    Sky Input - In Sketchup or Photoshop?
    renderpluginsextensions
    17 Posts 7 Posters 7.6k Views 7 Watching
    • andybotA Offline
      andybot
      If you save the image as png format - those windows will be transparent in the png file, you don't have to use the alpha mask.
      • V Offline
        valerostudio
        I agree, save as PNG but also make sure you are saving the Alpha Channels in your options and not just the RGB. This is on by default, so if you havent messed with it, than you should be fine. I recommend spending a few bucks on some HQ HDRI images and use those for your GI and BG coupled with the sun system for some casted shadowing. Fernando has a tutorial on Youtube on the trick to accomplish this. I use Peter Gunthrie's HDRIs which are fantastic. You can buy them for $25 each at 3DOcean. Well worth it. I own a few different ones. They also come with high res backplates so you can insert them in Photoshop. Hope this helps.
          castromann
          thy so much for your quick answers, but unfortunately thats not true. in the png only the areas that are not covered by windows are transparent... at the moment i can still see the environment background from the render through them ;-( the transparency of the png is exactly the same as the alpha mask.
          i now try to render a separate "background" channel and see what that will give.
          any other ideas of what i´m doing wrong or can be done?
          i own quite a few hdris already. i saw the ones from peter gunthrie - they are great! thx for your recommendations.
          edit: btw - do you know if vray accepts .exr files in the environment slots?
            castromann
            the background channel didn´t help either ;-(
            • andybotA Offline
              andybot
              Here is an example of a png image rendered with the alpha channel. You can see the before and after, I have glass that has a slight reflection and is not 100% transparent. I can place the sky behind with no problems. Not sure what is different with your render. Do you want to post an image or perhaps your vismat?
                castromann
                i found out how to do it - if someone else is interested - its explained by fernando in this video: http://www.youtube.com/user/asgvis#p/search/0/PjbrGcbzyjY
                you have to check affect alpha in the materials refraction layer to make it work!!!
                @andybot: thx for your example this is exactly the effect i was looking for, but it didn´t work because of the above.
                • andybotA Offline
                  andybot
                  makes sense. I use a vismat for glass based on a version I've modified from the asgvis site. It must have that already checked. I think that's only an issue if you use a refraction layer. semi-transparent materials without refraction should work fine.
                    castromann
                    ok - here´s a follow up to the last problem. as discussed before i got the alpha to be transparent behind the window with the "affect alpha" checkbox in the glass materials reflection layer.
                    unfortunatley i ran into an new problem with that kind of setting. to understand you maybe have to know i´m using the vray sun and hdri method trick with the unchecked reflection slot in the environment rollout. now when i try to put my backdrop behind the model in photoshop the glass seems to lose its reflections in the areas where the background shines through the window. looks not very nice and destroys the illusion of photorealism. in fernandos tutorial on youtube the reflections seem to stay. i tried so many things in the meanwhile that i think even if the solution was obvious i wouldn´t get it anymore.
                    another minor thing that happens when you save to png are the sharp white borders around the model you get in the alpha channel of the png. funny thing, if you crop the model to the alpha pass (not the alpha mask of the diffuse png)you can get rid of them easily.
                    if it´s uncelar what i´m talking about let me know and i´ll try to illustrate my problem with some pics tomorrow.
                    again thx for any pointing into the right direction!
                    • fuzzionF Offline
                      fuzzion
                      1)Get extremely high res commercial HDRI. VFSU sky isnt really as good as v.high HDRI for photo realism.
                      2)Use as sphere env.
                      3)VFSU 2.0 will have positional setting for env, current version = no so its trial and error. Hence Photoshop is prefered by some.
                      "Only the dead have seen the end of war" - Plato
                        castromann
                        thx fuzzion but the usage of hdris is not my actual problem. to clearify see the following pictures:
                        as you can see the lack of reflections in the second example makes it impossible to use an alternate BG in photoshop as it looks simply wrong.
                        grateful for your help!
                        • andybotA Offline
                          andybot
                          One thing you might try is to use material ID for the glass, and that way you get a channel you can control for the transparency of your glass/ background. You could mask your background with this channel and adjust the strength of how much you can see the background through the window.
                          Andy
                            castromann
                            you´re right andybot. i now changed my glass material as i seem to have less problems when using a material without refraction (as you mentioned already). with creating a materialID it should be no big problem to get rid of this problem in photoshop.
                            thx a lot for your support.
                              apple85
                              where do you locate the alpha channel to turn on and off with vray 3 on sketchup?
                              I try to save as a tif or png with my sky but get a transparent background - jpeg I have no problems but you don't save in jpeg if you can help it.
                              Im pulling my hair out on this one looking for this needle
