? And screenshot of settings?
        • 3 Offline
          3rdEye
          Hmmm, strange....
          when I install 3.1.5 and try with either TT_Lib 2.5.4 or 2.5.5 I get a blank Window on hitting the Cleanup Menue Item. So I switched back to 3.1.4 and Lib 2.5.4, which is the combination that works.
          I use SU 8 Pro, WinXP 32bit,
          but anyway - thx again for keeping it up!
          all the best, 3rdEye
          • dereiD Offline
            derei
            Uhh, I just downloaded today last version and replaced the one I had (can't say what version I had) and I noticed that it didn't worked as I expected. Now I'm home. I'll check tomorrow and eventually I'll send you a model.
              Also be sure that all setting where identical between your test. Could be some some checkbox being unticked.
              • Z Offline
                Zacchia
                Tomtom
                Thanks for 3.1.5. When I "clean" nothing happens, no window pup up, when I "clean with last settings" it works like 3.1.4. Windows 7 64 bit. The window should pup up, correct? I try tomorrow at the office...
                  @zacchia said:
                  Tomtom
                  Can you open the Ruby Console before you try "Clean..." and post back any errors?
                  • Z Offline
                    Zacchia
                    Same thing in office. See screenshot.
                      My bad. I made a minor change that required an update in TT_Lib2.
                      Version 3.1.6
                      Updated TT_Lib requirement to 2.5.5
                        blajnov
                        Version 3.1.6
                        Updated to version 2.5.5 TT_Lib and plug tt_cleanup.rb (Version 3.1.6), but I fall empty menu
                          Any error messages this time?
                          Btw, you're using Windows7 or Vista, right? If you go to the plugins folder in Windows Explorer, is there a Compatibility Files button visible?
                            Just noticed something odd in your screenshot:
                            "CleanUpi" - the title is suppose to be "CleanUp³" ... I wonder if your copy has been corrupted...
                              blajnov
                              Windows7 x64, previous versions worked flawlessly Cleanup
                                Any error messages in the Ruby Console?
                                Do you see a Compatibility Files button in Windows Explorer when you go to the Plugins folder?
                                • Z Offline
                                  Zacchia
                                  Hi Tom
                                  No error message but just an empty window
                                    hm... I cannot reproduce this at all.
                                    btw - when you lot check the Ruby Console, you open the Ruby Console before you try to use CleanUp ?
                                    Also, do you have administrator access?
                                    • N Offline
                                      nomeradona
                                      thnaks thomas for the update.
                                      • Z Offline
                                        Zacchia
                                        Yes. I do this way. No messages in ruby console. Same thing in Windows 7 and XP.
                                        • Z Offline
                                          Zacchia
                                          Tom
                                          Can you send me the 3.1.4 Version again? I tried to replace the 3.1.6 with the 3.1.4 but the window is now also with 3.1.4 empty so I am not sure if I really have the 3.1.4 file...
                                            Can you try:
                                            1. Type in the Ruby Console: TT::Lib::VERSION
                                            2. Type in the Ruby Console: TT::System.temp_path
                                            3. Type in the Ruby Console: TT::Plugins::CleanUp::VERSION
                                            4. Right Click on the empty webdialog when you try "Clean..." and click Properties. Take a screenshot.
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 48
                                            • 49
                                            • 17 / 49
