    [Plugin] Drape Cpoints
    46 Posts 23 Posters 50.8k Views 23 Watching
      dedmin
      @earthmover said:
      :berserk: Perfect perfect perfect! Exactly what I was looking for. Thank you so much TIG!
      Now I just need a "paint select faces" tool to quickly isolate faces in the triangulated topology. This will be a very useful tool for doing things like adding snow to an irregular shaped object, or adding water to a waterfall.
      Sorry, but how did you made triangulated mesh from the points?
        pibuz
        Sorry guys: I can't find the rb to triangulate the CPoints..
        Could you please head me to?
        ...btw GREAT RB! I can't wait to test it!
        WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
          The script 'points_cloud_triangulation.rb' [which shows in the Plugins menu as 'Triangulate Points'] is here...
          http://www.crai.archi.fr/RubyLibraryDepot/Ruby/points_cloud_triangulation.rb
          that also requires 'delauney2.rb' - which you can get here...
          http://forums.sketchucation.com/viewtopic.php?p=117071#p117071
          ๐Ÿค“
            dedmin
            @tig said:
            The script 'points_cloud_triangulation.rb' [Shows in the Plugins menu as 'Triangulate Points'] is here...
            ๐Ÿค“
            I tested it - SUPER USEFUL!!!!! BIG THANKS!! ๐Ÿ˜
              Ben Ritter
              Earthmover,
              For some reason, by looking at your images, I can't figure out what this script actually does or what happens in each step (e.g. bedspread example).
              Can you explain? Thanks.
                Ben Ritter
                TIG,
                Thanks for the explanation. I suppose it sounds more complicated than it really is.
                Ben
                  @ben ritter said:
                  Earthmover,
                  You select some faces/groups/components etc [the bed]. You give an XY grid spacing in a dialog and it makes a horizontal grid of Cpoints that's initially put just above the selection: the regular grid extends to the XY bounds of the selection. These Cpoints are then dropped down till they hit something in the selection OR, if not, then down to the minimum bounds of the selection. These Cpoints are grouped. This is all done so quickly you won't see it till the grid appears - there is a counter that shows its progress making the Cpoints and draping [dropping] them - there's also some 'behind the scenes' temporary grouping, erasing and exploding etc but you don't really need to worry about that ! Existing ruby tools can then work on these Cpoints to make a triangulated mesh face.
                  I surmise what was done with the 'bed' was to make the draped Cpoints, a faced mesh was made with 'Triangulate Points' and then some vertices forming the bottom edge were manually moved randomly to form the 'folds' of the bedspread. Perhaps a few top face vertices were moved a little to give some 'dints'. The sheet part was probably selected and moved up a little to form a change of plane for the different material. It was then all smoothed and the materials applied...
                  Its general use is if you have a triangulated site mesh made from survey data-points it'll likely be irregular - it's often preferable to make it into a regular XY grid (like those made by the Sandbox Tools). This tool lets you quickly drape a regular XY grid of Cpoints over the form and then reform them into a regular faced mesh using another tool, the original form is left unchanged...
                    jamma-pcb
                    ANy chance you could add gravity physics to this plugin.
                    The idea is to hover a face over multiple components and any space inbetween curve based on the gravity amount. Like draping a quilt over many pillows. The edges it would follow on Z and any space inbetween to curve out on multiple edges.
                    ANy chance of such a any tool
                      Sounds pretty complicated ! ๐Ÿ˜ฎ
                      Don't you want something inside SketchyPhysics like a 'chain of hinged links' that you anchor at its two ends and it then 'sags' appropriately ?
                      Each 'chain' would be made representing a 'rib' of a 'mesh' or 'net'...
                      You'd then swap the links for simple edges and explode stuff and you have the basis of the surface ???
                      My brain hurts already... ๐Ÿ‘Š
                      Thomthom is making a Vertex Editor and that might help ?
                      Remus has also done some work on Catenary Curves...
                      These things combined might do what you want BUT it'd be at the end of along list for me... others might pick up the gauntlet ? ๐Ÿ˜„
                      • EarthMoverE Offline
                        EarthMover
                        Sounds like he's looking for a real physics based cloth simulation plugin for sketchup. That seems as though it would be better integrated into sketchy physics as it has the framework for gravity simulation. I would love to see it, but I imagine it's still a far way off unless SU 8 implements a better engine under the hood.
                        Content Creator at Skapeup
                        • X Offline
                          xrok1
                          great plugin. thankyou. here is the .zip file that contains this and the other two plugins needed to create a mesh. maybe you could add it to your original post. would be less confusing for some. ๐Ÿ˜ณ
                          DRAPE_TRIANGULATE_DELU_Plugins.zip
                          โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                          • olisheaO Offline
                            olishea
                            TIG..I've got a problem.
                            The construction points appear, but they are not draped over the mesh (see screengrab). It just creates a regular, flat grid of c points under my mesh.
                            Am I doing something wrong?
                            http://i654.photobucket.com/albums/uu269/olishea/Picture26.png
                            oli
                            • olisheaO Offline
                              olishea
                              Never mind, I've got it to work now. You have to drape points over a group....I was triple clicking the mesh and then trying to use the plugin. duh!
                              I am using this to simplify a dirty 3D topographical survey and it work beautifully! such a good idea. I was just about to start manually draping construction points then I thought, "hang on a minute.....there MUST be a plugin for this"
                              so thank you ever so much for taking the time to make and share this wonderful ruby! It will save me lots and lots of time and stress so hats off to TIG! bravo!
                              oli
                                If I remember correctly, the Archiland plugin has a tool that recreates a terrain in a regular pattern: http://forums.sketchucation.com/viewtopic.php?f=323&t=13760#p102771
                                • olisheaO Offline
                                  olishea
                                  ah thomthom thank you!! i didnt know that plugin existed. you can really simplify a mesh with it, nice one!! and cheers to cadfather too.
                                  here is a screenshot of my mesh tests.
                                  Think i will be using the triangulated construction points at 5000mm centres....detailed enough for my needs. I love the archiland "simplify contours" tool as well, its a great idea.
                                  http://i654.photobucket.com/albums/uu269/olishea/Picture28-1.png
                                  oli
                                  • EdsonE Offline
                                    Edson
                                    @earthmover said:
                                    Another use for the script.....5 minute bedspread. (Bed model from warehouse)
                                    adam,
                                    did you just move the points using the regular move tool or did you use another plugin to make the bedspread?
                                    edson mahfuz, architect| porto alegre โ€ข brasil
                                    http://www.mahfuz.arq.br
                                      EarthMover
                                      Yes, Edson I just moved the Cpoints manually before running the triangulate plugin to give the appearance of ruffled edges. I also used JPP to give thickness to simulate the fold over atop the pillows.
                                      • Y Offline
                                        yukonhoo
                                        ๐Ÿค“
                                        Thanks!!
                                          ๐Ÿค“
                                          Thanks!!
                                          I have recently updated a version of the 'cloud' tool and a related delauney3 - do a search on the Plugins forum... ๐Ÿค“
                                          • Didier BurD Offline
                                            Didier Bur
                                            Note that I recently changed the old typo in the main script 'require ./delauney2.rb' to 'require 'delaunay2.rb'
                                            The required file has been renamed 'delaunay2.rb'
                                            Regards,
                                            DB
                                            • 2 / 3
