[Plugin Library] LibFredo6 - v14.5b - 24 May 24
Antuan
Can you open the Default Parameters dialog box for LibFredo6 and for my other plugins (if you have some installed)?
Fredo,
No, I can´t. I have installed FredoScale, ToolsOnSurface and Round Corner. None of them opens the Default parameter dialog.(e.g. Tools-Fredo6 Collection-ToolsOnFace-Default Parameters... does nothing, same for FredoScale or Round Corner) And the same for LibFredo6 library, through Window-LibFredo6 Settings-Default Paramenters... nothing happens. But as I said before other dialog boxes open normally (Check for update or Language Translation), and if I copy for example FredoScale.def from the still existing SU 7 files tree to the SU8 DEFPARAM-DIR directory I see that is detected because the changes take effect (i.e. change of the toolbar icons, etc.). The problem is about the dialog box itself, it doesn´t open no matter how I try. I am missing something? Any way, with older versions of same plugins everything works, both in SU 7 or 8.
Thank you for your help. -
beautifull man... 10+/10
Perfect~Thank you~!
Downloaded and installed the latest version but it does not show up in SU. I copied both the LIBFREDO6_Dir_37 folder and the LibFredo6.rb into the plug ins folder as shown but it just won`t show. I thought the .rb file might need unblocking - which I did. But still no joy. I already have the Fredoscale plug in which works fine.
Any ideas?I use Win7 Home Premium 64bit with SU8.
LibFredo6 is not really a plugin but a library.
Since you have FredoScale working fine, from what you say, it means you have a version of LibFredo6 installed.
Can you check the menu Windows > LibFredo6 Settings... > AboutFredo
Sorted it. I downloaded LibFredo6 3.7b but forgot to download the actual plug in! Sorry.
Hi Fredo,
I have been getting the following errors when I try to check plugins for updates.
I click on the red ruby icon and nothing happens (the update window doesn't come up)
and I get the following in the ruby console:C;/Program Files/Google/Google SketchUp 8/Plugins/ruby/singleton.rb;84; warning; already initialized constant FirstInstanceCall C;/Documents and Settings/All Users/Application Data/ASGVIS/VfS/Ruby/VfSObservers.rb;307; warning; don't put space before argument parentheses C;/Program Files/Google/Google SketchUp 8/Plugins/ruby/singleton.rb;84; warning; already initialized constant FirstInstanceCall
The last thing I did, which may have caused this was install GhostComp 1.0 - but I have tried removing it and the error still comes up.
Any ideas?edit: If I click on "check updates" through the menus, everything works... it's just through the ruby button that it gives errors.
edit2: Forgive me! I think I confused your update plugins ruby (which is part of libfredo) with a different ruby that has the same "ruby" icon which is called Autoloader.... so never mind! my bad!
everything is working fine!! -
Apologies if this has been answered already, I'm getting this when I start sketchup. Is there a simple fix. Apple imac, SU7.
There must currently be some permissions set that prevent you making folders/files in that location - either fix the permissions so you can [advisable]... OR make the folder that is needed... as clearly spelled out in the message
I have problems with the update option too... Every time that I want to go to "Check Plugins for Update" nothing happens. If I have the ruby console open it says:
Error; #<RangeError; 9947298230.424000 out of Time range> C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;677;in `at' C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;677;in `tip_next_date' C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;642;in `format_html_top' C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;225;in `refresh_dialog_top' C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;520;in `create_dialog_top' C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;151;in `initialize' C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;79;in `new' C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;79;in `top_dialog' C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Plugin.rb;195;in `populate_support_menu' C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Traductor.rb;908;in `call' C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Traductor.rb;908;in `add_command'
Any idea what´s happening?
Daniel S
Daniel,
two questions
How many days did you set the "next check" in the dialog box
Can you type the following command in the Ruby Console:
Upgrade.duration_next_check
- How many days did you set the "next check" in the dialog box
I put 999 the first time because I wanted to do a manual check. But then the update option stop working.
I try deleting and reinstalling Libfredo6 but the problem was still there.
Now In default parameters "Next Check in (days)" says 15. But I´m not able to check.@unknownuser said:
- Can you type the following command in the Ruby Console:
I tried and give different results. It says:
Upgrade.duration_next_check Error; #<NameError; (eval);157; uninitialized constant Upgrade> (eval);157
Upgrade.duration_next_check Error; #<NameError; (eval);677; uninitialized constant Upgrade> (eval);677
or:
Upgrade.duration_next_check Error; #<NameError; (eval);54; uninitialized constant Upgrade> (eval);54 (eval);1; warning; Float 0.0 out of range
Daniel S
Daniel,
Sorry I meant
Traductor::Upgrade.duration_next_check
When I put:
it says:Traductor;;Upgrade.duration_next_check 99999.0
Daniel S
Daniel,
This is where is the problem: 99999 is too big for a number of days.
Can you change it in the default parameters or in the Upgrade dialog box
I'll put a check in a next releaseFredo
FredoI can´t change the 99999 because:
- The Upgrade dialog box don´t open
- In default Parameters I can change it but it doesn´t really change.
In the attach video I show what happens.
I tried reinstalling LibFredo6 but still no work.
Daniel S
Updated version of the Italian Translation of Fredo6 Library
Daniel S
If you feel up to adding one line of code into a rb file using a plain text-editor like Notepad[++].exe... find this file open it and add this line and save it Then you can't wait more than a year [365 days]
Daniel S
Daniel,
I published a new release that should fix the issue.
