    CatchUp Edition 4
    38 Posts 12 Posters 30.3k Views 12 Watching
      Sorted
        πŸ‘
          Have anyone used this package?
          http://sketch3d.dynascape.com/Components/ComponentCategories.aspx
            SketchUpNoobie
            Awesome! πŸ˜‰ Thanks to everyone who helped on this one! Great job. πŸ‘
            SketchUpNoobie: the complete noob in all things SketchUp.
              d12dozr
              Excellent issue again, guys. Great, great content and editing πŸ‘
              The link to the survey from the flipping page format is still broken...the problem is that the "monkey" part of the URL is spelled "monket"
              It currently is: http://www.surveymonket.com/s/NH7KY5B
              It should be: http://www.surveymonkey.com/s/NH7KY5B
              http://goo.gl/f7ooYh
                The older Interactive PDF had a funky link. The newer one doesn't. The Flipping Page takes a few hours to update so if you've viewed there you're getting the old link.
                Thanks for the comments anyway πŸ‘
                • K
                  Khai
                  any chance of a direct download link? (right clicking the download link goes to "index.html" and I've never had any luck loading PDF's into Firefox....)
                  • marvins_dadM
                    marvins_dad
                    Another great one guys!
                    Might have to check out that Mouse that Mike reviewed.
                    My Gallery
                    • GaieusG
                      That's a simple redirect link (we only use it for being able to count downloads). It should launch the pdf file for you (I have also set my FF NOT to launch it in the browser but to download them instead).
                      If you right click on that index page and have a look at the source code, you will see the direct link.
                      πŸ˜‰
                        Wait til next edition as we'll be doing a more indepth test
                          You can download the PDF on the Issuu site.
                            Go here...
                            http://issuu.com/rclub24/docs/catchup_4
                            ...and press this button
                              That requires you to have a login/password!
                              • K
                                Khai
                                yes.. it does..
                                in the end, I started the index page, copied the URL that FF crashed on before it crashed and used that to download the PDF.
                                  That's a shit feature πŸ‘Ž
                                  For those who still need to bypass the redirect link (even though it helps us track stats) just click the red catchup button at the top of the page....here.... πŸ˜’
                                  • K
                                    Khai
                                    it's not that I don't want to help you track stats on this. it's I can't get to read it otherwise... (I've never worked out why my firefox hates PDF's. I've tried 2/3/4/5/6/Aurora, Adobe/Foxit/etc... FF will start loading it and just carry on forever loading.... I have to download the PDF and then read it in FF or Foxit..)
                                      That linked PDF has not got any 'Save' option toolbars either, or at least not in Acrobat Reader X embedded in FireFox 6.
                                      I use the FireFox Add-on 'DownloadThemAll', which let's you download things like PDFs and images that are otherwise not accessible in the browser window...
                                      You can always use File...SaveAs... menu option too and change to AllFileTypes and edit the suffix to .PDF - it then downloads OK too.
                                        PDF X-Change Viewer integrates with FF and is much light than that Adobe beast
                                          This should work...
                                          Close FireFox and open 'Adobe Reader X'.
                                          From the edit menu open up 'Preferences'.
                                          Click on the "Internet" settings and uncheck the box "Display in Read Mode by default".
                                          As a precaution, go to the "Document" settings and make sure that the box "Allow documents to hide the menubar, toolbars, and window-controls" is also unchecked.
                                          Click OK and close Adobe Reader X.
                                          Just to make sure, open Adobe Reader X and close it again.
                                          Now the print, save buttons etc... should be visible in Adobe Reader X, inside the browser next time you run FireFox.
                                          BUT it is flaky!
                                          • pbacotP
                                            Thanks guys,
                                            Another great issue.
                                            Two things:
                                            1. I find when I get to the lumenRT ad in the page turner edition, clicking on the page turner arrow takes me to the Lumen site, doesn't turn the page. Arrow key works OK.
                                            2. In the survey you don't say what period you are proposing for the donation amounts.
                                            Peter
