    [Plugin Library] LibFredo6 - v16.1a - 31 Aug 26
    2.2k Posts 580 Posters 6.6m Views 582 Watching
      antuan
      Fredo,
      No, I can´t. I have installed FredoScale, ToolsOnSurface and Round Corner. None of them opens the Default parameter dialog.(e.g. Tools-Fredo6 Collection-ToolsOnFace-Default Parameters... does nothing, same for FredoScale or Round Corner) And the same for LibFredo6 library, through Window-LibFredo6 Settings-Default Paramenters... nothing happens. But as I said before other dialog boxes open normally (Check for update or Language Translation), and if I copy for example FredoScale.def from the still existing SU 7 files tree to the SU8 DEFPARAM-DIR directory I see that is detected because the changes take effect (i.e. change of the toolbar icons, etc.). The problem is about the dialog box itself, it doesn´t open no matter how I try. I am missing something? Any way, with older versions of same plugins everything works, both in SU 7 or 8.
      Thank you for your help.
        mfarooqi
        beautifull man... 10+/10
          rjjvirusx
          Perfect~Thank you~!
            Goonster
            Downloaded and installed the latest version but it does not show up in SU. I copied both the LIBFREDO6_Dir_37 folder and the LibFredo6.rb into the plug ins folder as shown but it just won`t show. I thought the .rb file might need unblocking - which I did. But still no joy. I already have the Fredoscale plug in which works fine.
            Any ideas?
            I use Win7 Home Premium 64bit with SU8.
            • fredo6F Offline
              Any ideas?
              LibFredo6 is not really a plugin but a library.
              Since you have FredoScale working fine, from what you say, it means you have a version of LibFredo6 installed.
              Can you check the menu Windows > LibFredo6 Settings... > About
                Goonster
                Sorted it. I downloaded LibFredo6 3.7b but forgot to download the actual plug in! Sorry. 😳
                • halroachH Offline
                  halroach
                  Hi Fredo,
                  I have been getting the following errors when I try to check plugins for updates.
                  I click on the red ruby icon and nothing happens (the update window doesn't come up)
                  and I get the following in the ruby console:
                  C;/Program Files/Google/Google SketchUp 8/Plugins/ruby/singleton.rb;84; warning; already initialized constant FirstInstanceCall
                  C;/Documents and Settings/All Users/Application Data/ASGVIS/VfS/Ruby/VfSObservers.rb;307; warning; don't put space before argument parentheses
                  The last thing I did, which may have caused this was install GhostComp 1.0 - but I have tried removing it and the error still comes up.
                  Any ideas?
                  edit: If I click on "check updates" through the menus, everything works... it's just through the ruby button that it gives errors.
                  edit2: Forgive me! I think I confused your update plugins ruby (which is part of libfredo) with a different ruby that has the same "ruby" icon which is called Autoloader.... so never mind! my bad!
                  everything is working fine!!
                  FlexTools - Super Quick Windows, Doors, Slats...
                    Ands43
                    Apologies if this has been answered already, I'm getting this when I start sketchup. Is there a simple fix. Apple imac, SU7.
                      There must currently be some permissions set that prevent you making folders/files in that location - either fix the permissions so you can [advisable]... OR make the folder that is needed... as clearly spelled out in the message 😒
                        Daniel S
                        I have problems with the update option too... Every time that I want to go to "Check Plugins for Update" nothing happens. If I have the ruby console open it says:
                        Error; #<RangeError; 9947298230.424000 out of Time range>
                        C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;677;in `at'
                        C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;677;in `tip_next_date'
                        C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;642;in `format_html_top'
                        C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;225;in `refresh_dialog_top'
                        C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;520;in `create_dialog_top'
                        C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;151;in `initialize'
                        C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;79;in `new'
                        C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;79;in `top_dialog'
                        C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Plugin.rb;195;in `populate_support_menu'
                        C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Traductor.rb;908;in `call'
                        C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Traductor.rb;908;in `add_command'
                        Any idea what´s happening?
                        Daniel S
                        • fredo6F Offline
                          Daniel,
                          two questions
                          1. How many days did you set the "next check" in the dialog box
                          2. Can you type the following command in the Ruby Console: Upgrade.duration_next_check
                            Daniel S
                            I put 999 the first time because I wanted to do a manual check. But then the update option stop working.
                            I try deleting and reinstalling Libfredo6 but the problem was still there.
                            Now In default parameters "Next Check in (days)" says 15. But I´m not able to check.
                            1. Can you type the following command in the Ruby Console: Upgrade.duration_next_check
                            I tried and give different results. It says:
                            Error; #<NameError; (eval);157; uninitialized constant Upgrade>
                            (eval);157
                            Error; #<NameError; (eval);677; uninitialized constant Upgrade>
                            (eval);677
                            or:
                            Error; #<NameError; (eval);54; uninitialized constant Upgrade>
                            (eval);54
                            (eval);1; warning; Float 0.0 out of range
                            Daniel S
                            • fredo6F Offline
                              Daniel,
                              Sorry I meant Traductor::Upgrade.duration_next_check
                                Daniel S
                                When I put:
                                it says:
                                Traductor;;Upgrade.duration_next_check
                                99999.0
                                Daniel S
                                • fredo6F Offline
                                  Daniel,
                                  This is where is the problem: 99999 is too big for a number of days.
                                  Can you change it in the default parameters or in the Upgrade dialog box
                                  I'll put a check in a next release
                                    Daniel S
                                    I can´t change the 99999 because:
                                    • The Upgrade dialog box don´t open
                                    • In default Parameters I can change it but it doesn´t really change.
                                      In the attach video I show what happens.
                                    I tried reinstalling LibFredo6 but still no work.
                                    Daniel S
                                    cant change.zip
                                    • COSEDIMARCOC Offline
                                      COSEDIMARCO
                                      Updated version of the Italian Translation of Fredo6 Library
                                      [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
                                          Daniel S
                                        If you feel up to adding one line of code into a rb file using a plain text-editor like Notepad[++].exe... find this file Capture1.PNG open it and add this line and save it Capture.PNG Then you can't wait more than a year [365 days]
                                        • fredo6F Offline
                                          Daniel S
                                          Daniel,
                                          I published a new release that should fix the issue.
                                          • fredo6F Offline
                                            NEW RELEASELibFredo6 3.7c - 07 Jun 2011
                                            This is a minor maintenance release.
                                            • Fix an issue in CheckForUpdate (next date t check) signaled by Daniel S
                                            • Updated Italian translation by COSEDIMARCO
                                            • Updated Spanish transaltion by Defisto
                                            New release is available for download in the first post of this thread.
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 111
                                            • 112
                                            • 14 / 112
