    [Plugin] CleanUp
    974 Posts 217 Posters 992.0k Views 217 Watching
      small08
      Thank-you TT, for all your hard work.
        driven
        @thomthom said:
        Version 3.1.5
        Minor update to fix an internal GC issue.
        should this remove the html temp files?
          Ben Ritter
          Thank you!
            putnik
            Thank you Tom!
            http://keshas.info
              chango70
              Just great!
                Clean up of Clean up! 😉
                  @driven said:
                  @thomthom said:
                  Version 3.1.5
                  No. Afraid not. Anything related to that will occur in TT_Lib. I'll have a proper patch in a day or two.
                  • pep75P Offline
                    pep75
                      mberger
                      Thank you.
                      I have a feature request:
                      Could you have the option to not purge components that are unused but have "XXXX_proxy" instances.
                      I use the proxy feature in maxwell exporter a lot. It allows me to swap in the more complex geometry on export.
                      Functionality would be a checkbox i think and an extra check when deleting an un used instance if the corresponding instance with _proxy appended to the name is used and iff that is true not delete it.
                      • dereiD Offline
                        derei
                        It seems like your last version doesn't clean as good as the previous did. I wanted to clean some lines from a geometry I modified, but they remained. I had to delete them manually.
                          What version compared to which? 3.1.5 has no change in how it cleans compared to 3.1.4...
                          Got sample model? And screenshot of settings?
                          • 3 Offline
                            3rdEye
                            Hmmm, strange....
                            when I install 3.1.5 and try with either TT_Lib 2.5.4 or 2.5.5 I get a blank Window on hitting the Cleanup Menue Item. So I switched back to 3.1.4 and Lib 2.5.4, which is the combination that works.
                            I use SU 8 Pro, WinXP 32bit,
                            but anyway - thx again for keeping it up!
                            all the best, 3rdEye
                            • dereiD Offline
                              derei
                              Uhh, I just downloaded today last version and replaced the one I had (can't say what version I had) and I noticed that it didn't worked as I expected. Now I'm home. I'll check tomorrow and eventually I'll send you a model.
                                Also be sure that all setting where identical between your test. Could be some some checkbox being unticked.
                                • Z Offline
                                  Zacchia
                                  Tomtom
                                  Thanks for 3.1.5. When I "clean" nothing happens, no window pup up, when I "clean with last settings" it works like 3.1.4. Windows 7 64 bit. The window should pup up, correct? I try tomorrow at the office...
                                    @zacchia said:
                                    Tomtom
                                    Can you open the Ruby Console before you try "Clean..." and post back any errors?
                                    • Z Offline
                                      Zacchia
                                      Same thing in office. See screenshot.
                                        My bad. I made a minor change that required an update in TT_Lib2.
                                        Version 3.1.6
                                        Updated TT_Lib requirement to 2.5.5
                                          blajnov
                                          Version 3.1.6
                                          Updated to version 2.5.5 TT_Lib and plug tt_cleanup.rb (Version 3.1.6), but I fall empty menu
                                            Any error messages this time?
                                            Btw, you're using Windows7 or Vista, right? If you go to the plugins folder in Windows Explorer, is there a Compatibility Files button visible?
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 48
                                            • 49
                                            • 20 / 49
