    [Plugin] Greeble 2 released! (Updated August 31st, 2009)
    94 Posts 24 Posters 81.4k Views 24 Watching
      craigcampbell66
      Sketchup 7 windows7 pro 64
      Hi all, I am in need of some advice re the Greeble plugin. I seem to follow the workflow in the tutorials/videos but with no effect. Not a ripple. Have tried on planes/grids/boxes/spheres.
      Any advice appreciated.
      thanks in advance, Craig
        (I am in meters unity)I suppose that is the problem 😉
        I have also nothing when I input inch unity 😉
        surely measures are not accorded and i don't want have an headache for make conversion
        for have the good measures 💚
        so I take meter unity for simplify my life 😄
        Draw a simple box (7,6,4) select it and input numbers as shown
        If you don't obtain something like this there is a problem 😄
        click image for zoom
          craigcampbell66
          Hi, I tried again to use the greeble with the numbers in your parameters. Some success. It ceases to work at all when I input something into the offset parameters. I have tried in on a box and a sphere with the same results.
          I have the offset.rb installed in the plugins folder along with the progressbar.rb and the greeble
          any ideas as to where I am going wrong.
          • bagateloB Offline
            bagatelo
            Please do download the file and see if it is possible to solve my problem. The file was created in the latest version of Sketchup.
            my pain.skp
              This is made with my old Latticeizer script, 3cm frames and default pane with some PudhPull on the panes [with existing lines NOT kept] afterwards...Capture.PNG
              • bagateloB Offline
                bagatelo
                Please note the presentation that I have made in the attached file. That's exactly what I need. In some cases, I do not use handles in aluminum bar. I use ordinary handles. So I do not pull over 3cm from top face to bottom. In some cases, I use different spaces for 0.5cm, as requested by the woodworker or architect that I work. Thank you for your attention.
                One day I will no more bore you, because I'm trying to learn Ruby Script. Thanks.
                WHAT I NEED SKT 7.skp
                  This plug is always very funny ☀
                  • Chris FullmerC Offline
                    Pilou, you crack me up! Great stuff as always.
                    PS - what is your artistic style called, with all the vibrant colors and nonsensical shapes? I thought I remembered you using a term once that I found very interesting.
                      Surely "Flashy" 💚 for the other term I don't remember. 😳
                      Speedy Strange surreal geometrical attractor ? 😄
                      Because I don't spend more ten minutes by scenes! 😒
                      If you have 5 minutes you can see some Zbrush folish 😉
                      (section Zibi Art )
                      PS You have remarked that I have an immoderated use of your crazy "Random Painter" plug with SU 😉
                        Bertier
                        can't get no greeble 😞
                          Go to SMustard 😉 (it's free)
                            Bertier
                            c'est installé avec tout ce qu'il faut mais ça ne fonctionne pas...
                              Can you upload a simple model that you are trying to use it on that is not working? And also possibly open the Ruby Console (from the Window menu) and then run the plugin and see if it displays any errors there. Please paste those errors here.
                              This script does not always behave well...
                                Bertier
                                set to meters as Pilou suggested
                                trying to greeble a simple 100 x 100 square :
                                #Sketchup::Face:0x24e2b624 did not offset:
                                Error: #<NoMethodError: undefined method normal' for nil:NilClass> C:/Program Files/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:250:in greeble'
                                C:/Program Files/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:223:in each' C:/Program Files/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:223:in greeble'
                                C:/Program Files/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:294
                                C:/Program Files/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:250:in `call'
                                  Bertier
                                  The error in line #250 is when it tries to get a normal new_vector = cl_newface.normal and the face cl_newface doesn't exist.
                                  It is made by offsetting e which is one of clface[s] around lines #236 et al...
                                  Not sure what's causing it... Chris?
                                    Bertier
                                    sound chinese to me...
                                      hmm, somehow it is passing a bad vector parameter to the offset script I think.
                                      An example model would be helpful. Could you upload a small test model that is not working right? Thanks!
                                        Avec comme unité les mètres
                                        Essaie avec ces valeur avec une figure qui fait au minimum 100 m par 100 par 100 m !
                                        Pour avoir une extrusion continue
                                        Il faut répondre oui à la question pour faire un "group" de la boite de dialogue une fois le plug lancé
                                        Exploser le groupe résultat et recommencer 😉
                                          About the repetition from the last action : now we must make that
                                          Select faces
                                          begin
                                          Grebble with "Yes I want grouping the all topmost faces"
                                          • else any faces will be not selected for a next grebbling 😲
                                            Result
                                            Explode group = new topmost faces selected ☀
                                            goto begin
                                          it's possible but a little painful 😉
                                          Vieria Da Silva inspiration (cool gallery zoom possible) ☀
                                          Another thing: using the new plug of Selection aera by Sdmitch on a complex Greeble volume
                                          Some faces are selected as wished, but the Greebble makes nothing 😮
                                          Have you some tests inside Grebble for exit if some faces are in particular positions (overlapsed) ?
                                          (make nothing also with normal selection 😒
                                            Pout
                                            Hey Chris, haven't look at it but i read in the previous version of this plugin that you planned on integrating a cancel button to cancel script execution.
                                            Did you find a solution for this?
                                            Thx
                                            • 3 / 5
