    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 404.3k Views 172 Watching
    • rodrigonotorR Offline
      rodrigonotor
      You're rigth, here are the info:
      Sketchup 8.0.3117
      Sketchup Ivy 0.6.3
      Win 7 Ult
      Only create a little part of the Ivy and when I make Click+Shitft not work at all.
      Ruby Console:
      Error; #<TypeError; nil can't be coerced into Fixnum>
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;20;in `-'
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;20;in `initialize'
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;49;in `new'
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;49;in `grow_stem'
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;38;in `each'
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;38;in `grow_stem'
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;204;in `grow_stem'
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;203;in `each'
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;203;in `grow_stem'
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;202;in `times'
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;202;in `grow_stem'
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;90;in `onLButtonUp'
      Click+Shift
      Error; #<NoMethodError; undefined method `-' for nil;NilClass>
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;244;in `birth_stem'
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;237;in `each'
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;237;in `birth_stem'
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;226;in `birth'
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;93;in `onLButtonUp'
      quietly_force_sync_mats_cb just called
      • [Sketchando.net](http://foro.sketchando.net/portal.php) • www.arqcad.net •
      • sadyoS Offline
        sadyo
        @pixero said:
        @vidy said:
        @thomthom said:
        Those of you with problems: can you post more info to what isn't working. "Not working" is like going to the doctor saying "I'm ill, fix me."
        Please be specific by what isn't working (lack of menus, errors, or unexpected behaviour). Also keep the Ruby Console open so you can see if any error messages appear.
        System information such as OS version and exact SketchUp version also helps.
        Current problem on ver 0.6.3 on SU 8 at mine:
        1. When i press alt + click, sometime ivy doesn't follow the direction i clicked.
        2. Some time it doesn't react as it is supposed to be when i press ctrl + click (to grow leaves)
        3. And the most problem.. it just won't finished when i press shift + click, so it never generated the ivy. 😞
        but when i used ver 0.5.4, it's all work perfectly.. 😄
        I have the same problems as Vidy.
        • It doesnt branch. Just one stem.
        • Doesn't finish. 😞
          Windows 7 64bit. SU 8.
        Yep, I have the same problems too, just like i/we already reported since v0.6.2
        Windows 7 64bit, SU8.0.4811 pro
        • urgenU Offline
          urgen
          ....O-O-O-goooooooood! 👍 please,do not stop this work,! 🎉
          --pupil forever...------
            SketchUpNoobie
            O.K. This is embarrassing. 😒
            How do I open the .rar file? 😕 Do I just drop it in my plugins folder or do I need to do anything else such as extracting it somehow. I downloaded it right to my plugins folder and it doesn't seem to be showing up.
            SketchUpNoobie: the complete noob in all things SketchUp.
            • Rich O BrienR Online
              .rar is a different compression format. Use 7zip or PeaZip to uncompress and then place in plugins folder
                SketchUpNoobie
                So I have to download an extractor? Then I would extract it the same as I would a .zip? Alright. Thanks.
                  Yes, Windows doesn't extract .rar and many other compression types. Anyway either of those i posted are great alternatives to have.
                    SketchUpNoobie
                    Yep. Thanks. I got PeaZip seems to work well and looks like a useful tool.
                      SketchUpNoobie
                      I haven't read through the whole thread so please forgive me if this has been asked and/or solved before.
                      I play around with my ivy until I am satisfied but when I Shift+Click to create the actual geometry, nothing happens. 😕 Am I doing something wrong? I am running SketchUp 7 on Windows XP and have SketchUp Ivy version 0.6.3. I know you said this isn't tested on SketchUp 7. Is this my problem?
                        SketchUpNoobie
                        Nevermind. Works fine in SU 8. Really is a bummer though. Will there ever be support for version 7?
                        • V Offline
                          vidy
                          @sadyo said:
                          I am following what TIG says, about better test if the variable is NOT 'nil', then i try to fill a variable on the Branch Detail,...and voilaaa.... the Ivy appearing like it should and the SketchUpIvy0.6.3 can work very well now.
                          hooorraaay.. yes its work.. basically we need to input the detail and spread on ivy tab..
                          thanks tig,sadyo and pierreden for this plugins 😍
                          regards,
                          still so much to learn..
                            rodrigonotor
                            @vidy said:
                            regards,
                            Shame on me 😳 I don't understood what TIG says until now. The plugin works like charm.
                            Thankyou guys.
                            Sketchup 8.0.3117
                            Sketchup Ivy 0.6.3
                            Win 7 Ult
                            • romboutR Offline
                              rombout
                              nothing in su8 mac...
                              even nil change to 1 doesnt do anything, also no errors or feedback from the rubyconsole
                                rodrigonotor
                                Translation version 0.6.3 beta to spanish
                                Traducción de la versión 0.6.3 beta al español
                                SketchupIvy.0.6.3.esp_beta.rar
                                • sadyoS Offline
                                  sadyo
                                  Perhaps this could be useful,
                                  http://photoserver.ws/images/3AOt4de66fdea6ebb.jpg
                                  I am following what TIG says, about better test if the variable is NOT 'nil', then i try to fill a variable on the Branch Detail,...and voilaaa.... the Ivy appearing like it should and the SketchUpIvy0.6.3 can work very well now .
                                  Thanks TIG...Thanks Piereden
                                    matidami14
                                    i have the same problem. the leaf image its not right.
                                    it apears a rectangle in the limits of the image area, and someones have this white area.
                                    may be ther ins't some details in the instructions
                                    please answer me
                                      There are some problems with the three ivy leaf skp files pre-provided...
                                      The files are quite large because tif images were used; smaller png images with transparent backgrounds would suffice - these could be edited to fix this.
                                      The other issue is that these skp files currently have the four sides of the rectangular face as regular edges, which will inevitably show up when imported as a component. If the original skp is edited and the four edges selected and made 'hidden' then the imported leaves will no longer shown them [unless of course view>hidden-geometry is 'on' when they'll look like dotted lines]... If you've already got some such leaves imported you can edit them in situ and make their edges hidden - as they are instances, editing one should edit all of its siblings...
                                        matidami14
                                        ok, thankyou!
                                        i will try.
                                        someone have one work finished to share? (skp file and jpg image)
                                          Matidami14
                                          Why can't you edit the three files yourself they are inside the Plugin's subfolder ?
                                            matidami14
                                            i already do that, look this files:
                                            http://www.sendspace.com/file/7b8f80
                                            when i render the skb, the rectangles apears again! i guess its vray.. the ocult geometry shows in the process
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 36
                                            • 37
                                            • 13 / 37
