    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.8m Views 329 Watching
      cancincon
      @thomthom said:
      Did you perhaps select a group instead?
      hmm...maybe...
      well i am not even sure, i just made a cylinder and clicked on it with selection tool so it turns blue (so this is where i thought i selected it)
      Sorry, i know it sounds stupid but i would still appreciate some pointers about how to use this plug-in : (
      • TIGT Online
        You need a 'Group' of geometry that you want to 'bend', a straight 'Line' parallel with the X-axis [Red] that determines the extents of the bending [note that this line cannor be connected to anything else!] and a 'curve' [i.e. an Arc, Bezier or collection of Edges 'Welded' into a Curve] that the bend will follow.
        To make a group select your required geometry [e.g. your cylinder] right-click and 'Make Group'; it now selects as a single object because the geometry is inside it [you can also use a component-instance instead of a group - then use 'Make Component'!]...
        The relative placement of the group[or component], the line and the curve affect the resultant bending.
        Select the group[or component] and start the 'Shape Bender' tool.
        Follow the prompts - pick the line - then pick the curve - swap the start/end with arrow-keys IF required [e.g. the ghost-image of the potential bent result looks 'twisted'].
        Press <enter> and the group is copied in a 'bent' form, as a new 'shape bender component'...Capture.PNG
          You made a cylinder - as in you drew a circle and push-pulled it? Then what? Did you group it or make it into a component?
            cancincon
            Press <enter> and the group is copied in a 'bent' form, as a new 'shape bender component'...[attachment=0:31120sgk]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:31120sgk]
            Phew...that did it
            Thanks to everyone who bothered to give an answer, I appreciate it : ))
              avraz
              first of all thanks alot for your work -i just bought your repeat copy plug for landscaping and im very happy with it
              i also got the shape bender which i really enjoy playing with .
              the problem is-it works on 2 computers in version 7 but on my version 8 which i got alot of plugins installed in it , as soon as i pick the component and the 2 lines it starting to process and get stuck on 1-7% and writes that it is looking for components to explode
              i tried with a component and with a group i tried reenstalling it ,the shapes i used r as simple as they come and my computer is very strong
              my best guess is that is is clashing with another plugin
              i got about 100 plugins so if you know of such plug that might be causing such a problem it will help alot
              • TIGT Online
                Have you installed progressbar.rb on both PCs ?
                  avraz
                  yes i did
                  on the same computer i got v7 that works but got very few plugs in its library and v8 with alot of plugs that doesnt work correctly
                    araz
                    @tobobo said:
                    Do you have to mist uptodate Compent Spray plugin?, as i believe there is a clash with bender and the previous plugin.
                    i removed the component spray and it worked
                    thanks alot for the advice-problem solved
                    • ToboboT Offline
                      Tobobo
                      Do you have the most up to date Compent Spray plugin? as i believe there is a clash with bender and the previous version of the plugin.
                      Toby
                      Philippians 4:13
                      • ToboboT Offline
                        Tobobo
                        the new version of component spray works with the bender plugin
                        Apologise for the poor typing, i've corrected the post 😳
                        Toby
                        Philippians 4:13
                        • O Offline
                          onezero
                          @tig said:
                          You have unzipped the files into folder named after the zip and moved that folder into Plugins.
                          The only shape bender related stuff you should have in Plugins is the loader rb file and the subfolder, like this [attachment=0:2fm4zizk]<!-- ia0 -->Capture1.PNG<!-- ia0 -->[/attachment:2fm4zizk] and that subfolder should contain these files [attachment=1:2fm4zizk]<!-- ia1 -->Capture.PNG<!-- ia1 -->[/attachment:2fm4zizk] I.E. you move the file and subfolder that were in the zip into Plugins AND NOT the unzipped folder [clf_shape_bender_v005] itself...
                          Howdy everyone,
                          I'm sort of a newbie to SU. Well, I'm a newbie when it comes to using a MAC and SU. I've played with SU for years on a PC and recently I've made the move to Macintosh ( macbook pro) and the above help from TIG has by far been the most valuable advice and visual guide for getting this plugin to work.
                          I was repeatedly moving the whole zip file folder to the plugins and was absolutely confounded as to why it did not work. I installed and reinstalled again and again with the same result. I never had this frustrating difficulty on a PC.
                          Anyway, THANK YOU TIG and everyone else!! I am now on my way to enjoying (hopefully) the SU experience on my Apple.
                          I wish there was an energetic young person with a lot of time on their hands that could put all the MAC problems into a thread or topic so it would be easier to pinpoint some problems but I know that would be a huge task - just some wishful thinking on my part.
                          Keep up the good work everyone! This is a great website with an absolutely encouraging and positive atmosphere--renews my hope for mankind, in a way. 😄
                            saj33
                            Can somebody help? I've been trying to let my staircase follow a curved path. I selected the component, used the plugin then, when it comes to selecting a line on the red axis, my mouse can't select it. Nothing happens. Note, it does select when I'm not using the plugin. What do you think's the problem?
                            • TIGT Online
                              This line you must pick that is parallel to the red axis must be completely 'unattached' - i.e. it cannot join onto another line, or edge a face etc.
                              It also has to be a piece of separate geometry in the active-entities context [i.e. with the group/component that you want to bend].
                              The same points apply to the 'curve' you will need to pick next...
                                breeze
                                thank you very much
                                  disturbed13
                                  i have an issue
                                  this plug-in doesnt work right
                                  http://i107.photobucket.com/albums/m294/hedoe/myissue.jpg
                                  am i doing something wrong here or what?
                                    Could you post the SKP so we can take a look?
                                      disturbed13
                                      sure some background first so you understand what i am trying to accomplish
                                      im in the process of designing a tree climbing spider robot
                                      and im working on one of the legs, ive decided to have a 'thumb-like' appendage to grasp onto branches in the canopy
                                      now my mind is turning and it would be a good idea to add a saw-tooth like pattern to the inside of each
                                      for better grasping ability
                                      however i cant get the blasted mini pyramids to follow the curve of the main leg
                                      i havent tried the grasping limb yet
                                      the leg
                                      • TIGT Online
                                        The 'line' you are asked to pick initially needs to be parallel to the Red axis and it cannot touch anything else.
                                        Your supplied SKP only has two lines parallel to the Red axis; BUT both of these touch a line drawn on the Green axis, so they won't work!
                                        Erase the connected line and then the Lines parallel to the Red axis will be available and the tool should work.
                                        Note that the length of the 'line' and the 'arc', and the location of them relative to the object that's to be bent will affect the 'bending' - experiment with some different settings... 🤓
                                        • Jean-FrancoJ Offline
                                          Jean-Franco
                                          for me it works as it is in your SU file.
                                          But after you select the curved line and as shown in your picture, you have to play a bit with the Up and down arrows of your keyboard.
                                          Try.
                                          Jean-Franco
                                            gr8fzy1
                                            Can you explain this a little bit more clearly, because I'm having the same problem as saj33.
                                            I have the component all set, so I draw a line on the red axis. I then select the component and it asks me to select the line. But no matter how many times I click on it, it won't let me select the line.
                                            This is a screen shot of the arch I want to bend, the curve I want it to follow, and a dummy line drawn between them to represent the line drawn on the component. None of the lines/components are touching the red or green axis. And you can clearly see the line drawn on the component that I want to use.
                                            But then when I select the component and activate Shape bender, it WILL NOT let me select the drawn line. And I am doing everything as shown in the maker's own video. (The youtube one, 3rd video in his first post)
                                            This is the test file I made to test the plug in.
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 63
                                            • 64
                                            • 34 / 64
