    [Plugin] Greeble 2 released! (Updated August 31st, 2009)
    94 Posts 24 Posters 80.5k Views 24 Watching
      So goto the Protrude thread and ask your problem ! ๐Ÿ˜‰
      Maybe it's because you have a Mac ๐Ÿ˜’
      Damned crossing post ๐Ÿ˜’
      • Chris FullmerC Offline
        Ressurecting the dead - or at leas the long forgotten!
        But I've updated this script, and its a big enough update that I thought I'd post and let people know. Two main things are that it now works inside of groups and components and does not cause bug splats! (that was a big bug I never noticed until about 3 weeks ago, oops!). Also, the script remembers your settings between uses (but not between SketchUp sessions).
        So if you have an old copy (include clf_greeble.rb or an old clf_greeble2.rb) please delete them and install this one.
        UPDATE August 31, 2009
        2.20:: 2009-08-31
        • Fixed a MAJOR bug that would cuase SketchUp to crash when greeble was used inside a group or component. So yes, you can now safely use Greeble inside a group or component!
        • Changed some code that should theoretically speed things up ever so slightly....frankly I don't think it helped.
        • Changed some code to make it run smarter, skip certain methods if they were not being executed.
        • Fixed some code that could cause problems when faces would overlap.
          2.21:: 2009-08-31
        • Now user input settings are rembered between script uses.
        Download
        This script is hosted at http://www.smustard.com/script/Greeble2
          skkor9y
          hi,CHRIS your tools are doin magic.
          though my heart was shrunk when two of yr tools didnt worked ...
          but yr solution(to PIBUZ),of updating component spray worked...
          once again thanx..to u and also pibuz
            roytchaikowsky
            This thread cannot be in page 11 man
              Ummm, what?
                It was probably sunken to page 11 of the Ruby Forum. He must have been surprised how that comes although this is such a great plugin
                ๐Ÿ˜‰
                Roy, there IS a reason; this forum is quite active and not only due to the published plugins but also to the technical discussions between the scripters.
                Here is a better (cleaner) list of the plugins published on this forum so far (not totally proof though)
                http://forums.sketchucation.com/search.php?keywords=Plugin&terms=all&author=&sc=1&sf=titleonly&sr=topics&sk=s&sd=a&st=0&ch=300&t=0&submit=Search
                Note that this list spans over 21 pages itself so something inevitably must be below page 10.
                  jhearcht
                  SketchUp 6.4.265 on Windows XP
                  As a newbie, apparently I'm missing something that a more experienced modeler would take for granted.
                  I downloaded Greeble 2, along with Progress Bar and Offset. Put them in the Plug-ins folder. After a re-start, "Chris Fullmer Tools" appears in Plug-ins menu.
                  I select a grouped rectangular box with Juniper vegetation texture. I want to add some roughness to the surface. So I select the Greeble tool and enter some numbers. After clicking OK, nothing happens. I also trying selecting just one surface, but no go.
                  I was assuming the tool would draw a 2D grid with my +/- dimensions, then pull each piece up to a random height. If I could get some kind of response, I could then play with the numbers to get the look I want : pointy pyramids may do the trick.
                  Do I need to draw a grid before selecting the tool? Is there an auto grid tool? Should I greeble one face at a time? What do I need to do before invoking the Greeble tool?
                  Thanks for covering my ignorance with your intelligence. ๐Ÿ˜„
                    Hi jhearcht, it should work. But it does require a grid be drawn first. It will extrude each face, so if you just have one large face, it can extrude that face only. If you have a thousand faces, it then extrudes all those faces.
                    As a note, this plugin is apparently broken with SketchUp version 8.0 for now. I need to look into a fix for it. (but it should be working with version 6.x like you have).
                    You could upload your model and I'll see if I can play with it and see if there is some odd error if that would help,
                      Funny I just reply there โ˜€
                        craigcampbell66
                        Sketchup 7 windows7 pro 64
                        Hi all, I am in need of some advice re the Greeble plugin. I seem to follow the workflow in the tutorials/videos but with no effect. Not a ripple. Have tried on planes/grids/boxes/spheres.
                        Any advice appreciated.
                        thanks in advance, Craig
                          (I am in meters unity)I suppose that is the problem ๐Ÿ˜‰
                          I have also nothing when I input inch unity ๐Ÿ˜‰
                          surely measures are not accorded and i don't want have an headache for make conversion
                          for have the good measures ๐Ÿ’š
                          so I take meter unity for simplify my life ๐Ÿ˜„
                          Draw a simple box (7,6,4) select it and input numbers as shown
                          If you don't obtain something like this there is a problem ๐Ÿ˜„
                          click image for zoom
                            craigcampbell66
                            Hi, I tried again to use the greeble with the numbers in your parameters. Some success. It ceases to work at all when I input something into the offset parameters. I have tried in on a box and a sphere with the same results.
                            I have the offset.rb installed in the plugins folder along with the progressbar.rb and the greeble
                            any ideas as to where I am going wrong.
                            • bagateloB Offline
                              bagatelo
                              Please do download the file and see if it is possible to solve my problem. The file was created in the latest version of Sketchup.
                              my pain.skp
                                This is made with my old Latticeizer script, 3cm frames and default pane with some PudhPull on the panes [with existing lines NOT kept] afterwards...Capture.PNG
                                • bagateloB Offline
                                  bagatelo
                                  Please note the presentation that I have made in the attached file. That's exactly what I need. In some cases, I do not use handles in aluminum bar. I use ordinary handles. So I do not pull over 3cm from top face to bottom. In some cases, I use different spaces for 0.5cm, as requested by the woodworker or architect that I work. Thank you for your attention.
                                  One day I will no more bore you, because I'm trying to learn Ruby Script. Thanks.
                                  WHAT I NEED SKT 7.skp
                                    This plug is always very funny โ˜€
                                      Pilou, you crack me up! Great stuff as always.
                                      PS - what is your artistic style called, with all the vibrant colors and nonsensical shapes? I thought I remembered you using a term once that I found very interesting.
                                        Surely "Flashy" ๐Ÿ’š for the other term I don't remember. ๐Ÿ˜ณ
                                        Speedy Strange surreal geometrical attractor ? ๐Ÿ˜„
                                        Because I don't spend more ten minutes by scenes! ๐Ÿ˜’
                                        If you have 5 minutes you can see some Zbrush folish ๐Ÿ˜‰
                                        (section Zibi Art )
                                        PS You have remarked that I have an immoderated use of your crazy "Random Painter" plug with SU ๐Ÿ˜‰
                                          Bertier
                                          can't get no greeble ๐Ÿ˜ž
                                            Go to SMustard ๐Ÿ˜‰ (it's free)
                                            • 3 / 5
