    [Plugin] Drape Cpoints
    46 Posts 23 Posters 51.1k Views 23 Watching
      jamma-pcb
      ANy chance you could add gravity physics to this plugin.
      The idea is to hover a face over multiple components and any space inbetween curve based on the gravity amount. Like draping a quilt over many pillows. The edges it would follow on Z and any space inbetween to curve out on multiple edges.
      ANy chance of such a any tool
        Sounds pretty complicated ! ๐Ÿ˜ฎ
        Don't you want something inside SketchyPhysics like a 'chain of hinged links' that you anchor at its two ends and it then 'sags' appropriately ?
        Each 'chain' would be made representing a 'rib' of a 'mesh' or 'net'...
        You'd then swap the links for simple edges and explode stuff and you have the basis of the surface ???
        My brain hurts already... ๐Ÿ‘Š
        Thomthom is making a Vertex Editor and that might help ?
        Remus has also done some work on Catenary Curves...
        These things combined might do what you want BUT it'd be at the end of along list for me... others might pick up the gauntlet ? ๐Ÿ˜„
        • EarthMoverE
          EarthMover
          Sounds like he's looking for a real physics based cloth simulation plugin for sketchup. That seems as though it would be better integrated into sketchy physics as it has the framework for gravity simulation. I would love to see it, but I imagine it's still a far way off unless SU 8 implements a better engine under the hood.
          Content Creator at Skapeup
          • X
            xrok1
            great plugin. thankyou. here is the .zip file that contains this and the other two plugins needed to create a mesh. maybe you could add it to your original post. would be less confusing for some. ๐Ÿ˜ณ
            DRAPE_TRIANGULATE_DELU_Plugins.zip
            โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
            • olisheaO
              olishea
              TIG..I've got a problem.
              The construction points appear, but they are not draped over the mesh (see screengrab). It just creates a regular, flat grid of c points under my mesh.
              Am I doing something wrong?
              http://i654.photobucket.com/albums/uu269/olishea/Picture26.png
              oli
              • olisheaO
                olishea
                Never mind, I've got it to work now. You have to drape points over a group....I was triple clicking the mesh and then trying to use the plugin. duh!
                I am using this to simplify a dirty 3D topographical survey and it work beautifully! such a good idea. I was just about to start manually draping construction points then I thought, "hang on a minute.....there MUST be a plugin for this"
                so thank you ever so much for taking the time to make and share this wonderful ruby! It will save me lots and lots of time and stress so hats off to TIG! bravo!
                oli
                  If I remember correctly, the Archiland plugin has a tool that recreates a terrain in a regular pattern: http://forums.sketchucation.com/viewtopic.php?f=323&t=13760#p102771
                  • olisheaO
                    olishea
                    ah thomthom thank you!! i didnt know that plugin existed. you can really simplify a mesh with it, nice one!! and cheers to cadfather too.
                    here is a screenshot of my mesh tests.
                    Think i will be using the triangulated construction points at 5000mm centres....detailed enough for my needs. I love the archiland "simplify contours" tool as well, its a great idea.
                    http://i654.photobucket.com/albums/uu269/olishea/Picture28-1.png
                    oli
                    • EdsonE
                      Edson
                      @earthmover said:
                      Another use for the script.....5 minute bedspread. (Bed model from warehouse)
                      adam,
                      did you just move the points using the regular move tool or did you use another plugin to make the bedspread?
                      edson mahfuz, architect| porto alegre โ€ข brasil
                      http://www.mahfuz.arq.br
                      • EarthMoverE
                        EarthMover
                        Yes, Edson I just moved the Cpoints manually before running the triangulate plugin to give the appearance of ruffled edges. I also used JPP to give thickness to simulate the fold over atop the pillows.
                        • Y
                          yukonhoo
                          @tig said:
                          The script 'points_cloud_triangulation.rb' [which shows in the Plugins menu as 'Triangulate Points'] is here...
                          http://www.crai.archi.fr/RubyLibraryDepot/Ruby/points_cloud_triangulation.rb
                          that also requires 'delauney2.rb' - which you can get here...
                          http://forums.sketchucation.com/viewtopic.php?p=117071#p117071
                          ๐Ÿค“
                          Thanks!!
                            ๐Ÿค“
                            Thanks!!
                            I have recently updated a version of the 'cloud' tool and a related delauney3 - do a search on the Plugins forum... ๐Ÿค“
                            • Didier BurD
                              Didier Bur
                              Note that I recently changed the old typo in the main script 'require ./delauney2.rb' to 'require 'delaunay2.rb'
                              The required file has been renamed 'delaunay2.rb'
                              Regards,
                              DB
                              • tibetT
                                tibet
                                hi,
                                could you please make step by step tut for creating your wonderful "5-minute bedspread" for those, whoยดre in the process of learning, just a bit far behind you (youtube is fine too)
                                thanks !
                                SU 2015 Pro on Win10 x64
                                  Excellent Adam ๐Ÿ‘
                                    Nice tut! โ˜€
                                    • N
                                      nomeradona
                                      Wow Adam that is a cool tutorial.
                                      • EarthMoverE
                                        EarthMover
                                        Thanks guys..glad it was helpful. Here's a few tests of the method on different shapes. It's not as good as a physics based cloth simulation, but the results are fairly convincing. For table cloths, you just need to make sure you have a ground shape object that is slightly larger than the table and in the same group, so that the Cpoints will drape down and onto the ground. The same method can be used to make water in a stream bed or snow on a rooftop.
                                        • tibetT
                                          tibet
                                          hi earthmover,
                                          thanks for your valuable time and desire to share your knowledge among sketchup fans/learners.
                                          itยดs pretty cool, well done!
                                          cheers!
                                          • EarthMoverE
                                            EarthMover
                                            Tibet, here is a quick tutorial on the bedsheet.
                                            [flash=800,600:pdjve3kf]http://www.youtube.com/v/wIcHHsjQ-Mo[/flash:pdjve3kf]
                                            • 2 / 3
