    Need help. Sketchup to Unigrafix
    19 Posts 4 Posters 1.5k Views 4 Watching
    • fuzzionF Offline
      fuzzion
      @tig said:
      No!
      You need to do two steps - SKP >> XXX... then XXX >> PRT - there are several file formats that you can get out of SUp that other 'pay programs' can then convert to PRT etc - look at the http://www...
      I even think Rhino has a free trial with 25 saves so that might work ???
      Why not try a CADkey [KeyCreator] trail ? Otherwise it's $1,750 a seat!
      Thanks for your reply.
      I tried downloading the legit copy of rhino. Opened a .skp file but the screen was blank. It does have the x_t file export extension so that would be good.
      What am I doing wrong here?
      "Only the dead have seen the end of war" - Plato
        Read Rhino's import SKP guidance and continue...
        http://wiki.mcneel.com/labs/threedwarehouse#importing_sketchup_files
        • fuzzionF Offline
          fuzzion
          THanks for that.
          I get
          "Error importing file "C:\Users\Josh\Documents\4way_woofer.skp". ANd i tried many different files. (I do have VFSU running in the background rendering some stuff but i doubt that should cause the program)
          Using SR9 4.0 rhino.
          WHat am I doing wrong here? 😞
            Best to ask at Rhino's end...
              Panga
              Maybe a software like Deep Exploration could help in this case, I'm not sure, you've to check if the needed format are supported.
              (www.righthemisphere.com)
              • fuzzionF Offline
                fuzzion
                Hey TIG, it shouldnt matter if I use the free SU version...Right?
                  There's no difference between the SKP files from Free and Pro...
                  • fuzzionF Offline
                    fuzzion
                    %(#FF0000)[Hi and Josh,
                    Rhino V4 SR9 will open SketchUp V7 and older files.
                    Rhino V5 win32 will open SketchUp V8 and older files.
                    Rhino V4 pre SR9 will open SketchUp V6 and older files (unless it is a
                    really old V4 and then I'm not sure. It all has to do with the SketchUp SDK
                    that was available when the Rhino service release came out)
                    Tim]
                    Rhino 5 is in beta and I dont have the CD key.
                    Is there a way to open a SU8 file in SU7
                    or should I go Pro SU8 and save it some file that makes it easier to open in Rhino to convert to PRT or the above mentioned filenames.
                    Again, thank you so much for your help.
                      File > Save As....
                      Change .skp to .skp v7
                        Open the v8 SKP in v8 and File > Save_As - choose an earlier SKP version from the dropdown list, like v7; save the file and import it into Rhino as the acceptable version-SKP πŸ˜„
                        • fuzzionF Offline
                          fuzzion
                          Im tring all of the above suggestions including feedback from rhino, but everytime i export to rhino from SKP then from SKPO to STP it says
                          "step export does not support polygon meshes" and i get a wuerd looking outline of my drawing. Any suggestions? Thanks heaps
                          &STL file works now. Lets see proto type company accepts files
                          • fuzzionF Offline
                            fuzzion
                            I have called all the proto typing companies in SIngapore.
                            They say there is no real conversion from .skp into a solid file meaning
                            even though rhino can convert .skp files into .stl
                            the proto type machine will print out the inherent rough edges from the file.
                            He reckons i should learn AUtodesk inventor 😑 I dont have time,
                            im a full time attorney and drawing stuff and thinking of ideas is my hobby. SO for
                            the mean time, all I can do is give him the design, ask him to sign a non disclosure agreement and
                            pay him a few hundred bucks to make a solid file for rapid prototyping from my skp file.
                            Im still hoping that there is a work around, but there seems to be none, or is there? πŸ˜•
                              There are many SKP users who are successfully making prototypes using 3d-printing, so I fail to see your 'bureau's' problem πŸ˜•
                              Of course you do have to model carefully as manifold 'solids' etc...
                              There are also SKP > STL tools other than Rhino... Some even help you to make a good STL file from your messy SKP... some are completely Free and the Pro versions are not too expensive anyway at perhaps <$40/month or $299/year... IF you need those extra-special functions...
                              e.g.http://www.cadspan.com/[flash=640,390:1xnvnmlh]http://www.youtube.com/v/dvdUbV5R5xg&hl=en_US[/flash:1xnvnmlh]
                              http://www.aec3dp.com/tutorial-convert-google-sketchup-file-solid-3d-printable-stl-cadspan-toolset
                              http://forums.sketchucation.com/viewtopic.php?p=209946#p209946
                              http://www.cerebralmeltdown.com/cncstuff/stl/index.htm
                              etc etc...
                              • fuzzionF Offline
                                fuzzion
                                You are the man TIG !
                                WIll contact my prototyping workshop on monday and see what they say.
                                  Also SyCode offer various import and export options...
                                  http://www.sycode.com/products/sketchup/index.htm
