    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
      antuan
      Thomthom,
      Sorry for the delayed reply. No messages in the ruby console when trying to open the Default Parameters dialog box. Any one found this problem?
      • fredo6F Offline
        Antuan
        Can you open the Default Parameters dialog box for LibFredo6 and for my other plugins (if you have some installed)?
          antuan
          Fredo,
          No, I can´t. I have installed FredoScale, ToolsOnSurface and Round Corner. None of them opens the Default parameter dialog.(e.g. Tools-Fredo6 Collection-ToolsOnFace-Default Parameters... does nothing, same for FredoScale or Round Corner) And the same for LibFredo6 library, through Window-LibFredo6 Settings-Default Paramenters... nothing happens. But as I said before other dialog boxes open normally (Check for update or Language Translation), and if I copy for example FredoScale.def from the still existing SU 7 files tree to the SU8 DEFPARAM-DIR directory I see that is detected because the changes take effect (i.e. change of the toolbar icons, etc.). The problem is about the dialog box itself, it doesn´t open no matter how I try. I am missing something? Any way, with older versions of same plugins everything works, both in SU 7 or 8.
          Thank you for your help.
            mfarooqi
            beautifull man... 10+/10
              rjjvirusx
              Perfect~Thank you~!
                Goonster
                Downloaded and installed the latest version but it does not show up in SU. I copied both the LIBFREDO6_Dir_37 folder and the LibFredo6.rb into the plug ins folder as shown but it just won`t show. I thought the .rb file might need unblocking - which I did. But still no joy. I already have the Fredoscale plug in which works fine.
                Any ideas?
                I use Win7 Home Premium 64bit with SU8.
                • fredo6F Offline
                  Any ideas?
                  LibFredo6 is not really a plugin but a library.
                  Since you have FredoScale working fine, from what you say, it means you have a version of LibFredo6 installed.
                  Can you check the menu Windows > LibFredo6 Settings... > About
                    Goonster
                    Sorted it. I downloaded LibFredo6 3.7b but forgot to download the actual plug in! Sorry. 😳
                    • halroachH Offline
                      halroach
                      Hi Fredo,
                      I have been getting the following errors when I try to check plugins for updates.
                      I click on the red ruby icon and nothing happens (the update window doesn't come up)
                      and I get the following in the ruby console:
                      C;/Program Files/Google/Google SketchUp 8/Plugins/ruby/singleton.rb;84; warning; already initialized constant FirstInstanceCall
                      C;/Documents and Settings/All Users/Application Data/ASGVIS/VfS/Ruby/VfSObservers.rb;307; warning; don't put space before argument parentheses
                      The last thing I did, which may have caused this was install GhostComp 1.0 - but I have tried removing it and the error still comes up.
                      Any ideas?
                      edit: If I click on "check updates" through the menus, everything works... it's just through the ruby button that it gives errors.
                      edit2: Forgive me! I think I confused your update plugins ruby (which is part of libfredo) with a different ruby that has the same "ruby" icon which is called Autoloader.... so never mind! my bad!
                      everything is working fine!!
                      FlexTools - Super Quick Windows, Doors, Slats...
                        Ands43
                        Apologies if this has been answered already, I'm getting this when I start sketchup. Is there a simple fix. Apple imac, SU7.
                          There must currently be some permissions set that prevent you making folders/files in that location - either fix the permissions so you can [advisable]... OR make the folder that is needed... as clearly spelled out in the message 😒
                            Daniel S
                            I have problems with the update option too... Every time that I want to go to "Check Plugins for Update" nothing happens. If I have the ruby console open it says:
                            Error; #<RangeError; 9947298230.424000 out of Time range>
                            C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;677;in `at'
                            C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;677;in `tip_next_date'
                            C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;642;in `format_html_top'
                            C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;225;in `refresh_dialog_top'
                            C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;520;in `create_dialog_top'
                            C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;151;in `initialize'
                            C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;79;in `new'
                            C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;79;in `top_dialog'
                            C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Plugin.rb;195;in `populate_support_menu'
                            C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Traductor.rb;908;in `call'
                            C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Traductor.rb;908;in `add_command'
                            Any idea what´s happening?
                            Daniel S
                            • fredo6F Offline
                              Daniel,
                              two questions
                              1. How many days did you set the "next check" in the dialog box
                              2. Can you type the following command in the Ruby Console: Upgrade.duration_next_check
                                Daniel S
                                I put 999 the first time because I wanted to do a manual check. But then the update option stop working.
                                I try deleting and reinstalling Libfredo6 but the problem was still there.
                                Now In default parameters "Next Check in (days)" says 15. But I´m not able to check.
                                1. Can you type the following command in the Ruby Console: Upgrade.duration_next_check
                                I tried and give different results. It says:
                                Error; #<NameError; (eval);157; uninitialized constant Upgrade>
                                (eval);157
                                Error; #<NameError; (eval);677; uninitialized constant Upgrade>
                                (eval);677
                                or:
                                Error; #<NameError; (eval);54; uninitialized constant Upgrade>
                                (eval);54
                                (eval);1; warning; Float 0.0 out of range
                                Daniel S
                                • fredo6F Offline
                                  Daniel,
                                  Sorry I meant Traductor::Upgrade.duration_next_check
                                    Daniel S
                                    When I put:
                                    it says:
                                    Traductor;;Upgrade.duration_next_check
                                    99999.0
                                    Daniel S
                                    • fredo6F Offline
                                      Daniel,
                                      This is where is the problem: 99999 is too big for a number of days.
                                      Can you change it in the default parameters or in the Upgrade dialog box
                                      I'll put a check in a next release
                                        Daniel S
                                        I can´t change the 99999 because:
                                        • The Upgrade dialog box don´t open
                                        • In default Parameters I can change it but it doesn´t really change.
                                          In the attach video I show what happens.
                                        I tried reinstalling LibFredo6 but still no work.
                                        Daniel S
                                        cant change.zip
                                        • COSEDIMARCOC Offline
                                          COSEDIMARCO
                                          Updated version of the Italian Translation of Fredo6 Library
                                          [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
                                              Daniel S
                                            If you feel up to adding one line of code into a rb file using a plain text-editor like Notepad[++].exe... find this file Capture1.PNG open it and add this line and save it Capture.PNG Then you can't wait more than a year [365 days]
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 108
                                            • 109
                                            • 12 / 109
