[Plugin] Sketchup Ivy
.rar is a different compression format. Use 7zip or PeaZip to uncompress and then place in plugins folder
So I have to download an extractor? Then I would extract it the same as I would a .zip? Alright. Thanks.
Yes, Windows doesn't extract .rar and many other compression types. Anyway either of those i posted are great alternatives to have.
Yep. Thanks. I got PeaZip seems to work well and looks like a useful tool.
I haven't read through the whole thread so please forgive me if this has been asked and/or solved before.
I play around with my ivy until I am satisfied but when I Shift+Click to create the actual geometry, nothing happens. Am I doing something wrong? I am running SketchUp 7 on Windows XP and have SketchUp Ivy version 0.6.3. I know you said this isn't tested on SketchUp 7. Is this my problem?
Nevermind. Works fine in SU 8. Really is a bummer though. Will there ever be support for version 7?
@sadyo said:
I am following what TIG says, about better test if the variable is NOT 'nil', then i try to fill a variable on the Branch Detail,...and voilaaa.... the Ivy appearing like it should and the SketchUpIvy0.6.3 can work very well now.
hooorraaay.. yes its work.. basically we need to input the detail and spread on ivy tab..
thanks tig,sadyo and pierreden for this pluginsregards,
@vidy said:
regards,
Shame on me I don't understood what TIG says until now. The plugin works like charm.
Thankyou guys.Sketchup 8.0.3117
Sketchup Ivy 0.6.3
Win 7 Ult -
nothing in su8 mac...
even nil change to 1 doesnt do anything, also no errors or feedback from the rubyconsole -
Translation version 0.6.3 beta to spanish
Traducción de la versión 0.6.3 beta al español
Perhaps this could be useful,
I am following what TIG says, about better test if the variable is NOT 'nil', then i try to fill a variable on the Branch Detail,...and voilaaa.... the Ivy appearing like it should and the SketchUpIvy0.6.3 can work very well now .
Thanks TIG...Thanks Piereden -
i have the same problem. the leaf image its not right.
it apears a rectangle in the limits of the image area, and someones have this white area.
may be ther ins't some details in the instructions
please answer me -
There are some problems with the three ivy leaf skp files pre-provided...
The files are quite large because tif images were used; smaller png images with transparent backgrounds would suffice - these could be edited to fix this.
The other issue is that these skp files currently have the four sides of the rectangular face as regular edges, which will inevitably show up when imported as a component. If the original skp is edited and the four edges selected and made 'hidden' then the imported leaves will no longer shown them [unless of course view>hidden-geometry is 'on' when they'll look like dotted lines]... If you've already got some such leaves imported you can edit them in situ and make their edges hidden - as they are instances, editing one should edit all of its siblings... -
ok, thankyou!
i will try.
someone have one work finished to share? (skp file and jpg image) -
Matidami14
Why can't you edit the three files yourself they are inside the Plugin's subfolder ?
i already do that, look this files:
http://www.sendspace.com/file/7b8f80
when i render the skb, the rectangles apears again! i guess its vray.. the ocult geometry shows in the process
Make sure that the texture's image file has a totally transparent background with ALL pixels completely transparent etc...
matidami14, take a look of this, maybe work for you.
the files are in here:
http://www.sketchando.net/descargas/ivy_leaf_enavas_ver6.0.rar
Regards
o bad the script doesn't have rotation for the leaves. Something like a min and max, now it always looks really flat and evenly
following...
It works fine
http://www.mypicx.com/06072011/Ivye/
