    Show Me Your SketchUp
    114 Posts 74 Posters 64.4k Views 74 Watching
    • V Offline
      Vicspa
      This is what works for me at this time.
      • Bryan KB Offline
          Panga
          And here is my SU workspace :
          And my plugin folder :
          These screenshots was made after a recent reinstall, so all the plugin i'm using are not present, only the most used.
          Regards.
          • leedeeteeL Offline
            leedeetee
            Here's mine. Nothing too fancy...
              And where is that screenshot, Gavin?
              • ToboboT Offline
                Tobobo
                Better late than never. 😳
                Toby
                Philippians 4:13
                  @Tobobo: It looks like you have some stray files in your plugin folder that are not located where they should. In particular there seems to be files related to VfSU scattered.
                  With the latest version, 1.49.01, only vfs.rb is located in the Plugins folder.
                  (Plus you have many redundant folders of older versions of Fredo's plugins.)
                  • ToboboT Offline
                    Tobobo
                    Yeah I know that but I'm dont want to go deleting the wrong ones.
                    If you can help in pointing out the redundant ones I would be very grateful.
                    I'm having some real problems with VRay at the moment. IT are being slow in resolving online validation problems. 😑
                    Toby
                    Philippians 4:13
                    • F Offline
                      fransko
                      this is my desktop i working on a game
                      • brodieB Offline
                        brodie
                        John's minimalistic UI is my dream, but I'm not quite there yet. I have dual monitors at 1920x1080 so I had to reduce the resolution of the screenshot. The only icons most people won't recognize are the last several icons which consist of my Maxwell Render toolbar.
                        As you can see I have a number of plugins (I pare this down periodically so most of the ones on there I use on a regular basis) but I prefer to use keyboard shortcuts. I'd use shortcuts for the remaining toolbars but at this point I'd have to use keyboard combos that wouldn't make much sense and would end up wasting time trying to figure out what the combo is.
                        I'm surprised by how many people here use one monitor (so the menus get in the way) and have TONS of icons. That sort of setup would drive my crazy.
                        You'll also notice if you look real close, that I have my plugins folder in Dropbox so my plugins are synced between my computers.
                        -Brodie
                          julyyen
                          ...and mine.
                          • GwyattG Offline
                            Gwyatt
                            Greetings all only fair i post My Sketchup as per request
                            Sorry mis clicked didnt up load it
                            GW Sketchup
                              Goonster
                              Compared to some of the others mine is positively barren. But I very much doubt I would need or use all of those plug ins anyway.
                              http://i530.photobucket.com/albums/dd349/G00nster/Miscellaneous/MySketchup.jpg
                                pfnt
                                I have found this thread very interesting as it shows work flow vs. real estate. Here is my real estate...
                                The Real Estate Division
                                Supporting Files
                                  Sir
                                  I know the shortcuts for all the stuff i use
                                  http://img90.imageshack.us/img90/4497/unled1ta.jpg
                                    This is after I opened SU > Pressed the "Display desktop" button in my tray before SU fully loaded then found SU with my toolbars completelymessed up and then I reset the toolbar positions. Still quite messy (and sorry for the OT post John, but this is also"My SketchUp") πŸ˜†
                                    • jason_marantoJ Offline
                                      jason_maranto
                                      I use the various inspector as I need them but do not keep anything but these toolbars open "all the time".
                                      Best,
                                      Jason.
                                        swagen
                                        I suggest you guys also show up your "hotkeys" too. Having a good hotkey combination would speed up your progress a lot
                                          Matt666
                                          Here's mine.
                                          I have 2 plugins folders 😳 because I share some plugins with other computers at work. When I upgrade a plugin, everybody can use it. I use Native plugins folder for plugins I can't modify, and new plugins I test.
                                          πŸ˜‰
                                          Frenglish at its best !
                                          My scripts
                                          • kaluK Offline
                                            kalu
                                            here's my laptop setup.. i have a couple of more toolbars showing on the other computer.
                                            [attachment=1:3i0a61fs]<!-- ia1 -->sketchupscreen_1.jpg<!-- ia1 -->[/attachment:3i0a61fs]
                                            [attachment=0:3i0a61fs]<!-- ia0 -->screen 2011-06-04 at 1.41.46 AM.jpg<!-- ia0 -->[/attachment:3i0a61fs]
                                            Hello Jeff, how you make possible to have all this toolbars rows in sketchup for mac?
                                            THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
                                            • 4 / 6
