    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 543.7k Views 172 Watching
    • V
      vidy
      @thomthom said:
      Those of you with problems: can you post more info to what isn't working. "Not working" is like going to the doctor saying "I'm ill, fix me."
      Please be specific by what isn't working (lack of menus, errors, or unexpected behaviour). Also keep the Ruby Console open so you can see if any error messages appear.
      System information such as OS version and exact SketchUp version also helps.
      Current problem on ver 0.6.3 on SU 8 at mine:
      1. When i press alt + click, sometime ivy doesn't follow the direction i clicked.
      2. Some time it doesn't react as it is supposed to be when i press ctrl + click (to grow leaves)
      3. And the most problem.. it just won't finished when i press shift + click, so it never generated the ivy. ๐Ÿ˜ž
      but when i used ver 0.5.4, it's all work perfectly.. ๐Ÿ˜„
      still so much to learn..
        In the script's line #20 [..branch] and line #244 [..tool] [and probably other lines too ๐Ÿ˜• ] there is some arithmetic where something that's 'nil' is subtracted from something else and so it returns an error...
        Either put these parts into begin...rescue...end traps so the error won't trip up the script OR better test if the variable is NOT 'nil' and setting it to say 0 if +or- or 1 if *or/ - e.g. xxx=0 if not xxx
        The tools could be trapped to return at least something 1-seed.params[:branch][:spread] will fail if NOT seed.params[:branch][:spread] (i.e. it's nil)...
        LiveIvy.seed is defined as @@seed which in turn is defined as ' self' ๐Ÿ˜•
        which in turn has params which have :branch and :spread... BUT somewhere some of these aren't getting set to 0 [or 1 ?] as a safety net ??
        • PixeroP
          Pixero
          I have the same problems as Vidy.
          • It doesnt branch. Just one stem.
          • Doesn't finish. ๐Ÿ˜ž
            Windows 7 64bit. SU 8.
          • rodrigonotorR
            rodrigonotor
            You're rigth, here are the info:
            Sketchup 8.0.3117
            Sketchup Ivy 0.6.3
            Win 7 Ult
            Only create a little part of the Ivy and when I make Click+Shitft not work at all.
            Ruby Console:
            Error; #<TypeError; nil can't be coerced into Fixnum>
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;20;in `-'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;20;in `initialize'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;49;in `new'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;49;in `grow_stem'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;38;in `each'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;38;in `grow_stem'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;204;in `grow_stem'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;203;in `each'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;203;in `grow_stem'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;202;in `times'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;202;in `grow_stem'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;90;in `onLButtonUp'
            Click+Shift
            Error; #<NoMethodError; undefined method `-' for nil;NilClass>
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;244;in `birth_stem'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;237;in `each'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;237;in `birth_stem'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;226;in `birth'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;93;in `onLButtonUp'
            quietly_force_sync_mats_cb just called
            โ€ข Sketchando.net โ€ข www.arqcad.net โ€ข
            • sadyoS
              sadyo
              Yep, I have the same problems too, just like i/we already reported since v0.6.2
              Windows 7 64bit, SU8.0.4811 pro
              • urgenU
                urgen
                ....O-O-O-goooooooood! ๐Ÿ‘ please,do not stop this work,! ๐ŸŽ‰
                --pupil forever...------
                  SketchUpNoobie
                  O.K. This is embarrassing. ๐Ÿ˜’
                  How do I open the .rar file? ๐Ÿ˜• Do I just drop it in my plugins folder or do I need to do anything else such as extracting it somehow. I downloaded it right to my plugins folder and it doesn't seem to be showing up.
                  SketchUpNoobie: the complete noob in all things SketchUp.
                    .rar is a different compression format. Use 7zip or PeaZip to uncompress and then place in plugins folder
                      SketchUpNoobie
                      So I have to download an extractor? Then I would extract it the same as I would a .zip? Alright. Thanks.
                        Yes, Windows doesn't extract .rar and many other compression types. Anyway either of those i posted are great alternatives to have.
                          SketchUpNoobie
                          Yep. Thanks. I got PeaZip seems to work well and looks like a useful tool.
                            SketchUpNoobie
                            I haven't read through the whole thread so please forgive me if this has been asked and/or solved before.
                            I play around with my ivy until I am satisfied but when I Shift+Click to create the actual geometry, nothing happens. ๐Ÿ˜• Am I doing something wrong? I am running SketchUp 7 on Windows XP and have SketchUp Ivy version 0.6.3. I know you said this isn't tested on SketchUp 7. Is this my problem?
                              SketchUpNoobie
                              Nevermind. Works fine in SU 8. Really is a bummer though. Will there ever be support for version 7?
                              • V
                                vidy
                                @sadyo said:
                                I am following what TIG says, about better test if the variable is NOT 'nil', then i try to fill a variable on the Branch Detail,...and voilaaa.... the Ivy appearing like it should and the SketchUpIvy0.6.3 can work very well now.
                                hooorraaay.. yes its work.. basically we need to input the detail and spread on ivy tab..
                                thanks tig,sadyo and pierreden for this plugins ๐Ÿ˜
                                regards,
                                • rodrigonotorR
                                  rodrigonotor
                                  @vidy said:
                                  regards,
                                  Shame on me ๐Ÿ˜ณ I don't understood what TIG says until now. The plugin works like charm.
                                  Thankyou guys.
                                  Sketchup 8.0.3117
                                  Sketchup Ivy 0.6.3
                                  Win 7 Ult
                                  • romboutR
                                    rombout
                                    nothing in su8 mac...
                                    even nil change to 1 doesnt do anything, also no errors or feedback from the rubyconsole
                                    • rodrigonotorR
                                      rodrigonotor
                                      Translation version 0.6.3 beta to spanish
                                      Traducciรณn de la versiรณn 0.6.3 beta al espaรฑol
                                      SketchupIvy.0.6.3.esp_beta.rar
                                      • sadyoS
                                        sadyo
                                        Perhaps this could be useful,
                                        http://photoserver.ws/images/3AOt4de66fdea6ebb.jpg
                                        I am following what TIG says, about better test if the variable is NOT 'nil', then i try to fill a variable on the Branch Detail,...and voilaaa.... the Ivy appearing like it should and the SketchUpIvy0.6.3 can work very well now .
                                        Thanks TIG...Thanks Piereden
                                          matidami14
                                          i have the same problem. the leaf image its not right.
                                          it apears a rectangle in the limits of the image area, and someones have this white area.
                                          may be ther ins't some details in the instructions
                                          please answer me
                                            There are some problems with the three ivy leaf skp files pre-provided...
                                            The files are quite large because tif images were used; smaller png images with transparent backgrounds would suffice - these could be edited to fix this.
                                            The other issue is that these skp files currently have the four sides of the rectangular face as regular edges, which will inevitably show up when imported as a component. If the original skp is edited and the four edges selected and made 'hidden' then the imported leaves will no longer shown them [unless of course view>hidden-geometry is 'on' when they'll look like dotted lines]... If you've already got some such leaves imported you can edit them in situ and make their edges hidden - as they are instances, editing one should edit all of its siblings...
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 36
                                            • 37
                                            • 13 / 37
