    CatchUp Edition 4
    38 Posts 12 Posters 28.1k Views 12 Watching
      @marvins_dad said:
      Another great one guys!
      Might have to check out that Mouse that Mike reviewed.
      Wait til next edition as we'll be doing a more indepth test
        @khai said:
        any chance of a direct download link? (right clicking the download link goes to "index.html" and I've never had any luck loading PDF's into Firefox....)
        You can download the PDF on the Issuu site.
          Go here...
          http://issuu.com/rclub24/docs/catchup_4
          ...and press this button
            That requires you to have a login/password!
              Khai
              yes.. it does..
              in the end, I started the index page, copied the URL that FF crashed on before it crashed and used that to download the PDF.
                That's a shit feature πŸ‘Ž
                For those who still need to bypass the redirect link (even though it helps us track stats) just click the red catchup button at the top of the page....here.... πŸ˜’
                  Khai
                  it's not that I don't want to help you track stats on this. it's I can't get to read it otherwise... (I've never worked out why my firefox hates PDF's. I've tried 2/3/4/5/6/Aurora, Adobe/Foxit/etc... FF will start loading it and just carry on forever loading.... I have to download the PDF and then read it in FF or Foxit..)
                    That linked PDF has not got any 'Save' option toolbars either, or at least not in Acrobat Reader X embedded in FireFox 6.
                    I use the FireFox Add-on 'DownloadThemAll', which let's you download things like PDFs and images that are otherwise not accessible in the browser window...
                    You can always use File...SaveAs... menu option too and change to AllFileTypes and edit the suffix to .PDF - it then downloads OK too.
                      PDF X-Change Viewer integrates with FF and is much light than that Adobe beast
                        This should work...
                        Close FireFox and open 'Adobe Reader X'.
                        From the edit menu open up 'Preferences'.
                        Click on the "Internet" settings and uncheck the box "Display in Read Mode by default".
                        As a precaution, go to the "Document" settings and make sure that the box "Allow documents to hide the menubar, toolbars, and window-controls" is also unchecked.
                        Click OK and close Adobe Reader X.
                        Just to make sure, open Adobe Reader X and close it again.
                        Now the print, save buttons etc... should be visible in Adobe Reader X, inside the browser next time you run FireFox.
                        BUT it is flaky!
                        • pbacotP Offline
                          Thanks guys,
                          Another great issue.
                          Two things:
                          1. I find when I get to the lumenRT ad in the page turner edition, clicking on the page turner arrow takes me to the Lumen site, doesn't turn the page. Arrow key works OK.
                          2. In the survey you don't say what period you are proposing for the donation amounts.
                          Peter
                            davs001
                            Hello everybody
                            The first thing: Thank you very much!. Excellent job!
                            The second: I have problems when I followed the niche tutorial. When I tried to use Extrude Edges by Rails in SU8, it allow me to select the profile, rails, etc. but nothing happens. I changed to SU7 and the extruded surface came up immediately. This is my second Issue with SU8…
                            Your help please - I've split the thread off into EEbyRails... TIG http://forums.sketchucation.com/viewtopic.php?p=350962#p350962
                              Can you post this issue in the plugins thread? I can't see the problem unless you failed to select th melding profile?
                              • W Offline
                                wannabe
                                hey!
                                I'm searching for the thread (I think it was a tutorial or in the gallery section) showing the development of the scene used to presentate the "useful app sketcher" in the pdf 😲
                                thanks
                                  There isn't a thread just for Sketcher. There's a thread on the 'ongoing useful mac apps' in the Corner Bar forum that has discussions on it.
                                  • W Offline
                                    wannabe
                                    ah thanks for reply but well I meant the asian house thats in that picture used to show the features of sketcher
                                    this certain house was build in sketchup afaik ... and it's awesome
                                    • W Offline
                                      wannabe
                                      no idea who made this asian-ish scene?
                                        It's one in a series of epic models called Eye Candy by Silver Shadow
                                        http://forums.sketchucation.com/viewtopic.php?f=81&t=10549&hilit=Candy
                                        I'd advise you read every page because you might find a link to the model πŸ˜‰
                                        • W Offline
                                          wannabe
                                          thank you soo much ... have been searching this for a long time
                                            Don't thank me. It's an inspirational thread that the whole SU Community benefits from.
                                            • 2 / 2
