    [Plugin] Drape Cpoints
    46 Posts 23 Posters 49.5k Views 23 Watching
      @olishea said:
      Never mind, I've got it to work now. You have to drape points over a group....I was triple clicking the mesh and then trying to use the plugin. duh!
      I am using this to simplify a dirty 3D topographical survey and it work beautifully! such a good idea. I was just about to start manually draping construction points then I thought, "hang on a minute.....there MUST be a plugin for this"
      so thank you ever so much for taking the time to make and share this wonderful ruby! It will save me lots and lots of time and stress so hats off to TIG! bravo!
      If I remember correctly, the Archiland plugin has a tool that recreates a terrain in a regular pattern: http://forums.sketchucation.com/viewtopic.php?f=323&t=13760#p102771
      • olisheaO Offline
        olishea
        ah thomthom thank you!! i didnt know that plugin existed. you can really simplify a mesh with it, nice one!! and cheers to cadfather too.
        here is a screenshot of my mesh tests.
        Think i will be using the triangulated construction points at 5000mm centres....detailed enough for my needs. I love the archiland "simplify contours" tool as well, its a great idea.
        http://i654.photobucket.com/albums/uu269/olishea/Picture28-1.png
        oli
        • EdsonE Offline
          Edson
          @earthmover said:
          Another use for the script.....5 minute bedspread. (Bed model from warehouse)
          adam,
          did you just move the points using the regular move tool or did you use another plugin to make the bedspread?
          http://www.mahfuz.arq.br
          • EarthMoverE Offline
            EarthMover
            Yes, Edson I just moved the Cpoints manually before running the triangulate plugin to give the appearance of ruffled edges. I also used JPP to give thickness to simulate the fold over atop the pillows.
            Content Creator at Skapeup
            • Y Offline
              yukonhoo
              @tig said:
              The script 'points_cloud_triangulation.rb' [which shows in the Plugins menu as 'Triangulate Points'] is here...
              http://www.crai.archi.fr/RubyLibraryDepot/Ruby/points_cloud_triangulation.rb
              that also requires 'delauney2.rb' - which you can get here...
              http://forums.sketchucation.com/viewtopic.php?p=117071#p117071
              Thanks!!
                Thanks!!
                I have recently updated a version of the 'cloud' tool and a related delauney3 - do a search on the Plugins forum... 🤓
                • Didier BurD Offline
                  Didier Bur
                  Note that I recently changed the old typo in the main script 'require ./delauney2.rb' to 'require 'delaunay2.rb'
                  The required file has been renamed 'delaunay2.rb'
                  Regards,
                  DB
                  • tibetT Offline
                    tibet
                    hi,
                    could you please make step by step tut for creating your wonderful "5-minute bedspread" for those, who´re in the process of learning, just a bit far behind you (youtube is fine too)
                    thanks !
                    SU 2015 Pro on Win10 x64
                      Excellent Adam 👍
                        Nice tut! ☀
                        • N Offline
                          nomeradona
                          Wow Adam that is a cool tutorial.
                            EarthMover
                            Thanks guys..glad it was helpful. Here's a few tests of the method on different shapes. It's not as good as a physics based cloth simulation, but the results are fairly convincing. For table cloths, you just need to make sure you have a ground shape object that is slightly larger than the table and in the same group, so that the Cpoints will drape down and onto the ground. The same method can be used to make water in a stream bed or snow on a rooftop.
                            • tibetT Offline
                              tibet
                              hi earthmover,
                              thanks for your valuable time and desire to share your knowledge among sketchup fans/learners.
                              it´s pretty cool, well done!
                              cheers!
                                EarthMover
                                Tibet, here is a quick tutorial on the bedsheet.
                                [flash=800,600:pdjve3kf]http://www.youtube.com/v/wIcHHsjQ-Mo[/flash:pdjve3kf]
                                • X Offline
                                  xrok1
                                  Thanks!!
                                  "and a related delauney3" can't find this?
                                    Thanks!!
                                    The delauney3.rb is a modified version I wrote to use with my version of The Triangulate-Points tool here http://forums.sketchucation.com/viewtopic.php?p=301274#p301274 = the .rb is in the zip file with the tool's .rb...
                                    It in no way replaces or affects other tools using earlier 'delauney' scripts - however the earlier scripts can clash with so other tools so that is why I rewrote the modularized versions of them...
                                      thepolarblair
                                      Hi TIG - First off - Amazing Plugin! Currently trying to model a leather headboard and will be using it to get nice uneven edges for a more realistic look. This may have already been flagged up so please ignore if that's the case, but I can't seem to get the plugin to work in Sketchup 8. 6 is fine so its not causing me any hassle but I just thought it could be worth a mention. Again - thank you very much. I'll try to post the results when I get there.
                                        It should work fine in v8.
                                        Do you have the latest v8M3 installed ?
                                        Do you get any error messages in the pre-opened Ruby Console when you run this tool ?
                                        Do you have a 'rogue' script auto-loading that can cause issues by messing with the base-classes or making ill-formed observers ?
                                        Examples are SketchyPhysics, Matchbox, DrivingDimensions and an old SolarStudy tool [I forget its exact name]...
                                        If so, try moving them out of the Plugins folder and retry the tool...
                                          anar
                                          Great plugin thanks TIG!
                                          But why not let the user choose his own projection axis instead of only using Z down ?
                                          It would make the plug even more useful if you don't have to rotate the target group as intended before to use it.
                                          Cheers!
                                          • olisheaO Offline
                                            olishea
                                            still one of my all time favourite plugins
                                            oli
                                            • 2 / 3
