    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      boestin
      Hello Gaieus,
      Thank you for you reply.
      I dont know how I can check that, I am almost sure that it is the top side because when I draw a rectangle, select it and generate fur on this I am in the Top view camera.
        When you draw a rectangle on the red/green plane, its back face (blue colour) is showing up by default. Right click and reverse faces to change that and now the front face (white) will show upwards.
        I am not sure this is the problem but I can imagine.
          boestin
          Thanks Gaieus!! That was the problem
          You made my day!!
            sectionaa
            @fletch said:
            JC,
            Does THIS help at all?
            http://twilightrender.com/phpBB3/download/file.php?id=3803
            Very useful indeed.
            There must be a variable not shown in settings dialog which controls rotation on a specified axis.
            (The default effect is visible in the road signs image).
            It would be a great benefit to have that variable available, and a "jitter" control.
            But the author has done a fantastic job.
              sectionaa
              @gaieus said:
              Yeah. Though already a minority of the countries, still "the sun never sets over the countries that drive on the left".
              πŸ˜„
              And of course the land of the rising sun drives on the left.
              • brodieB Offline
                brodie
                I downloaded the plugin and extracted it to my plugins folder (SU 😎 and now get a runtime error anytime I open SU. Anyone else have this issue or have a solution?
                -Brodie
                  Taavi K
                  I ran into small problem. What can I do to lose that ... problem?
                    sesil5
                    goodmorning!! i need your help!
                    How can i download this plugin?
                      Hi Sesil,
                      It is posted as an attachment at the bottom of the first post.
                        sesil5
                        @gaieus said:
                        Hi Sesil,
                        Hi Gaieus, i found the zip file but it doesn't contains any runfile for installation. Sorry for my English,i'm from Greece.
                        Nevertheless, thank you very much.
                          SketchUp plugins are 8mostly) simple text files with an rb (for "ruby") extension. All you need to do is to extract all the content and then copy everything into the plugins folder of SketchUp which is by default (on a 32 bit windows) here:
                          C:\Program Files\Google\Google SketchUp 8\Plugins\
                          Also, here is a sticky post about the installation of zipped plugins:
                          http://forums.sketchucation.com/viewtopic.php?f=323&t=35746
                            sesil5
                            It's work!!! Thank you very very much. I use some other plugins like omnigrid plugin and it was necessary to make an installation. I think that i'm comfused about the programms and the plugins!!!!
                              dirtypr
                              This is great!
                                brokenstaral
                                awsome!!
                                so simple and easy to operate!!
                                This is by far one of the best and most useful plugins I have ever seen !!!!!
                                • U Offline
                                  uzairazam
                                  i am unable to create furs....when i click make fur....nothing happens....what is wrong with it plz help?
                                    mazureac
                                    Thanks for a super plugin!
                                      torring
                                      Great plugin!
                                        stef52
                                        Hello!
                                        i have a little problem with a piece of a terrain shaped with the sand box; what can i do to have a regular surface of grass instead of this triangulated one?
                                        http://img11.hostingpics.net/thumbs/mini_12231297gg.png
                                          tak2hata
                                          Hi,stef52.
                                          @stef52 said:
                                          Hello!
                                          I think inputing larger number to "MaxNumber(/Face)" in dialog will improve the problem.
                                          How is it?
                                          Please reply if it does not improve the problem.
                                          Thanks.
                                          by TAK2HATA
                                          • eidam655E Offline
                                            eidam655
                                            hello,
                                            thanks for the plugin, grass making is now really easy (and by using component grass, it's also super fast as well!) πŸ˜„
                                            however, i have a question (a feature request): would it be possible to implement distributing by a B&W texture, or with an exponential fall-off (especially useful with the Valid Distance option)
                                            thanks for answers and i wish you good luck πŸ˜„
                                            I'm using SketchUp 2017, V-Ray 3.4
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 32
                                            • 33
                                            • 15 / 33
