    Need help. Sketchup to Unigrafix
    19 Posts 4 Posters 1.9k Views 4 Watching
      Best to ask at Rhino's end...
      • P
        Panga
        Maybe a software like Deep Exploration could help in this case, I'm not sure, you've to check if the needed format are supported.
        http://www.righthemisphere.com/products/dexp/
        • fuzzionF
          fuzzion
          Hey TIG, it shouldnt matter if I use the free SU version...Right?
          "Only the dead have seen the end of war" - Plato
            There's no difference between the SKP files from Free and Pro...
            • fuzzionF
              fuzzion
              %(#FF0000)[Hi and Josh,
              Rhino V4 SR9 will open SketchUp V7 and older files.
              Rhino V5 win32 will open SketchUp V8 and older files.
              Rhino V4 pre SR9 will open SketchUp V6 and older files (unless it is a
              really old V4 and then I'm not sure. It all has to do with the SketchUp SDK
              that was available when the Rhino service release came out)
              Tim]
              Rhino 5 is in beta and I dont have the CD key.
              Is there a way to open a SU8 file in SU7
              or should I go Pro SU8 and save it some file that makes it easier to open in Rhino to convert to PRT or the above mentioned filenames.
              Again, thank you so much for your help.
                File > Save As....
                Change .skp to .skp v7
                  Open the v8 SKP in v8 and File > Save_As - choose an earlier SKP version from the dropdown list, like v7; save the file and import it into Rhino as the acceptable version-SKP πŸ˜„
                  • fuzzionF
                    fuzzion
                    Im tring all of the above suggestions including feedback from rhino, but everytime i export to rhino from SKP then from SKPO to STP it says
                    "step export does not support polygon meshes" and i get a wuerd looking outline of my drawing. Any suggestions? Thanks heaps
                    &STL file works now. Lets see proto type company accepts files
                    • fuzzionF
                      fuzzion
                      I have called all the proto typing companies in SIngapore.
                      They say there is no real conversion from .skp into a solid file meaning
                      even though rhino can convert .skp files into .stl
                      the proto type machine will print out the inherent rough edges from the file.
                      He reckons i should learn AUtodesk inventor 😑 I dont have time,
                      im a full time attorney and drawing stuff and thinking of ideas is my hobby. SO for
                      the mean time, all I can do is give him the design, ask him to sign a non disclosure agreement and
                      pay him a few hundred bucks to make a solid file for rapid prototyping from my skp file.
                      Im still hoping that there is a work around, but there seems to be none, or is there? πŸ˜•
                        There are many SKP users who are successfully making prototypes using 3d-printing, so I fail to see your 'bureau's' problem πŸ˜•
                        Of course you do have to model carefully as manifold 'solids' etc...
                        There are also SKP > STL tools other than Rhino... Some even help you to make a good STL file from your messy SKP... some are completely Free and the Pro versions are not too expensive anyway at perhaps <$40/month or $299/year... IF you need those extra-special functions...
                        e.g.http://www.cadspan.com/[flash=640,390:1xnvnmlh]http://www.youtube.com/v/dvdUbV5R5xg&hl=en_US[/flash:1xnvnmlh]
                        http://www.aec3dp.com/tutorial-convert-google-sketchup-file-solid-3d-printable-stl-cadspan-toolset
                        http://forums.sketchucation.com/viewtopic.php?p=209946#p209946
                        http://www.cerebralmeltdown.com/cncstuff/stl/index.htm
                        etc etc...
                        • fuzzionF
                          fuzzion
                          You are the man TIG !
                          WIll contact my prototyping workshop on monday and see what they say.
                            Also SyCode offer various import and export options...
                            (www.sycode.com)
